kodama
- 1,075
- 144
- TL;DR Summary
- The role of the Exceptional Jordan Algebra in physics
I found 3 papers on The Exceptional Jordan Algebra in physics
arXiv:2305.00668 (hep-ph)
[Submitted on 1 May 2023]
CKM matrix parameters from an algebra
Aditya Ankur Patel, Tejinder P. Singh
Download PDF
We report a theoretical derivation of the Cabibbo-Kobayashi-Maskawa (CKM) matrix parameters and the accompanying mixing angles. These results are arrived at from the exceptional Jordan algebra applied to quark states, and from expressing flavor eigenstates (i.e. left-chiral states) as superposition of mass eigenstates (i.e. the right-chiral states) weighted by square-root of mass. Flavor mixing for quarks is mediated by the square-root mass eigenstates, and the mass ratios used have been derived in earlier work from a left-right symmetric extension of the standard model. This permits a construction of the CKM matrix from first principles. There exist only four normed division algebras, they can be listed as follows - the real numbers R, the complex numbers C, the quaternions H and the octonions O. The first three algebras are fairly well known; however, octonions as algebra are less studied. Recent research has pointed towards the importance of octonions in the study of high energy physics. Clifford algebras and the standard model are being studied closely. The main advantage of this approach is that the spinor representations of the fundamental fermions can be constructed easily here as the left ideals of the algebra. Also the action of various Spin Groups on these representations too can be studied easily. In this work, we build on some recent advances in the field and try to determine the CKM angles from an algebraic framework. We obtain the mixing angle values as θ12=11.093o,θ13=0.172o,θ23=4.054o. In comparison, the corresponding experimentally measured values for these angles are 13.04o±0.05o,0.201o±0.011o,2.38o±0.06o. The agreement of theory with experiment is likely to improve when running of quark masses is taken into account.
Comments: 35 pages, 8 tables, 4 figures
Subjects: High Energy Physics - Phenomenology (hep-ph)
Cite as: arXiv:2305.00668 [hep-ph]
arXiv:2304.01213 (physics)
[Submitted on 28 Mar 2023]
The exceptional Jordan algebra, and its implications for our understanding of gravitation and the weak force
Tejinder P. Singh
Download PDF
The exceptional Jordan algebra is the algebra of 3×3 Hermitian matrices with octonionic entries. It is the only one from Jordan's algebraic formulation of quantum mechanics which is not equivalent to the conventional formulation of quantum theory. It has often been suggested that this exceptional algebra could explain physical phenomena not currently explained by the conventional approach, such as values of the fundamental constants of the standard model of particle physics, and their relation to gravitation. We show that this is indeed the case; and this also unravels the connection between general relativity and the weak force. The exceptional Jordan algebra also predicts a new U(1) gravitational interaction which modifies general relativity, and which provides a theoretical basis for understanding the Modified Newtonian Dynamics (MOND).
Comments: 12 pages
Subjects: General Physics (physics.gen-ph)
Cite as: arXiv:2304.01213 [physics.gen-ph]
arXiv:2006.16265 (hep-th)
[Submitted on 29 Jun 2020]
The Standard Model, The Exceptional Jordan Algebra, and Triality
Latham Boyle
Download PDF
Jordan, Wigner and von Neumann classified the possible algebras of quantum mechanical observables, and found they fell into 4 "ordinary" families, plus one remarkable outlier: the exceptional Jordan algebra. We point out an intriguing relationship between the complexification of this algebra and the standard model of particle physics, its minimal left-right-symmetric SU(3)×SU(2)L×SU(2)R×U(1) extension, and Spin(10) unification. This suggests a geometric interpretation, where a single generation of standard model fermions is described by the tangent space (C⊗O)2 of the complex octonionic projective plane, and the existence of three generations is related to SO(8) triality.
Comments: 5 pages, 1 figure
Subjects: High Energy Physics - Theory (hep-th); High Energy Physics - Phenomenology (hep-ph); Quantum Physics (quant-ph)
Cite as: arXiv:2006.16265 [hep-th]
once again
the quaternions H and the octonions O Clifford algebras and the standard model are being studied closelycomments
Download PDF
Tejinder P. Singh
Download PDF
Comments: 12 pages
Latham Boyle
Download PDF
once again
