uby
- 176
Hello all,
I am having a slight conceptual problem in rationalizing what happens when a current-carrying material is exposed to an orthogonal magnetic field.
The Lorentz force experienced by the moving charged particle is generally given by (dropping directional notations for clarity):
F = q(E + v x B)
In the absence of an applied electric field, this simplifies to:
F = q(v x B)
In the classical case of a current-carrying wire, this force results in a deflection of the wire. In other words, there is a NET force acting on the charges moving through the wire.
There is also an effect called the Hall Effect, in which an electric field is induced due to the magnetic force:
E = -(v x B)
This field produces a voltage which can be measured.
However, if the force caused by this field is truly in opposition to the Lorentz force, shouldn't the net force on moving charge carriers be ZERO?
i.e.) F = q(E + v x B) = q(-(v x B) + v x B) = 0
Why would the wire deflect if the net force on the carriers is zero? Is it because the induced electric field creates a force on the non-mobile charges in the wire (i.e. - metal cations)?
Thanks
F = q(E + v x B)
F = q(v x B)
E = -(v x B)
Thanks
