The Electric Flux on all sides of a cube
The discussion revolves around calculating the electric flux through a cube's surfaces, with participants addressing issues related to the correct application of formulas and the importance of understanding the concept of flux. The initial poster struggles with their calculations and is advised to consider the angles of the surfaces relative to the electric field, as not all surfaces are perpendicular. Clarifications are made regarding the area calculation for square surfaces, emphasizing that it should be length times width rather than using πr². Participants suggest sketching the electric field and understanding the meaning of flux to apply the correct equations effectively. Ultimately, the consensus is that a deeper comprehension of the principles involved is crucial for solving the problem accurately.
ecsx00
\phi = \vec{E} * A * d
phi is the electric flux
E is the Electric field from vector form
A is the area and A = \pir^{2}
d is the distance on the axis (x, y, or z)
s1 = s3 = 0 *Since they are along the y-axis and there is no y-vector
s2 = 1.14e-1
s4 = - 1.14e-1
s5 = 2.69e-1
s6 = -2.69e-1
I don't know why I am getting these wrong but you need to arrange them from s1-s6 on the answer when you submit them and it tells me to check my sign on s5. Changing it to negative doesn't help.
I'll recheck my calculations again and try a different method. I probably forgot to put " \pi" into the calculations but I will check on that.
Am I doing this right? Or is the equation to solve this problem totally different and I am off.
Pointing out where I went wrong helps, please do not post the answer as I just need a hint or tip.
Thank you!
Area for a square is the length times width not \pi r^2 .
You need to consider that flux is dependent on angle and that not all the surfaces are perpendicular to the electric field.
Also what is the deal with the distance component in you're equation for flux?
I'd add as a hint: sketch the field.
I really have no clue. This equation is from the book directly.
\varphi = \vec{E}L^{2}cos(θ)
or
\varphi = -\vec{E}L^{2}cos(θ)
Where E is the electric field from the \hat{n} vector.
θ is either 90° or 180°
Is that the equation I am looking for?
Instead of trying to guess which equation to apply - why don't you start with what "flux" actually means? And seriously: sketch the field.
Were you able to figure it out?
That equation looks right. Like Simon said though you should make sure to understand what flux means and you'll know when to apply the appropriate equations.
Use $$\oint \vec{E} \cdot \vec{dA}$$ What is E and dA? What is the value of the electric field along S5?
Thanks. I solved it after looking at a few examples that people had on this site and eventually figured out how they got to the solution. I wouldn't guess it.
Yeah - guessing seldom works without understanding.
22K
