I The effect of temperature on the damping of a guitar string
Temperature influences the frequency of a guitar string by affecting its elasticity and tension, but its impact on damping is less clear. The discussion highlights that colder air, being denser, can extract more energy from the string, resulting in a louder sound initially but leading to quicker damping. The viscous damping coefficient, which is crucial for understanding damping effects, does not typically include temperature as a variable. Additional research into the drag equation may provide insights into how air density and temperature interact with string vibration. Overall, while temperature affects frequency and sound intensity, its role in damping requires further investigation.
SamuuLau
TL;DR Summary
How does temperatue affect damping of a guitar string, assuming temperature doesn't change the other factors, such as the wooden guitar?
I am a high school student and recently I have been working on a project about how temperature affects the frequency of a string emits. I have read blogs like https://www.physicsforums.com/threads/tension-and-frequency-with-change-in-temperature.833185/ and completed the part of thermal expansion to the elasticity/tension force. However, another question that strikes me is how does temperature affect the damping of the string.
I looked up some formulas that might be related, such as the model of $$T\frac{\partial^2 y(x,t)}{\partial x^2} + \beta\frac{\partial y(x,t)}{\partial t}-\rho \frac{\partial^2 y(x,t)}{\partial t^2} = 0$$ Where 𝛽 is a viscous damping coefficient.
I searched about what affects the vicous damping coefficeint and I couldn't find temperature as one of the factors. Am I wrong assuming temperatue changes the damping of a guitar string?
Also, I am assuming the temperature has no effect on any material besides the string such as the guitar neck or wood. I am focusing solely on the metal string.
Welcome to PF.
Colder, more dense air, extracts more energy from the string, so it sounds louder initially, but is damped more quickly.
You need to study the drag equation. https://en.wikipedia.org/wiki/Drag_equation
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
