The given function is an even or an odd function?
In summary, the function ##f(x^2)## is an even function and is symmetrical w.r.t. the Y axis, so you can find its value by applying the arbitrary function to the square of the input value.
brochesspro
155
Determine whether the function ##f(x^2)## is an even function, or an odd function, or neither, where ##f(x)## is an arbitrary function.
Given below.
I think the answer is an even function as the function ##x^2## is an even function and thus, is symmetrical w.r.t. Y axis. The question I have is how to do this problem algebraically. I tried to graph some functions on GeoGebra to verify my answer.
a) ##y = ln(x^2)##
b) ##y = sin(x^2)##
These are the two functions I tried, and both look pretty even to me. Please help me solve this problem. Thank you.
Likes Delta2
How is the function ##f(x^2)## defined?
PS how did the computer calculate the function values to draw that graph for you?
The computer first calculates the values of the squares of the input value and applies the arbitrary function to the new value. I know that since the function ##x^2## is an even function and thus, is symmetrical w.r.t. Y axis, the output of the arbitrary function will be even. Eg. ##f((-1)^2) = f(1^2)## as ##(-1)^2 = 1^2 = 1##. I am sure I am correct till here. Are you?
I will see you after two hours.
Exactly. This is called the composition of two functions. Technically, we define a new function ##g(x)## by:$$g(x) = f(x^2)$$And then ##g(x)## is an even function for any function ##f(x)##, as you have shown for ##x = 1##.
But how do I write it formally?
You should directly use the definitions of "even" and "odd" functions. Start with ##g(-x) = f((-x)^2)## and see where that leads you for the function g. Is ##g(x)## even or odd or neither?
##f((-x)^2) = f(x^2)##, for ##x^2## in the domain of f.
Thus ##f(x^2)## is an even function.
  • Love
Likes sysprog and Delta2
Oh, I see. Thank you.
To do it fully formally you have first to define the function $$g(x)=f(x^2)$$ and then prove that $$g(-x)=g(x)$$ and hence g is even. The proof is half a line long, it is essentially what @Mark44 does at post #8.
And precisely what I did in post #5.
Likes Delta2
Thank you for your replies. They mean a lot to me. I solved the problem long ago, so no need to reply to this thread any further.
Likes Delta2
FAQ: The given function is an even or an odd function?
What is an even function?
An even function is a mathematical function where the output values remain unchanged when the input values are replaced with their corresponding negative values. In other words, if f(x) is an even function, then f(x) = f(-x) for all values of x.
What is an odd function?
An odd function is a mathematical function where the output values change sign when the input values are replaced with their corresponding negative values. In other words, if f(x) is an odd function, then f(x) = -f(-x) for all values of x.
How can I determine if a function is even or odd?
To determine if a function is even or odd, you can use the symmetry test. Replace x with -x in the function and if the resulting function is the same as the original function, then it is an even function. If the resulting function is the negative of the original function, then it is an odd function.
What are some examples of even functions?
Examples of even functions include f(x) = x², f(x) = cos(x), and f(x) = |x|. These functions have a symmetry around the y-axis, which means they remain unchanged when the input values are replaced with their corresponding negative values.
What are some examples of odd functions?
Examples of odd functions include f(x) = x³, f(x) = sin(x), and f(x) = tan(x). These functions have a symmetry around the origin, which means their output values change sign when the input values are replaced with their corresponding negative values.
