The equation of a roller coaster loop
In summary, the equation for a clothoid loop is given by Etot = \frac{m}{2}v2 + mgh, where v02 - 2gh is the velocity at the base of the loop. r is found in terms of theta, and H is the maximum height of the loop.
Whiteblooded
Hi everyone.
I was wondering about the equation of a roller coaster loop. Most people do not realize this, but a roller coaster loop is not a circle.. but rather a 'clothoid loop' shape.. the reason for this being, with a circular loop, the 'G force' varies quite a lot, and is uncomfortable to the rider. The clothoid loop shape gives more of a normal distribution function for G force, where G force is highest at the top of the loop. I'm trying to derive an equation for this shape.
I was originally trying to model a roller coaster car as a point mass, where the velocity is given by:
Etot = [tex]\frac{m}{2}[/tex]v2 + mgh = [tex]\frac{m}{2}[/tex]v02
v2 = v02 - 2gh
Where h is the height (a variable) from the base of the loop, and v0 is the velocity at the base of the loop.
Then one would put this into the centrepital force equatioon to give:
F = [tex]\frac{m}{r}[/tex]v2 = [tex]\frac{m}{r}[/tex] (v02 - 2gh)
Idealy, I'd like to get an equation for r in terms of the angle around the loop. To do this, I need to find h in terms of r and theta. (I think this is where everything went wrong) The value I got for h was:
h = H/2 - rcos([tex]\theta[/tex])
Where [tex]\theta[/tex] is the angle from the vertical axis of symmetry, starting at the bottom of the loop, sweeping through to the top. H is the maximum height of the loop. My value for h clearly isn't correct, because it assumes the radius always comes from the centre (H/2) of the loop.
Then when I get this value of h, I'm not sure where to go.. the idea that I have in my head would be to somehow make this force equal to a normal distribution of the form:
A*exp{-Bx2} (Where A and B are some constants/scale factors and x is a variable.. which will be a form of theta).
Then I'd try and equate that with the centrepital force as shown above, and (attempt to) rearrange for r.
Can anyone help me out with this? I've looked all over the web for the solution to this problem. http://physics.gu.se/LISEBERG/eng/loop_pe.html" Has some quite useful things on.. but it seems to skip over a lot of the mathematics and doesn't really explain it very well.
I've decided to resign from this project lol..
I believe to fully acquire an equation for these shapes, you have to know about frensel integrals... which I haven't studied yet.
That Clothoid curve is interesting and its relevance to early and modern railway track layout. It must also explain how some car drivers manage to give their passengers a more pleasant ride than others - and they haven't even heard of the Physics involved (I hadn't!).
Also I was thinking some drivers might exploit a similar principle in the choice of racing lines. Very interesting topic.
FAQ: The equation of a roller coaster loop
What is the equation of a roller coaster loop?
The equation of a roller coaster loop is a mathematical representation of the shape of the loop. It is typically a function of height and distance, and can vary depending on the specific design of the loop.
What factors influence the equation of a roller coaster loop?
The factors that influence the equation of a roller coaster loop include the height and shape of the loop, the speed of the coaster, and the force of gravity. Other factors such as friction and air resistance may also play a role.
Can the equation of a roller coaster loop be simplified?
Yes, the equation of a roller coaster loop can be simplified by assuming certain ideal conditions, such as a frictionless track and a constant speed throughout the loop. However, these simplifications may not accurately reflect the real-world experience of riding a roller coaster.
Is there a universal equation for all roller coaster loops?
No, there is not a universal equation for all roller coaster loops. Each loop is designed differently and may have a unique equation based on its specific dimensions and other factors.
How is the equation of a roller coaster loop used in the design process?
The equation of a roller coaster loop is an important tool in the design process, as it helps engineers and designers determine the necessary height, speed, and other factors to ensure a safe and thrilling ride. It also allows them to test and modify different designs to create the most exciting and efficient loop possible.
