The Einstein Maxwell Action with sources
In summary, the free field Einstein-Maxwell action can be modified in the presence of sources by adding a term for the Maxwell source ##J_\mu A^\mu## in the matter Lagrangian ##\mathcal{L}_M##. In the presence of matter, the Hilbert action is modified to include the matter terms and the interaction term between charged particles and the electromagnetic field. This results in a total action that includes the gravitational field term and all other matter terms in ##\mathcal{L}_M##.
center o bass
560
The free field Einstein-Maxwell action is often states as
$$S[A, g] = - \frac{1}{4}\int_M F^{\mu \nu} F_{\mu \nu}d^4 x + \int_M R(M) d^4x$$
where ##M## is the spacetime manifold ##F## is the field strength and ##R(M)## is the curvature of the spacetime manifold as dictated by the metric tensor ##g##.
The question is, how are this modified in the presence of sources?
Individually, the maxwell action with sources are obtained by adding a term
$$\int_M J_\mu A^\mu d^4x$$
such that
$$S[A] = - \frac{1}{4}\int_M F^{\mu \nu} F_{\mu \nu}d^4 x - \int_M J_\mu A^\mu d^4x$$,
while for the Einstein Hilbert action we have to add
$$\int_M \mathcal{L}_M d^4 x$$
for some matter Lagrangian ##\mathcal{L}_M##.
The question is whether, for the combined action, the maxwell source term should be included in ##\mathcal{L}_M##? This seems logical because charged currents also contribute to the curvature of spacetime. On the other hand, the free field action above is varied with respect to ##A## and ##g## individually, so it seems that if the action with sources are going to reproduce the Maxwell equation
$$\partial_\nu F^{\mu \nu} = J^\mu$$
then we need a ##J_\mu A^\mu## term for the source -- and I've never seen such a term in the matter Lagrangian ##\mathcal{L}_M##.
In the presence of matter, the Hilbert action is modified to:
$$S=\int_M R\tilde{\omega}+\int_M \mathcal{L}_M \tilde{\omega}$$
Where ##\tilde{\omega}## is the volume form on your manifold, equal to ##\sqrt{-g}d^4x## in a given coordinate system.
##\mathcal{L}_M## includes all the matter terms, and so if you are in the presence of charged particles, it would be all 3 terms, the particle term, the field term, and the interaction term. Therefore, your total action would be:
$$S=\int_M R\tilde{\omega}-\sum_{\text{i=particles}}\int m_ic ds_i-\int_M A^\mu J_\mu \tilde{\omega}-\frac{1}{4}\int F_{\mu\nu}F^{\mu\nu} \tilde{\omega}$$
Every term that is not the gravitational field term should be included in ##\mathcal{L}_M##
Related to The Einstein Maxwell Action with sources
1. What is the Einstein Maxwell Action with sources?
The Einstein Maxwell Action with sources is a mathematical framework that describes the behavior of electromagnetic fields and their interactions with gravity. It is a modification of the Einstein-Hilbert action, which describes the behavior of gravity alone.
2. How is the Einstein Maxwell Action with sources derived?
The Einstein Maxwell Action with sources is derived from the Einstein-Maxwell equations, which describe the behavior of electromagnetic fields in the presence of gravity. The action is constructed by combining the Einstein-Hilbert action with the electromagnetic field Lagrangian.
3. What does the term "action" mean in physics?
In physics, action refers to a mathematical quantity that describes the dynamics of a physical system. It can be thought of as the "sum" of all possible paths that a system can take in space and time, and it is used to determine the equations of motion for that system.
4. How does the Einstein Maxwell Action with sources relate to other theories of gravity?
The Einstein Maxwell Action with sources is a modification of the Einstein-Hilbert action, which is the basis for Einstein's theory of general relativity. It is also closely related to other theories of gravity, such as Brans-Dicke theory and scalar-tensor theories.
5. What are the applications of the Einstein Maxwell Action with sources?
The Einstein Maxwell Action with sources has many applications in modern physics, including cosmology, black hole physics, and the study of gravity and electromagnetism at small scales. It is also used in theoretical research to explore new ideas and potential modifications to the theory of general relativity.
