The Durability of Bone: Long Falls
  • Thread starter enterthetaiga
In summary, the "Long Fall Boots" that prevent any damage no matter how far you fall are only effective if you land on your feet on a hard, sturdy surface. If you land with bent knees it is less painful. The boots are only effective up to a few meters, and they only work if you bend your knees.
enterthetaiga
I am doing a paper on the physics in Valve's Portal and got interested in the "Long Fall Boots" that prevent any damage no matter how far you fall. I can calculate the force they can withstand and all of that, but I wonder how much more durable these boots are than plain human feet. So here is my question:
How much force is required to break a pair of human legs given that the person is in free fall and lands on her (the character in portal is an average-sized female) feet on a hard, sturdy surface (like tile), or how much energy can a pair of human legs absorb?
The long-fall boot are total fantasy.
The maximum energy a bone can absorb without breaking is surprisingly small. The leg bones can absorb about 200 J - and you get two of them per human. (I'm pressed to find a reference though.)
Breaking a bone depends on the angle and type of the impact as well as the force of the impact.
Breakages from modest falls usually result from a bad angle of landing - for a very long fall, the knee joint will fail even if nothing else does.
You'll have noticed that if you land with bent knees it is less painful than landing with straight knees.
If you bend your legs then the momentum change when you land is spread over longer.
Also see:
https://www.physicsforums.com/showthread.php?t=312805
Humans have a terminal velocity so above a certain height (call it Hmax) any increase in height makes no difference to how fast you land. So that limits how effective the boots need to be.
The maximium safe height without magic boots is only a few meters (call it Hs).
So one approach would be to say that the boots are Hmax2/Hs2 times as effective.
Bending the knees is recommended...
http://www.wikihow.com/Survive-a-Long-Fall
Bend your knees. Possibly nothing is more important to surviving a fall (or simpler to do) than bending your knees. Research has shown that having one’s knees bent at impact can reduce the magnitude of impact forces 36-fold
Sadly no source cited.
Perhaps of interest..
http://scienceblogs.com/dotphysics/2009/12/16/dangerous-jumping-calculator/
FAQ: The Durability of Bone: Long Falls
How are bones able to withstand long falls and impact?
Bones are made up of a complex structure of collagen and minerals such as calcium and phosphate, which give them strength and rigidity. This structure is able to absorb and distribute forces, making bones more resistant to fractures.
Can bones become stronger and more durable over time?
Yes, bones have the ability to adapt and become stronger through a process called remodeling. When subjected to repeated stress, bones will remodel themselves to better withstand that stress, making them more durable in the long run.
Are certain bones more durable than others?
Yes, certain bones in the body are designed to withstand more force and impact than others. For example, the bones in the legs are thicker and stronger compared to the bones in the fingers, which are more delicate and prone to fractures.
How do factors like age and health affect the durability of bones?
As we age, our bones naturally become less dense and more fragile. This can make them less durable and more prone to fractures, especially in older individuals who may have pre-existing health conditions that affect bone strength and density.
Can nutrition and exercise play a role in bone durability?
Yes, proper nutrition and regular exercise can contribute to the durability of bones. Consuming enough calcium and vitamin D, as well as engaging in weight-bearing exercises, can help maintain bone density and strength, making them more resistant to fractures.
