The exact reading of a text (fortran 90)
  • Fortran
  • Thread starter hodei_cloud
  • Tags
    Reading Text
In summary, gsal's code "nearly works", except it can't tell you when the last character(s) in a line really were blank characters that were stored on the disk. For many purposes that doesn't matter, but it's not telling you exactly what was on the disk file. It also depends on knowing the maximum length of any line in the file. If the character string is too short to hold the whole line, you won't get any error messages.
hodei_cloud
Hello everyone,
I am making an RSA algorithm (cryptography) with my little knowledge and I am having serious problems with the reading of the text.
I am making it with a simple text reading (no raw format) and the main problem is the length of each line.
For example in this text:
___________________________________
Hello world, I'm doing a text to show you
an easy example
the first line has 42 characters, the second 0 and the third 16.
What I normally do it's making all the lines of length 42 for example (m=42) and read it with a string per line or with a matrix (character type).
Like this
Code:
do i=1,n !n-->lines,(i know how to read all the lines but no the lenght)
  read(unit="whatever",fmt="(42a1)"),(x(i,j),j=1,m)
enddo
But the problems is that the matrix has a lot of "spaces" characters that I don't want to read! (the right spaces, no all the spaces)
I am trying to do like a matrix with a "flexible" length or something (dont know if exists) to read each line exactly
If you can't help me this way, can you help me with a good link to learn how the raw read/write works? (i suppose that this would help me, maybe I'm wrong too)
Technology news on Phys.org
The first thing to remember is that, when reading in Fortran, commans and blankspaces act as value separators. So, in order to read and entire string (including blankspaces) as a single value and into a single variable, you need to specify the format and tell it to read all 40, 80 characters or whatever widest row you may have...and your string variable needs to be just as wide.
The best thing is to read entire lines at a time and let Fortran figure that for you (i.e., where the lines end); then, you come back and inspect the line and figure out how wide it really is.
Here is a program that reads lines of variable lengths and populates your matrix.
Code:
program rrr
    integer, parameter :: nrows = 3, ncols = 45
    character(len=20) :: fmt
    character(len=ncols) :: line
    character, dimension(nrows,ncols) :: x
    write(fmt,*) "(a", ncols, ")"
    x = ''
    do i = 1,nrows
        read(*,fmt) line
        do j = 1, len_trim(line)
            x(i,j) = line(j:j)
        end do
    end do
    write(*,*) "x = "
    do i = 1,nrows
        write(*,*) (x(i,j),j=1,ncols)
    end do
end program rrr
but I am not 100% sure of what you want to achieve...whether you would be happy with an arrays of strings or a matrix of characters or what.
In any case, I hope the program above gives you a couple of hints (and tricks) on how to about it.
gsal
Likes 1 person
If you want to read exactly what is on the disk file, the only option in Fortran 90 is to open the file for unformatted random access with a record length of 1 character, and then you can read one character at a time.
There is a slightly nicer option in Fortran 2008 using "stream I/O", which just treats the file as a string of characters and ignores the ends of the lines. Some compilers (e.g. GNU gforrtran) have that option even though they are don't support all of Fortran 2008.
These solutions are operating system dependent, because different systems represent "end of line" in different ways on the disk. Linux uses one character, but Windows uses two.
The best OS-indepedent way is to use a C routine to read the data instead of Fortran. Many Fortan compilers have a non-standard built in function called GETC or FGETC which calls the corresponding C library routine.
Likes 1 person
Thank you, both of you. Your answers are very helpful !
The problem with the solution of gsal is that when writing the matrix, all the matrix columns have the same lines, and also the backspace character. This makes my program very slow (makes the cryptography operation with each character), but thanks to your answer, I realized that I do not need to read all the text in a row, but per lines and with the "len_trim" that you write.
On the other hand, the answer of AlephZero clear my mind about all the info I search in the internet about this matter. I did not knew the difference of "unformatted" and "I/O stream". I think that this solution would be the best, talking about cryptography, but it is a little out of my hands, so I would try what I say earlier.
Sorry that my solution cannot be perfect; after all, I do not know exactly what you are trying to do.
In any case, I am not sure if you figured it out or not, but the way I typically work is with standard input and standard output...my program, as-is, works just fine if run with input re-direction:
Code:
rrr.exe < input.file
The writing of the matrix is correct, too...did you run my entire program as-is, with input re-direction? or did you try to incorporate stuff into your version? If your program is not working correct, maybe your should post the entire source and let us take at look at it.
Or whatever...I think by now you probably know better how to go about it.
No, no, your program works really fine!
But I mean that in my program I use an old text and make a difficult operation with each character to form another text. With the program you write the output is in the screen, making it imposible for me. And I try to modify to make the output in a text, but the matrix "X" maintains the backspaces (in the new text).
But your program really is fine. I know that I did not ask the question with all my conditions from the beginning, but I was a mess before I write in this post. I was asking something (not exactly) to hear the answers and see if it could help me and they really help me. Thanks.
I don't know Fortran beyond 90.
And I don't know cryptography...are you trying to encrypt a file? I presume that for encrypting a file, you really need to process the entire file in one shot? Correct? 'cause if encryption happens one line at a time, it could easily be reverse engineered?
In any case, I presume that if we were using tcl, python, perl or stuff like that, the first thing that one would do is to read the entire file into single string...so, to that end, AlephZero recommendation sounds good, if you can go beyond Fortran 90.
In ANY case, I don't quite understand your statement when you say "all the matrix columns have the same lines, and also the backspace character"...do you mean to say, all the rows have the same number of columns? Even if they are empty? ("backspace"-> blank space?).
If that is the case...well, yeah, a matrix is a matrix and it is typically of rectangular shape...if not being stored via some sparse technique.
If you would like to use some kind of matrix, where the rows (lines of text) are NOT the same length and possibly zero length when empty, then, you need what is typically referred to as "ragged" matrix.
Immediately, two choices come to mind:
1) an array of variable length character strings.
2) an array of variable length character arrays.
Because your original intent of using a matrix, I implement choice 2), above, in the program below; it uses a custom type definition and a pointer.
Code:
program rrr
    integer, parameter :: nmax = 2000, ncols = 150
    type array
        character, dimension(:), pointer :: x
    end type array
    type(array), dimension(nmax) :: ragged
    integer :: i, n, ios
    nrows = 0
    do
        read(*,fmt,iostat=ios) line
        if (ios /= 0) exit
        if (len_trim(line) == 0) then
!            nrows = nrows+1
!            allocate( ragged(nrows)%x(1) )
!            ragged(nrows)%x(1) = ""
        else
            nrows = nrows+1
            allocate( ragged(nrows)%x(len_trim(line)) )
                ragged(nrows)%x(j) = line(j:j)
            end do
        end if
    end do
    do i = 1,nrows
        write(*,'("Row #",i2," is",i3," characters long")') i, size(ragged(i)%x,dim=1)
    end do
    write(*,*)
    write(*,*) "============================================"
    write(*,*) "Replicating, x = "
    do i = 1,nrows
        write(*,*) (ragged(i)%x(j), j=1, size(ragged(i)%x,dim=1) )
    end do
end program rrr
I increased the parameters to allow for the widest line in the file to be 150 characters and the total number of lines in the file of 2000...but this is only because I am using re-direction; if you do not use re-direction and instead actually open the file inside the code, you can open the file, count the number of line, close it, allocate memory, re-open file, read it...you get the point.
The code as shown ignores blank lines; un-comment those 3 lines and it puts them back as length 1 with the empty character in them.
Hello, sorry for asking again, but I have a problem with the tip gsal gave me.
I make a program that takes a text and makes an output of numbers (exactly with the length of the characters) like that
Code:
!to read the number of lines in the text
open(unit=111,file="text.txt",action="read",status="old")
nrows=0
   do
     read(unit=111,fmt="(1a)",iostat=s) line
     if (s<0) then
       exit
     endif
     nrows=nrows+1
   enddo
close(unit=111)
open(unit=112,file="cyber.txt",action="write",status="replace")
ncols=1000
allocate (x(ncols),x1(cols),y(ncols))
   do i=1,nrows
     read(unit=111,fmt="(a1000)"),line
     do j=1,len_trim(line)
       x(j)=line(j:j)
       x1(j)=ichar(x(j))
       call encrypt(x1(j),E,N1,y(j))   !-->make a operation to transform into another number (y)
     enddo
     write(unit=112,fmt="(1000i10)"),(y(j),j=1,len_trim(line))
   enddo
deallocate (x,x1,y)
close(unit=111)
close(unit=112)
This works perfectly fine and makes a text with the format "(1000i10)" (if you want to see, I put it like attachment)
But the problem is later reading the text of numbers, I read it like this:
Code:
!some definitions
integer,dimension(:),allocatable::x1,y1
character(len=1),dimension(:),allocatable::x
!to read the number of lines again
nrows=0
   do
     if (s<0) then
       exit
     endif
     nrows=nrows+1
   enddo
close(unit=111)
open(unit=111,file="cyber.txt",action="read",status="old")
open(unit=112,file="new_text.txt",action="write",status="replace")
allocate(x(cols),x1(cols),y(cols))
 do i=1,nrows
     read(unit=111,fmt="(a10000)"),line  !--> make it with 10000, because the for each character,
                                                         !     makes 10 numbers (or spaces)
    do j=1,len_trim(line)/10                    !-->for the same reason
        read(unit=111,fmt="(1000i10)"),y(j)
        call decrypt(y(j),P,Q,D,x1(j))         !--> makes an operation with number y to became another number
        x(j)=achar(x1(j))
     enddo
     write(unit=112,fmt="(a1000)"),(x(j),j=1,len_trim(line))
   enddo
close(unit=111)
close(unit=112)
deallocate(x,x1,y)
It gives me the error of
"Traceback: not available, compile with -ftrace=frame or -ftrace=full
Fortran runtime error: End of file"
but i don't know why its the end of file before it makes all. I try to put iostat to see where its the problem, and it seems that it is in "i=1", the first try?!?
I know it is a lot to see, if you can't help me, I understand, it is my duty after all XD.
  • cyber.txt
In your first piece of source code, above, I noticed:
  • I don't see where you declare x, x1, y
  • the first do-loop, determines nrows. Yet, you do not seem to make any kind of allocation based on nrows; that means, there is no need to open the file, read, close...may as well just read it once until the end of file.
  • the allocate line seems to have a typo...allocate (x(ncols),x1(cols),y(ncols))...is cols (without the n) defined before? is it non-zero?
  • the second loop ignores blank lines...hope you are doing that on purpose.
In your second piece of source code:
  • at the top, you declare x1 and y1, but I don't see where you declare y...which you later allocate
Other than that, I don't have your entire program (and workflow) to carry out any kind of testing and debugging of my own.
Likes 1 person
Sorry about that, I was trying to explain a little bit (because my program isn't in english) and I make a few mistakes. I attach the real program (I added some explanations with the ! simbol). But maybe its too long to read.
Thanks for the help
In the meantime, I will see if I can do something regarding your suggestions
I compile it with g95 like this
g95 -o rsa5.x big_integer_module.f95 rsa5.f95
  • rsa5.txt
  • big_integer_module.txt
Regarding your answer, the second loop ignores the blank lines? its not the same as the first? I don't see the difference...
The difference is that the second look has an inner loop "j=1,len_trim(line)" which will not be executed if the line is empty or made up of blank spaces. Thankfully, the write statement that follows does not execute, either, as the implied loop had the same limits...otherwise, you would have been writing the previous y.
compiled the program...running it with 1 to create keys...it is not working...it looks like the key_generator call just does not return as I am never asked for the number to encrypt the file...
...or attache a couple of private and public keys for me.
hhhmmm...it looks like I was able to compile the program and able to run it and encode a message.
But, I had to change a couple of things.
First, because it was getting stuck while generating keys, I moved the random_seed() call out of the "prime_number_aurkite()" subroutine and placed it at the top of the main program so that it only gets called once per run...otherwise, because it was being called without arguments, I think it might have been generating the same number every time and generating the same Pand Q and never getting out of the loop.
Also, I did not like that in your sub "prime_number_aurkite()", you are allocating Y(N), which defines Y as an array with items from 1:N...but next you do: Y(0)=3! In other words, you assign to index 0 (zero).
After I was able to create keys and encrypt a file, I was not able to unencrypt...
first thing was that I got an end-of-file error, which I think it is because you try to read twice as many times from the file...
shoudln't your code
Code:
   do i=1,n
       read([COLOR="Red"][b]unit=111[/b][/COLOR],fmt="(1000i10)"),y(j)
       x(j)=achar(x1(j))
     enddo
   enddo
say
Code:
   do i=1,n
       read([COLOR="Red"][b]line[/b][/color],fmt="(1000i10)"),y(j)
       x(j)=achar(x1(j))
     enddo
   enddo
Anyway, that's where I am...and can't unencrypt the encrypted code...the program terminates, but the output file is very large and does not have much.
Anyways, thanks for all your help.
I was compiling the program in a docfis server, and in this server the program runs always good, but sometimes not in my private computer. So maybe that is way you couldn't run it in the first attempt.
I will try to see if I can do more, and I am also searching like you said before about the I/O stream.
dont know why, but it reads the first number x m (m times) where m=columns
I think its done, if that's the problem of all the program I will let you know
Finally! The only change I made is in the part that make the error, I made some changes to make the paragraphs characters (like you said) and the problem I mention about the bad reading. Like this:
Code:
   do i=1,n
     read(unit=111,fmt="(a10000)"),line1
    if (len_trim(line1)/=0) then
     read(line1,fmt="(1000i10)"),(y(j),j=1,len_trim(line1)/10)
     do j=1,len_trim(line1)/10
       x(j)=achar(x1(j))
     enddo
     write(unit=112,fmt="(1000a)"),(x(j),j=1,len_trim(line1)/10)
    else if (len_trim(line1)==0) then
     write(unit=112,fmt="(1a)"),''
    endif
   enddo
The only important change I made was that the
Code:
  read(line,fmt="(1000i10)"),y(j)
enddo
that i write it like this
Code:
read(line,fmt="(1000i10)"),(y(j),j=1,len_trim(line))
About the reverse engineering you mention, why is that? what is the difference between reading all in one and like me with each line?
I see the problem...in the read statements.
Here is a shortcut...forget about reading the line as text first and THEN trying to read integers out of it...in this case, it is simpler to read all integers in one shot into the integer array and be done with it.
Inside the clause "else if (zenbakia==3) then", this is what the do-loop that works for me looks like
Code:
   do i=1,n
     read(111,'(1000i10)' ) y
     k = 1
     do while (y(k) > 0)
       call decrypt(y(k),P,Q,D,x1(k))
       x(k)=achar(x1(k))
       write(112,'(a1,$)') x(k)
       k = k + 1
     end do
     write(112,*)
   enddo
I can now unencrypt the encrypted file...how do you say it anyway? Unencrypt? Uncrypt? Decrypt?
Anyway...that's my solution.
gsal
missed you for 2 minutes...saw your solution...I like mine better ;-) ...so much briefer, no divide by 10 or anything like that...
Related to The exact reading of a text (fortran 90)
1. What is "The exact reading of a text" in fortran 90?
"The exact reading of a text" in fortran 90 refers to the process of reading and interpreting a text file in the fortran 90 programming language. This involves using specific commands and functions to extract and manipulate data from the text file.
2. Why is the exact reading of a text important in fortran 90?
The exact reading of a text is important in fortran 90 as it allows for efficient and accurate processing of data from text files. This is essential for many scientific and engineering applications, where large amounts of data need to be analyzed and manipulated.
3. What are the main commands used for exact reading of a text in fortran 90?
The main commands used for exact reading of a text in fortran 90 are "open", "read", "close", and "endfile". These commands allow the program to open a text file, read data from it, close the file, and determine when the end of the file has been reached.
4. How can I ensure the accuracy of the exact reading of a text in fortran 90?
To ensure the accuracy of the exact reading of a text in fortran 90, it is important to carefully define and format the input file. This includes using the correct data types and delimiters to ensure the data is read correctly. Additionally, thorough testing and debugging of the program can help identify and fix any errors.
5. Are there any limitations to the exact reading of a text in fortran 90?
There are some limitations to the exact reading of a text in fortran 90. For example, the program may have difficulty reading large or complex text files, or files with inconsistent formatting. Additionally, the program may not be able to handle unexpected data or errors in the input file.
10K
