The fractional derivative operator
In summary, the conversation discusses the pattern for finding the derivative of a function of various orders. It involves using limits and the binomial theorem. The conversation ends with a discussion on generalizing this pattern to fractional order derivatives, but it is pointed out that this is not possible. The conversation is then closed.
Kumar8434
121
I've been thinking about it since yesterday and have noticed this pattern:
We have, the first order derivative of a function ##f(x)## is:
$$f'(x)=\lim_{h\rightarrow 0}\frac{f(x+h)-f(x)}{h} ...(1)$$
The second order derivative of the same function is:
$$f''(x)=\lim_{h\rightarrow 0}\frac{f'(x+h)-f'(x)}{h}$$
By putting ##x=x+h## in (1), we can have ##f'(x+h)##.
So,$$f''(x)=\lim_{h\rightarrow 0}\frac{\lim_{h\rightarrow 0}\frac{f(x+h+h)-f(x+h)}{h}-\lim_{h\rightarrow 0}\frac{f(x+h)-f(x)}{h}}{h}$$
Or , $$f''(x)=\lim_{h\rightarrow 0}\frac{f(x+2h)-2f(x+h)+f(x)}{h^2}...(2)$$
You can check by L'Hospital's rule that this limit evaluates to ##f''(x)##.
Now, the third order derivative of the same function is:
$$f'''(x)=\lim_{h\rightarrow 0}\frac{f''(x+h)-f''(x)}{h}$$
By putting ##x=x+h## in (2), we can get ##f''(x+h)##.
So, $$f'''(x)=\lim_{h\rightarrow 0}\frac{\lim_{h\rightarrow 0}\frac{f(x+3h)-2f(x+2h)+f(x+h)}{h^2}-\lim_{h\rightarrow 0}\frac{f(x+2h)-2f(x+h)+f(x)}{h^2}}{h}$$
which gives $$f'''(x)=\lim_{h\rightarrow 0} \frac{f(x+3h)-3f(x+2h)+3f(x+h)-f(x)}{h^3}...(3)$$
Again, by repeating the same process, we can get that:
$$f''''(x)=\lim_{h\rightarrow 0}\frac{f(x+4h)-4f(x+3h)+6f(x+2h)-4f(x+h)+f(x)}{h^4}...(4)$$
So, we notice that the coefficient of ##f(x+(n-r)h)## in the expression of ##f^{n}(x)## (##n^{th}## derivative of ##f(x)##) is actually ##(-1)^{r}\cdot {^n}C_r##, same as the coefficient of ##x^{n-r}## in the expansion of ##(x-1)^n##.
It can be proved that:
$$f^n(x)=\lim_{h\rightarrow 0}\frac{\sum_{r=0}^n(-1)^{r}\cdot ^{n}C_r\cdot f(x+(n-r)h)}{h^n}$$
where ##f^n(x)## is the ##n^{th}## order derivative of the function ##f(x)##.
Now, to generalize this to fractional order derivatives, we just have to generalize the coefficients, which must be similar to the generalization of the expansion of ##(x-1)^n## to fractional exponents.
I'm not very good with binomial theorem, but I guess that it should be:
$$f^n(x)=\lim_{h\rightarrow 0}\frac{f(x+nh)-n\cdot f(x+(n-1)h)+\frac{n(n-1)}{2!}\cdot f(x+(n-2)h)-...}{h^n}$$
, where ##n## can be fractional. Have I done anything wrong?
Mathematics news on Phys.org
You can't have a noninteger number of addends.
Try to figure out how it would look for (x^0.5)' or (x^1.5)'. I suspect you won't get very far.
FAQ: The fractional derivative operator
1. What is a fractional derivative operator?
A fractional derivative operator is a mathematical operator that extends the concept of differentiation to non-integer orders. It is denoted by Dα, where α is any real number. It can be thought of as a generalization of the traditional derivative operator, which is only defined for integer orders.
2. How is the fractional derivative operator calculated?
The fractional derivative operator is calculated using the Riemann-Liouville or Caputo definitions. The Riemann-Liouville definition involves evaluating the integral of the function being differentiated, while the Caputo definition involves taking the traditional derivative first and then applying the Riemann-Liouville definition. Both methods yield the same result for functions that are well-behaved.
3. What are the applications of the fractional derivative operator?
The fractional derivative operator has various applications in mathematics and science. It is commonly used in the study of fractional calculus, which has applications in fields such as physics, engineering, and economics. It is also useful in modeling complex systems with memory or non-local effects, such as viscoelastic materials and anomalous diffusion processes.
4. Can the fractional derivative operator be negative or complex?
Yes, the fractional derivative operator can take on negative or complex values. This is because the fractional derivative operator is a generalization of the traditional derivative operator, which can also take on negative or complex values for certain functions. However, the fractional derivative operator may not be well-defined for all negative or complex orders, and its behavior in these cases can be quite different from that of the traditional derivative operator.
5. Are there any limitations or drawbacks to using the fractional derivative operator?
One limitation of the fractional derivative operator is that it is not always well-defined for all functions and orders. In some cases, the fractional derivative may not exist or may not have the desired properties. Additionally, the fractional derivative operator can be quite complex and difficult to work with, making it challenging to apply in certain situations. It also may not have as many established rules and properties as the traditional derivative operator, making it harder to use in calculations and proofs.
