The graph of a twice-differentiable function
In summary, the problem asks about determining the graph of a twice-differentiable function based on its properties. The first line of the problem contains a typo, which should read as "x < -2, y' > 0." This means that the function is increasing to the left of this point, eliminating options A and B. The distinction between options C and D can then be made based on the values at the extremes.
Fatima Hasan
319
How to determine the graph using the properties of a twice-differentiable function ?
None
when x < 2 , y ' > 0 . So, the function is increasing on this interval. But , the correct answer is ( D) and the function is decreasing when x < 2.
Could somebody help me to solve this problem ?
Thank you for your help
The top line in the problem must be an error. To be consistent with the rest of the problem, it should read x < -2.
Likes Fatima Hasan
None
There must be a typographical error in the question: the first line ##x < 2 \hspace{2em} y'>0, y''<0## should read as ##x < - 2 \hspace{2em} y'>0, y''<0##.
Can you see why the original printed form (with ##x < 2## instead of ##x < -2##) does not make sense?
Likes Fatima Hasan
There is probably a typo in the first line. I think it should be ##x<-2##, because otherwise it would contradict the following conditions. Thus it is increasing left of this point, which excludes A and B. The distinction between C and D is then done by the values at the extremes.
Likes Fatima Hasan
Related to The graph of a twice-differentiable function
1. What is the significance of a twice-differentiable function?
A twice-differentiable function is a function that can be differentiated twice. This means that its graph will have a well-defined curvature, which can provide information about its behavior and rate of change.
2. How can I determine if a function is twice-differentiable?
A function is twice-differentiable if it has continuous derivatives up to the second order. This means that the first and second derivatives must exist and be continuous at every point in the function's domain.
3. What does the graph of a twice-differentiable function look like?
The graph of a twice-differentiable function can have various shapes and forms, depending on the specific function. However, it will always have a smooth and continuous curve with a well-defined curvature.
4. Can a function be twice-differentiable at some points and not at others?
Yes, it is possible for a function to be twice-differentiable at some points and not at others. This can occur if the function has a sharp corner or a discontinuity at a certain point, where its derivatives do not exist.
5. How can the second derivative of a function be used to analyze its behavior?
The second derivative of a function can provide information about the concavity and inflection points of its graph. A positive second derivative indicates a concave-upward curve, while a negative second derivative indicates a concave-downward curve. Inflection points are points where the curvature of the graph changes from concave-upward to concave-downward or vice versa.
