The graph of sin inverse (sin x) after the domain of (- pi/2, pi/2)
In summary, the graph of sin inverse (sin x) between the domain of (-pi/2,pi/2) is y = x, but after it crosses that domain, the expression changes due to the principle value of sin inverse being (-pi/2,pi/2) and its many-to-one nature. The graph of sin inverse (sin x) on different intervals has a sawtooth shape, with the graph of y = x on the interval [-pi/2,pi/2] and a slope of -1 on other intervals. To understand this graph, analysis must be done on each interval.
esha
74
the graph of sin inverse (sin x) between the domain of ( -pi/2,pi/2) is y = x. but after it crosses that domain of course the expression won't be the same anymore because sin inverse has its principle value as ( - pi/2, pi/2) due to sin x many to one natured function. now the way these expressions change is what doesn't seem intuitive to me. can anybody please tell me how to derive those expressions logically?
Mathematics news on Phys.org
No, it isn't. The graphs of the two functions are close together when x is in the interval [-.5, .5], but they aren't identical.
What expression? Are you trying to understand why the graph of ##y = \sin^{-1}(x)## looks the way it looks? Are you asking how the values on this graph are calculated? If you have studied calculus, one of the topics presented later is infinite series. One such series is the expansion for the arcsine function. See https://math.stackexchange.com/questions/197874/maclaurin-expansion-of-arcsin-x.
its not sin inverse graph..
that's pretty straight forward..
. m talking bout sin inverse ( sin x) graph
they are different...
It wasn't clear to me what you were asking about, which is the graph of ##y = \sin^{-1}(\sin(x))##. On the interval ##[-\pi/2, \pi/2]##, the graph of this function is the same as that of y = x, which is what you said.
On the interval ##[\pi/2, 3\pi/2]##, the graph of ##y = \sin^{-1}(\sin(x))## goes from ##(\pi/2, \pi/2)## down to (0, 0), and then to ##(3\pi/2, -\pi/2)##, so this line segment has a slope of -1 with an equation of ##y = -(x - \pi)## (in other words, the same as the graph of y = -x, but shifted to the right by ##\pi## units.
You have to go through this kind of analysis on each of the intervals ##[-\pi/2 + 2n\pi, \pi/2 + 2n\pi]##. Doing this you get a sawtooth graph like this one:http://www.wolframalpha.com/input/?i=plot+y+=+arcsin(sin(x))
thanks... for the explanation
Related to The graph of sin inverse (sin x) after the domain of (- pi/2, pi/2)
1. What is the domain and range of the graph of sin inverse (sin x) after the domain of (- pi/2, pi/2)?
The domain of the graph of sin inverse (sin x) after the domain of (- pi/2, pi/2) is the interval [0, pi]. The range is the interval [-pi/2, pi/2]. This means that the graph only exists between 0 and pi on the x-axis, and between -pi/2 and pi/2 on the y-axis.
2. What is the shape of the graph of sin inverse (sin x) after the domain of (- pi/2, pi/2)?
The shape of the graph of sin inverse (sin x) after the domain of (- pi/2, pi/2) is a series of straight lines connected at the endpoints. This is because the inverse of sin x is a piecewise function, meaning it has different rules for different intervals on the x-axis.
3. How does the graph of sin inverse (sin x) after the domain of (- pi/2, pi/2) differ from the graph of sin x?
The graph of sin x is a smooth, continuous curve, while the graph of sin inverse (sin x) after the domain of (- pi/2, pi/2) is a series of straight lines. Also, the domain and range of the two graphs are different, as the graph of sin x extends to infinity in both directions on the x-axis, while the graph of sin inverse (sin x) is limited to the interval [0, pi].
4. What is the period of the graph of sin inverse (sin x) after the domain of (- pi/2, pi/2)?
The period of the graph of sin inverse (sin x) after the domain of (- pi/2, pi/2) is pi. This means that the graph repeats itself every pi units on the x-axis.
5. How does the graph of sin inverse (sin x) after the domain of (- pi/2, pi/2) relate to the unit circle?
The graph of sin inverse (sin x) after the domain of (- pi/2, pi/2) represents the angle measure of an angle on the unit circle. The x-value of a point on the graph corresponds to the angle measure in radians, while the y-value corresponds to the sine of that angle. This is similar to how the unit circle is used to find the sine of an angle in trigonometry.
  • General Math
  • General Math
  • General Math
