The elasticity/stiffness tensor for an isotropic materials
In summary, the elasticity/stiffness tensor for isotropic and homogeneous materials is characterized by two independent material parameters (λ and μ) and is given by the representation C_{ijkl} = \lambda\delta_{ij}\delta_{kl} + \mu(\delta_{ik}\delta_{jl} + \delta_{il}\delta_{jk}). The most general form for materials with cubic symmetry is C_{ijkl} = \lambda\delta_{ij}\delta_{kl} + \mu\delta_{ik}\delta_{jl} + \nu\delta_{il}\delta_{jk}, with three independent parameters, but it only satisfies the expected symmetries when μ = ν. This is why μ = ν for isotropic materials
Wuberdall
34
Hi PF,
As you may know, is the the elasticity/stiffness tensor for isotropic and homogeneous materials characterized by two independant material parameters (λ and μ) and is given by the bellow representation.
[tex]C_{ijkl} = \lambda\delta_{ij}\delta_{kl} + \mu(\delta_{ik}\delta_{jl} + \delta_{il}\delta_{jk})[/tex]
Do any of you know a sound argument, mostly relaying on physical intuition, for why this is the most general form of the elasticity tensor for isotropic and homogeneous materials?
Of course one could always impose all the symmetries (for an isotropic material) upon the elasticity tensor and go through all the necessary and tedious computations to derive this result... But this is unfortunately not what I'm looking for.
And furthermore, what are/is the difference between isotropic materials and materials possessing cubic symmetry, where the most general elasticity tensor instead is written
[tex]C_{ijkl} = \lambda\delta_{ij}\delta_{kl} + \mu\delta_{ik}\delta_{jl} + \nu\delta_{il}\delta_{jk}[/tex]
and is characterized by three (instead of two) independant material parameters.
That is, why is μ = ν for isotopic materials ?
Thanks in advance :-))
The most general isotropic rank four tensor is of the form with three independent parameters. However, this does not satisfy the symmetries expected from the stiffness tensor. It only does so when ##\mu = \nu##.
Related to The elasticity/stiffness tensor for an isotropic materials
What is the elasticity/stiffness tensor for an isotropic material?
The elasticity or stiffness tensor for an isotropic material is a mathematical representation of the material's mechanical properties. It describes how the material responds to external forces and how it deforms under stress.
How is the elasticity/stiffness tensor calculated?
The elasticity/stiffness tensor is calculated by performing experiments on the material, such as tension or compression tests, and measuring the resulting strain and stress. These values are then used to determine the material's elastic constants, which are used to construct the tensor.
What does the elasticity/stiffness tensor tell us about a material?
The elasticity/stiffness tensor provides information about a material's stiffness, strength, and ability to deform under stress. It also allows us to predict how the material will respond to different types of loading, such as tension, compression, or shear.
How does the elasticity/stiffness tensor differ for different materials?
The elasticity/stiffness tensor is unique for each material, as it depends on the material's internal structure and composition. Isotropic materials, which have the same properties in all directions, have a simpler tensor compared to anisotropic materials, which have different properties in different directions.
Why is the elasticity/stiffness tensor important in materials science and engineering?
The elasticity/stiffness tensor is crucial in materials science and engineering because it allows us to understand and predict a material's behavior under different conditions. This information is essential for designing and selecting materials for various applications, such as in construction, manufacturing, and product design.
  • Electromagnetism
  • Linear and Abstract Algebra
  • Mechanics
27K
  • Differential Geometry
16K
