Stephen10523
- 2
Find parametric equations of a line that intersect both L1 and L2 at right angles.
L1: [x,y,z]=[4,8,-1] + t[2,3,-4] L2: (x-7)/-6 = (y-2)/1 = (z+1)/2
Symmetric, parametric, cross product
We used cross product to find the direction vector, which was [1,2,2]. To finish the parametric equation, we need at least one of the points that this vector intersects the two lines (which are skewed).
One attempt was setting the two line's parametric equations equal to each other to isolate the t or s, and using this to find the x-, y- and z-value, this should not be possible though because the lines are skewed -- the t and s should not be equal to each other... But the numbers do satisfy each other (but not the back of the book -- the books example answer of a point (2,5,3) does not work).
We then tried taking the 's' we found, and put it into the parametric equations set to each other, to find the 't' at the set 's'. This resulted in -3/10, -1, -3/10. We then used these 't' values to find the x-, y- and z- values, and eventually make a parametric equation. This also does not work when we check it.
