Jeff Root
- 76
- 6
How was it discovered that electromagnetic radiation is electromagnetic?
-- Jeff, in Minneapolis
James Maxwell discovered the laws governing the interaction between electrical and magnetic fields in the middle of the 19th century. One of the consequences of these laws is electromagnetic waves propagating at the speed ##c##. Googling for “Maxwell laws radiation” will find many explanations, although you will need a bit of experience with partial differential equations and vector calculus to follow along in his footsteps.Jeff Root said:How was it discovered that electromagnetic radiation is electromagnetic?
It's a "quacks like a duck" thing, isn't it? You have a theoretical prediction that there are waves of a certain speed and a physical phenomenon with about that speed. We will certainly consider the possibility that these facts are unrelated, but the idea that they are the same is a sensible starting point. In this case it turned out to be right as well. If it hadn't been (e.g. if Maxwell had been studying gravity and derived gravitational waves, which also move at ##c##), eliminating the possibility would probably have turned up evidence towards what was really going on.Jeff Root said:Was there anything about light that suggested to him that it might be electric and/or magnetic in nature?
Mentors sometimes edit the level. I suspect they don't think there's anything in the basic facts of the history of electromagnetism that's likely to need undergraduate knowledge of physics.Jeff Root said:I thought I set the "level" for this thread to "Intermediate" as
the first step in posting, but I see that it is now set to "Basic".
That's what happened here. We'll often adjust the thread level after the fact so that it tells future visitors (who are the real audience for many threads - just compare the view counts to the post counts) what to expect when Google or other investigation brings them to the thread.Ibix said:Mentors sometimes edit the level. I suspect they don't think there's anything in the basic facts of the history of electromagnetism that's likely to need undergraduate knowledge of physics..
I think Maxwell based it solely on the speed calculation. Read what he wrote in his paper “On physical lines of force”. Imagine how he must have felt when he had this flash of insight.Jeff Root said:So it appears that the answer is that Maxwell calculated that
something "electromagnetic" (since it consisted of intertwined
electric and magnetic characteristics) should have a speed very
close to the previously-measured speed of light, and therefore
guessed that this predicted thing might actually BE light.
Did he also base that guess on any other known properties of
light besides its speed? Was there anything about light that
nature? Sure, electric sparks produce light, but so do flames,
which are not obviously electric or magnetic. Did he have any
reason to think that infrared or ultraviolet light might have
electric and/or magnetic characteristics before he worked out
the laws of electromagnetism?
They’re inseparable. You write down the differential equation and solve it; the solution is waves traveling at speed ##c##.Jeff Root said:Which did Maxwell derive first: the waveform or the speed?
Are you familiar with solutions of differential equations? Guessing the form of the solution from the structure of the equations is almost universal.Jeff Root said:He might have guessed that he was working out an equation to
describe light even before he saw that it would result in a wave
or knew what speed it gave.
The wave equation is a partial differential equation that may constrain some scalar function u = u (x1, x2, …, xn; t) of a time variable t and one or more spatial variables x1, x2, … xn. The quantity u may be, for example, the pressure in a liquid or gas, or the displacement, along some specific direction, of the particles of a vibrating solid away from their resting positions. The equation is
where c is a fixed non-negative real coefficient.
Using the notations of Newtonian mechanics and vector calculus, the wave equation can be written more compactly as
Yes. It’s just the well-known wave equation ##\frac{\partial^2E}{\partial x^2}=\frac{1}{c^2}\frac{\partial^2 E}{\partial t^2}## for a wave propagating in the ##x## direction with speed ##c## (although I have simplified it to avoid using the notation of vector calculus).Jeff Root said:Inseparable but probably not simultaneous. Could Maxwell tell
from the form of the equation alone that the solution is a wave?
No, the two are inseparable. Look at the solution again: ##\sin(\omega t - kx)##.Jeff Root said:So Maxwell probably knew that his equation describes a wave
before he used it to find the value of c.
Well maybe a few seconds or minutes apart. Maxwell first saw that his 4 equations combined lead to the wave equation (which is known to mathematicians since Leonard Euler discover it at 1750s) and then its a matter of doing some simple secondary calculation to determine the speed of the wave.Jeff Root said:So the moment he saw that the equation predicts a wave,
he also saw that it predicts a speed of 300,000 km/s.
Not hours apart, not minutes apart, not even seconds apart.
Simultaneously.
Can you explain how that works? It makes no sense to me.
anorlunda said:It is possible that someone noticed that permitivity and permeability of free space (which can be measured independently with no reference to light) can be combined to make the speed of light, before Maxwell worked out his equations
Yes. Yes.Jeff Root said:But I want to be sure: Maxwell's equation explicitly
predicts sine waves? And light has been observed to
have the form of sine waves, not some other kind of
waves or pulses?
Yes. The wave equation is ##\frac{\partial^2E}{\partial x^2}=\frac{1}{c^2}\frac{\partial^2 E}{\partial t^2}## and it is trivial to verify that the solutions are sinusoidal waves. (But note that "trivial" does not mean that you shouldn't try it for yourself! I suggested one form of the sinusoidal solution in a previous posts).Jeff Root said:But I want to be sure: Maxwell's equation explicitly
The wave equation is linear, meaning that if ##A## and ##B## are both sinusoidal wave solutions with different frequencies and wavelengths, then their linear combinations ##\alpha A+\beta B## where ##\alpha## and ##\beta## are arbitrary constants will also be a solution (but don't take my word for it! Try it for yourself!). It also turns out that any waveform traveling at speed ##c## can be written as a sum of these sinusoids at various frequencies (google for "Fourier analysis") so when we've successfully predicted sinusoidal solutions we've predicted all the waveforms.And light has been observed to
waves or pulses? Not square waves or sawtooth waves
or whatever else might be imagined as an alternative?
As @anorlunda says above, monochromatic light has been shown to be sinusoidal and there's not a lot of room for doubt here. At lower frequencies, we can observe the waveforms with an oscilloscope and see the sine wave directly on the screen.So that when electromagnetic radiation is depicted in a diagram as a sine wave, the sine wave shape has not
been chosen just because it looks pretty or is easy to draw, but because it accurately represents some features of the radiation...the sine wave shape correctly graphs how the fields vary in strength as the radiation moves through space?
yes, but it is still EM radiation and obeys the same lawsJeff Root said:Lower frequencies would be radio.
Jeff Root said:If it is sinusoidal, isn't that purely because
it was designed and made to be sinusoidal by the physical size of
the resonating chamber or electrical circuit?
Jeff Root said:As far as I know, radio waves can only be detected in very large numbers
Jeff Root said:Can the waveforms of natural radio sources be observed?
again … of course they can, just like any other RF source …. I really don't see what your problem is ??Jeff Root said:When I ask whether the waveforms of natural radio
sources can be observed, I am not asking whether the
radio emissions can be detected and observed-- of course
they are all the time. I am asking whether the shape of
the individual waveforms can be observed.
anorlunda said:Haven't you beaten this horse to death yet.
Yes. Both questions were raised by Nugatory in post #24, where he said:Ibix said:@Jeff Root - my interpretation of your #27 is that
you seem to be asking two different questions. One is, can you see the
EM field of a single RF photon, and is it sinusoidal? The other is, if you
have a broad-spectrum signal, can you see the sine waves making it up?
The role of theory here is complex and interesting, but I want to cutIbix said:The first you'd have to ask of someone who understands quantum field
theory. Maxwell's equations are classical and only describe classical waves.
I agree that "parts of a photon" cannot be detected. That is why I questionIbix said:My guess would be that the question doesn't make sense - you'd have to be
able to detect parts of a photon and the point of quanta is that you can't do that.
Can you explain how that is possible? With an incoherent light source, evenIbix said:The second is a yes, to arbitrary precision given a narrow enough bandpass
filter and a bright enough source. You simply filter out everything except an
arbitrarily narrow frequency band and, the narrower the bandpass the nearer
a pure sine wave you'll pass through.
No, I was referring to the single waveform that is all we're ever working with, whether it's electromagnetic radiation or any of the many other phenomena desribed by the wave equation. I'm not sure where you're getting the idea that the signal contains a large number of waves, whether coherent or not, or that a single quantum is a single wave.Jeff Root said:This was surprising to me, so I thought I may have misunderstood what he
meant. He may have been referring to observation of the waveforms of very
large numbers of coherent radio waves, rather than of a "single radio wave",
a single quantum of radio-frequency electromagnetic radiation.
Your expectation is wrong. Many posts back I suggested that you google for "Fourier analysis"; this will explain how it doesn't work the way you're expecting.Can you explain how that is possible? ... I'd expect the waveform...
You can write any wave as a sum of sine waves (decomposing an arbitrary wave into a sum of sine waves is what the Fourier transform does). Asking whether classical electromagnetic radiation is "actually" sine waves is a bit like asking whether three is "actually" two plus one. You can certainly represent it that way if you wish.Jeff Root said:The fundamental question I have is whether electromagnetic radiation in
general actually has sinusoidal waveform. I believe it does, but that belief
may be based on stories to children. There is certainly some truth to it.
I'm trying to find out how much, from people who know the adult story.
