MHB The Euler Maclaurin summation formula and the Riemann zeta function
The Euler-Maclaurin summation formula provides a method to approximate the sum of a function's values at discrete points using integrals and derivatives. It is expressed in terms of Bernoulli numbers and polynomials, allowing for the evaluation of sums like the Riemann zeta function. By applying this formula to the series sum of k raised to the power of -s, it establishes a relationship between the zeta function and its derivatives. Specifically, it shows that the derivative of the zeta function at -1 can be expressed in terms of the Glaisher-Kinkelin constant. This connection highlights the interplay between summation techniques and analytic number theory.
polygamma
The Euler-Maclaurin summation formula and the Riemann zeta function
The Euler-Maclaurin summation formula states that if $f(x)$ has $(2p+1)$ continuous derivatives on the interval $[m,n]$ (where $m$ and $n$ are natural numbers), then
$$ \sum_{k=m}^{n-1} f(k) = \int_{m}^{n} f(x) \ dx - \frac{1}{2} \Big( f(n)-f(m) \Big) + \sum_{j=1}^{p} \frac{B_{2j}}{(2j)!} \Big( f^{(2j-1)}(n) - f^{(2j-1)} (m) \Big)$$
$$ + \frac{1}{(2p+1)!}\int_{m}^{n} B_{2p+1}(x-\lfloor x \rfloor ) f^{(2p+1)}(x) \ dx $$
where $B_{j}$ are the Bernoulli numbers and $B_{j}(x)$ are the Bernoulli polynomials.
You can derive the formula by first repeatedly integrating $ \displaystyle \int_{0}^{1} f(x) \ dx = \int_{0}^{1} B_{0}(x) f(x) \ dx$ by parts. Then replace $f(x)$ with $f(x+k)$ and sum both sides of equation from $m$ to $n-1$.By applying the Euler Macluarin summation formula to $ \displaystyle \sum_{k=n}^{\infty} {k^{-s}}$ show that for $\text{Re}(s) > -3$, $$ \zeta(s) = \lim_{n \to \infty} \left( \sum_{k=1}^{n} k^{-s} - \frac{n^{1-s}}{1-s} - \frac{n^{-s}}{2} + \frac{s n^{-s-1}}{12} \right) . $$Then use the representation to show that $ \displaystyle \zeta'(-1) = \frac{1}{12} - \log A$ where $A$ is the Glaisher-Kinkelin constant given by
$$A = \lim_{n \to \infty} \frac{\prod_{k=1}^{n} k^{k}}{n^{n^{2}+n/2+1/12} e^{-n^{2}/4}} . $$
Mathematics news on Phys.org
$$ \sum_{k=m}^{\infty} k^{-s} = \zeta(s) - \sum_{k=1}^{m-1} k^{-s} = \zeta(s) - \sum_{k=0}^{m} k^{-s} + m^{-s} $$
$$ = \int_{m}^{\infty} x^{-s} \ dx - \frac{1}{2} \Big( 0 - m^{-s} \Big) + \frac{1/6}{2!} \Big( 0 - sm^{-s-1} \Big) - \frac{s(s+1)(s+2)}{3!}\int_{m}^{\infty} B_{3}(x-\lfloor x \rfloor ) x^{-s-3} \ dx$$
$$ = \frac{m^{1-s}}{s-1} + \frac{m^{-s}}{2} + \frac{sm^{-s-1}}{12} - \frac{s(s+1)(s+2)}{3!}\int_{m}^{\infty} B_{3}(x-\lfloor x \rfloor ) x^{-s-3} \ dx$$
$$ \implies \zeta(s) = \sum_{k=1}^{m} k^{-s} + \frac{m^{1-s}}{s-1} - \frac{m^{-s}}{2} + \frac{sm^{-s-1}}{12} - \frac{s(s+1)(s+2)}{3!}\int_{m}^{\infty} B_{3}(x-\lfloor x \rfloor ) x^{-s-3} \ dx $$
If $\text{Re}(s) >-3$, the remainder goes to zero as $m$ goes to $\infty$. This is due to the oscillatory nature of $B_{3}(x - \lfloor x \rfloor)$. But at the very least it goes to zero for $\text{Re} (s) > -2$.
So
$$ \lim_{m \to \infty} \zeta(s) = \zeta(s) = \lim_{m \to \infty} \Big( \sum_{k=1}^{m} k^{-s} - \frac{m^{1-s}}{1-s} - \frac{m^{-s}}{2} + \frac{sm^{-s-1}}{12} \Big)$$Then assuming it is OK to differentiate inside of the limit,
$$\zeta'(s) = \lim_{m \to \infty} \Bigg(- \sum_{k=1}^{m} k^{-s} \log k - \frac{-m^{1-s} (1-s) \log m +m^{1-s}}{(1-s)^{2}} + \frac{m^{-s} \log m}{2} $$
$$ + \frac{1}{12} \left(m^{-s-1}- sm^{-s-1} \log m \right) \Bigg) $$
$$ \implies \zeta'(-1) = \lim_{m \to \infty} \Bigg( - \sum_{k=1}^{m} k \log k - \frac{-2m^{2} \log m + m^{2}}{4} + \frac{m \log m}{2} + \frac{1}{12} + \frac{ \log m}{12} \Bigg)$$
$$ = \lim_{m \to \infty} \Bigg( - \sum_{k=1}^{m} k \log k + \Big(\frac{m^{2}}{2} + \frac{m}{2} + \frac{1}{12} \Big) \log m -\frac{m^{2}}{4} + \frac{1}{12} \Bigg)$$
$$ = - \lim_{m \to \infty} \Bigg( \sum_{k=1}^{m} k \log k - \Big(\frac{m^{2}}{2}+\frac{m}{2} + \frac{1}{12} \Big) \log m + \frac{m^{2}}{4} \Bigg) + \frac{1}{12} = - \log A + \frac{1}{12}$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
