The fifth derivative of arctan(x)
  • Thread starter KiwiKid
  • Tags
    Derivative
In summary: What will also help is to put the whole thing over a common denominator before differentiating again, so before taking the (k+1)th derivative, make sure you write the kth derivative in the form \frac{P_k(x)}{(x^2+1)^k}, where P_k(x) is a polynomial.
KiwiKid
38
Show that the fifth derivative of arctan(x) equals (120x^4 - 240x^2 + 24)/((x^2 + 1)^5). Then, calculate the fifth order Taylor series of arctan(x) around x = 0.
Differentiation rules; knowing how a Taylor series works.
I tried the brute-force way of differrentiating those fractions over and over and over again, resulting in one big mess. My answer ultimately turned out to be something different than what was asked, which isn't particularly surprising, considering the number of calculations I had to perform. I didn't even get to the Taylor series part.
My question is: is there a non-obvious solution to this problem that I'm missing? If so, could anyone give me a hint? I've been stuck on this problem for over an hour now and I'm not exactly fond of the idea of redoing all my previous calculations.
You need to show at least some of your work.
f(x) = arctan(x); The first derivative: f'(x) = 1/(x^2 + 1); Second derivative: f''(x) = -2x/((x^2+1)^2). ...And so on. Except that it's around the third derivative that it starts to get more complicated, and it becomes virtually impossible to keep differentiating without making mistakes. At least, that's what I think, because 'my' fifth derivative of arctan(x) didn't match what I was supposed to get at all.
Writing those as:
f'(x) = (x^2 + 1)-1
and
f''(x) = -2x(x^2+1)-2
May help. You can then use the product rule rather than the quotient rule.
SammyS said:
Writing those as:
f'(x) = (x^2 + 1)-1
and
Wow, thanks. That's probably it. :smile: *starts writing it all down once more*
[tex] \frac{P_k(x)}{(x^2+1)^k},[/tex] where P_k(x) is a polynomial.
FAQ: The fifth derivative of arctan(x)
What is the formula for finding the fifth derivative of arctan(x)?
The formula for finding the fifth derivative of arctan(x) is:
d5/dx5 arctan(x) = 120x/(x2+1)5
How do you simplify the fifth derivative of arctan(x)?
The fifth derivative of arctan(x) can be simplified using the following steps:
1. Rewrite arctan(x) as (1/2)ln((1+x)/(1-x))
2. Use the chain rule to find the derivatives of ln((1+x)/(1-x))
3. Substitute the values into the formula for the fifth derivative of arctan(x)
4. Simplify the resulting expression
What is the significance of the fifth derivative of arctan(x)?
The fifth derivative of arctan(x) represents the rate of change of the fourth derivative of arctan(x). It is used in higher level calculus and physics to analyze the behavior of functions and models.
Can the fifth derivative of arctan(x) be negative?
Yes, the fifth derivative of arctan(x) can be negative. This indicates that the fourth derivative of arctan(x) is decreasing at that point.
How is the fifth derivative of arctan(x) related to other trigonometric functions?
The fifth derivative of arctan(x) is related to other trigonometric functions through the chain rule. It can be used to find the derivatives of other inverse trigonometric functions, such as arcsin(x) and arccos(x).
