The Diffraction Grating (Grade 12 Physics)
In summary, the answer to whether the maxima created by a diffraction grating have the same intensity is no. This is due to the fact that a diffraction grating also produces secondary maxima, which have a lesser intensity than the principal maxima. The intensity of these secondary maxima decreases as the order of the spectra increases, making it necessary to adjust the incoming beam in order to cover more area of the grating and raise the overall intensity. This is a result of the superposition principle and is useful in measuring closely spaced emission wavelengths in various spectra.
EmilyBergendahl
32
Do the maxima created by a diffraction grating all have the same intensity? Explain.
mλ = wsinθ (?)
According to the back of my textbook (Nelson Physics 12), the answer is no. I believe the answer may have to do with the fact that a diffraction grating also produces secondary maxima of a lesser intensity than the principal maxima, but I'm not sure. Overall, I would like to understand how to better explain this.
Any help is appreciated!
When in labs (optics with spectrometer) i recall doing the experiment (long back in 1962) i remember that the central maxima was brightest(undiffracted) and the different order of spectra on the right and left of the central beam as
the first order was bright (about 80% intense) and
the 2nd order was less intense say about fifty percent of the first order
the 3rd order was very feeble say about 50% of the 2nd order...the higher orders were not available as the angular position was out of reach.
so, if you plot the intensity/compare it ..its a fact that different order of the diffracted maxima has decreasing intensity and to raise the general intensity the incoming beam was adjusted so that it covers more area of the grating.
naturally a question comes to our mind - what is the reason for this variation-
If one starts with single slit diffraction- the central maxima lies at zero degree, and its maximum intense the secondary maxima and further on are reduced in Intensity- as we add number of slits a theoretical estimate of the Intensity can be done by using superposition principle and it comes out that the diffracted secondary maximas superposed on individual slit diffraction will have reduced intensity and N-slits (grating is a device to raise the intensity of higher order spectral lines) and is used for measurement of lines of different wavelengths-say in sodium light the doublet separation increases as the order of spectra is increased and one can measure closely spaced emission characteristic wavelengths say in hydrogen or helium /mercury/neon spectra.
However the relative intensity of different orders of spectra decreases.
For the expression of Intensity of different orders one can look up
REF.
<https://www.uAlberta.ca/~pogosyan/teaching/PHYS_130/FALL_2010/lectures/lect36/lecture36.html>
Likes EmilyBergendahl
FAQ: The Diffraction Grating (Grade 12 Physics)
1. What is a diffraction grating?
A diffraction grating is a device used to separate light into its component wavelengths. It consists of a large number of parallel, evenly spaced slits or lines that cause diffraction of light passing through them.
2. How does a diffraction grating work?
When light passes through a diffraction grating, each slit acts as a point source of light, producing a series of diffraction patterns. These patterns interfere with each other, resulting in a distinct pattern of bright and dark fringes, known as interference pattern. The spacing between these fringes depends on the wavelength of light and the distance between the slits.
3. What is the difference between a diffraction grating and a prism?
A prism uses refraction to separate light into its component wavelengths, while a diffraction grating uses diffraction. Additionally, a prism separates light into a continuous spectrum, while a diffraction grating produces a spectrum with distinct, sharp lines.
4. How is a diffraction grating used in spectroscopy?
In spectroscopy, a diffraction grating is used to analyze the composition of light sources. By passing light through a diffraction grating, the different wavelengths of light are separated and can be measured, allowing scientists to identify the elements present in a light source.
5. What is the equation for calculating the angle of diffraction in a diffraction grating?
The equation for calculating the angle of diffraction in a diffraction grating is given by: sinθ = mλ/d, where θ is the angle of diffraction, m is the order of the diffraction (usually an integer), λ is the wavelength of light, and d is the distance between the slits on the grating.
13K
10K
