MHB The exact value of cos(θ) in the form of p/q
  • Thread starter Thread starter karush
    Form Value
The discussion focuses on determining the value of cos(θ) in the context of a triangle OAB, where the length OC is needed to calculate cos(θ) as OC/OA. The participants explore methods to find point C, suggesting converting vectors a and b into lines to find their intersection. They also reference the Law of Cosines and vector dot product calculations to derive cos(θ). Ultimately, they confirm that the length of OC is 11.2, leading to the conclusion that cos(θ) equals 56/65.
karush
MHB
calculations and boxed answers are mine
my question is with (iii) (provided the (i) and (ii) are correct.
from the diagram $cos \theta$ would be $\frac{OC}{OA}$ or $\frac{11.2}{13}$
but would need the the length of $OC$ to do so, what would be the best approach to get point $C$
we could convert $a$ and $b$ and to lines and find the intersection at $C$ hence $OC$.
but not sure how this could be done with just vectors
Mathematics news on Phys.org
Re: the exact value of cos theta in the form of p/q
Consider a triangle OAB. You can find the length of AB as you know the position vectors for A and B. Then use the Law of Cosines to find your angle.
-Dan
Use the fact that \displaystyle \begin{align*} \mathbf{a} \cdot \mathbf{b} = |\mathbf{a}||\mathbf{b}|\cos{(\theta)} \end{align*}
Also note that you have evaluate \displaystyle \begin{align*} \mathbf{a}\cdot \mathbf{b} \end{align*} incorrectly.
\displaystyle \begin{align*} \mathbf{a}\cdot \mathbf{b} &= 12 \cdot 6 + 5 \cdot 8 \\ &= 72 + 40 \\ &= 112 \end{align*}
$o^2=a^2+b^2-2ab\ cos\ \theta$
or $\displaystyle\frac{o^2 -a^2-b^2}{-2ab}=cos\ \theta$
plugging in $\displaystyle o=3\sqrt{3}\ a=10\ b=13$ we get $cos\ \theta = \frac{56}{65}$
well easier than finding $OB...$
$\displaystyle\frac{a\cdot b}{10\times 13} = \frac{112}{130}=\frac{56}{65}$
i reduced the fraction..
This may be something along the lines of what you were looking for:
Suppose we write the point $C$ as: $(6t,8t)$.
Clearly the length of $OC$ is $10t$.
The length of $AC$ is: $\sqrt{(8t - 5)^2 + (6t - 12)^2} = \sqrt{100t^2 - 224t + 169}$.
Because we have a right triangle, we know that:
$100t^2 + 100t^2 - 224t + 169 = 169$
$200t^2 - 224t = 0$
$t(25t - 28) = 0$
We can discount the solution $t = 0$, leaving us with $t = \frac{28}{25} = \frac{112}{100} = 1.12$, which establishes that the length of $OC$ is 11.2, as we surmised by the other method.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
