- #36
DrGreg
- 2,081
I think this thread is getting bogged down in the technicalities of how to measure a non-constant frequency, which has little to do with the doppler effect.
Mathematically, signal of frequency f can be described by the formula
and that is valid whether f is constant or varies as a function of time. The doppler effect can be described mathematically in these terms and "granularity" is irrelevant.
The complication arises in the real world if you are given a signal to listen to and asked to decide what f is. This is difficult because because you won't just hear the signal but also interference from other sounds nearby. If you analysing using a microphone and electronic equipment (analogue or digital), there will be distortions and noise introduced by the equipment. If you analysing with your own ears and brain, there will be distortions due to the acoustic properties of the ear and its perception mechanisms. The problems get worse if you can listen over only a short period of time or the frequency is changing very rapidly. This means in practice there are always uncertainties when trying to measure the frequency of a signal over a short period of time or the when frequency is changing very rapidly. (Mathematically, this uncertainty is pretty much identical to the Heisenberg uncertainty of quantum physics.) However, I wouldn't describe this as "granularity" as that suggests only discrete answers and the problem is a bit more subtle than that. It is a practical problem of measurement and doesn't affect the theory behind the doppler shift, where we can assume no noise or interference and perfect measurements (even if such measurements are impossible in the real world).
[tex]\sin (2\pi f t + \phi)[/tex]
