The effect on a photocurrent of reducing the frequency of photons
In summary, the current in a photoelectric effect is independent of frequency, as the number of emitted electrons per unit time remains constant for frequencies above the threshold frequency. This is due to the fact that the kinetic energy of the electrons may increase with frequency, but the average number of electrons passing through a cross-sectional area remains constant. Therefore, the correct answer is option (c).
Pushoam
962
52
As frequency is decreased to threshold, no. of emitted electrons will remain same, but their maximum kinetic energy will decrease. So, the current should decrease slowly.
For frequency less than the threshold frequency, no electron will be emitted. So, the current should fall down to 0 at threshold frequency and for frequency less than threshold frequency.Option(c) meets the above two conditions. So, this should be the correct option. Right?
How does the kinetic energy relate to the current? How is current defined?
The number of emitted electrons per unit time is independent of frequency for f > fth.
So, even if the kinetic energy of the electron increases when frequency is increased, the average no. of electrons pasing a cross -sectional area per unit time remains independent of frequency.
So, the current is independent of frequency.
Hence, the answer is option (c).
Right?
## I = \frac {kn}t ##, where n is no. of photons touching the metal surface and k is the fraction of photons which eject electrons
Yes!
Right?
Yup!
Related to The effect on a photocurrent of reducing the frequency of photons
1. What is photocurrent and how is it affected by the frequency of photons?
Photocurrent is the flow of electrical current that is generated when light is shone onto a photosensitive material. The frequency of photons refers to the number of wave cycles of light per second. The lower the frequency of photons, the lower the energy of the light particles, which results in a lower photocurrent.
2. How does the frequency of photons impact the efficiency of a photocell?
The efficiency of a photocell, which is the ratio of the generated photocurrent to the incident light intensity, is directly affected by the frequency of photons. As the frequency decreases, the efficiency also decreases as the lower energy photons are less able to generate an electrical current.
3. Can the frequency of photons be reduced without impacting the overall light intensity?
Yes, the frequency of photons can be reduced without affecting the overall light intensity by using filters or diffraction gratings. These tools can isolate specific frequencies of light and allow them to pass through while blocking others, resulting in a change in frequency without altering the overall intensity.
4. Does the material of the photocell affect the relationship between frequency and photocurrent?
Yes, the material of the photocell can play a role in the effect of reducing the frequency of photons on photocurrent. Different materials have different energy band gaps, which determine the minimum energy needed for electrons to be excited and generate a photocurrent. Therefore, the impact of reducing frequency may vary depending on the material used.
5. Are there any practical applications for manipulating the frequency of photons in a photocell?
Yes, there are practical applications for controlling the frequency of photons in a photocell. For example, in solar cells, researchers are exploring ways to lower the frequency of photons to increase the efficiency of converting light into electricity. There are also potential applications in telecommunications, where manipulating the frequency of photons can impact the speed and accuracy of data transmission.
  • Quantum Physics
