MHB The functions is equal to zero for x=0
  • Thread starter Thread starter evinda
    Functions Zero
evinda
MHB
Hello! (Wave)
We consider the following Cauchy problem
$u_t=u_{xx} \text{ in } (0,T) \times \mathbb{R} \\ u(0,x)=\phi(x) \text{ where } \phi(x)=-\phi(-x), x \in \mathbb{R} $
I want to show that $ u(t,0)=0, \forall t \geq 0 $.
We have the following theorem:
Let $\phi \in C^0(\mathbb{R}^n)$ and bounded. Then
$u(t,x)=\int_{\mathbb{R}^n} \Gamma (t,x-\xi) \phi(\xi)d{\xi} $
is the solution of the problem
$ u_t-\Delta u=0 \text{ in } (0,T) \times \mathbb{R}^n, T>0 \\ u(0,x)=\phi(x), x \in \mathbb{R}^n $.
From this we have that the solution of the given problem is
$ u(t,x)=\int_{\mathbb{R}} \Gamma(t,x-\xi) \phi(\xi) d{\xi}=-\int_{\mathbb{R}} \Gamma(t,x-\xi) \phi(-\xi) d{\xi}=\int_{\mathbb{R}}\Gamma(t,x+u) \phi(u) du$
So we have that $u(t,0)=\int_{\mathbb{R}} \Gamma(t,u) \phi(u)du$.
How can we show that the latter is equal to 0?
Hi evinda,
If I'm not mistaken, $\Gamma(t,u)$ is an even function of $u$. Combining this with the oddness of $\phi(u)$ should do the trick.
Yes, we have that $\Gamma (t, x-\xi)=\frac{1}{2^n [\pi t]^{\frac{n}{2}}} e^{\frac{|x-\xi|^2}{4t}}$.
So we have that
$$u(t,x)=\int_{\mathbb{R}} \Gamma (t,x-\xi) \phi(\xi) d{\xi}$$
For $x=0$: $u(t,0)=\int_{\mathbb{R}} \Gamma (t, -\xi) \phi(\xi) d{\xi}=\int_{\mathbb{R}^n} \Gamma(t,\xi) (-\phi(-\xi)) d{\xi}=-\int_{\mathbb{R}} \Gamma(t,\xi) \phi(\xi) d{\xi}$
So we have that $\int_{\mathbb{R}} \Gamma(t,-\xi) \phi(\xi) d{\xi}=\int_{\mathbb{R}} \Gamma(t,\xi) \phi(\xi) d{\xi}=-\int_{\mathbb{R}} \Gamma(t,\xi) \phi(\xi) d{\xi} \Rightarrow \int_{\mathbb{R}} \Gamma(t,\xi) \phi(\xi) d{\xi}=0$.
Right?
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
