The Hubble Constant and Natural Unit
In summary: So essentially, setting the natural value of the Hubble constant to 1 in cosmological calculations is possible and often done, but it cannot be done with other parameters like \Omega_m due to their dimensionless nature. In summary, setting the natural value of the Hubble constant to 1 in some cosmological calculations is possible and often done, as it is considered a normalisation constant. However, this cannot be done with other parameters like \Omega_m due to their dimensionless nature.
micomaco86572
54
Could we set the natural value Hubble constant to be 1 in some calculation of cosmology, like what we do in the natural unit?
Space news on Phys.org
As there isn't anything fundamental about the Hubble constant, this doesn't make sense to me. The Hubble constant is just the current average expansion rate. It's different now than it was a few billion years ago, and from what it will be in a few billion years.
Effectively yes, there are many quantities dealt with in Cosmology in which the Hubble constant value is part of the unit, for instance you can say the distance to some object is X Mpc/h where h = Hubbles constant / 100. The /100 part is just to make little h of order unity, which is what cosmologist tend to like their parameters to be.
There are many more examples of this, since so many things just have the actual value of the Hubbles constant as a simple factor.
Somewhat pedantic note: h = H_0 / (100 km/s/Mpc). It's sort of a way of saying, "Well, this quantity I'm measuring depends upon the actual value of H_0, but we don't know what the actual value is, so we'll just calculate everything based on H_0 = 100km/s/Mpc and carry over the difference between this and the true value by keeping track of the appearances of 'h'."
So I guess this is sort of similar, in a way.
Agreed. The point is that for the most part in cosmological calculations (distance measures dependence on cosmology for instance), the actual value of H0 is simply a normalisation constant and hence can be considered in the above way. This is not true for most other parameters. You couldn't do this with say [tex]\Omega_m[/tex].
Well, that depends upon whether your measurement is sensitive to the density fraction or the total density. The CMB, for instance, is sensitive to the total density of normal and dark matter, while supernova measurements are only sensitive to the density fraction. So for CMB measurements, an estimate of [tex]\Omega_m[/tex] would indeed depend upon [tex]h[/tex], which is why for CMB experiments constraints are usually quoted on [tex]\omega_m[/tex], where [tex]\omega_m = \Omega_m h^2[/tex].
I think the reason why we cannot set [tex]\Omega_{m}[/tex] to be 1 is dimensionless.
Ah, after reading this, I realize that I misunderstood Wallace's post. However, [tex]\Omega_m[/tex] is already almost exactly analogous to [tex]h[/tex]:
[tex]h = \frac{H_0}{100 km/s/Mpc}[/tex]
[tex]\Omega_m = \frac{\rho_m}{\rho_c}[/tex]
(Here [tex]\rho_c = \frac{3}{8 \pi G} H_0^2[/tex] is the critical density, the density for which k = 0 at a given expansion rate).
So we see that [tex]h[/tex] is the "true" Hubble constant compared against some "standard" value of 100 km/s/Mpc, while [tex]\Omega_m[/tex] is the "true" matter density compared against the "standard" density: the critical density. This is usually thought of as the density fraction, but that interpretation is only accurate if the curvature is zero.
Very well stated, Chalnoth.
Related to The Hubble Constant and Natural Unit
1. What is the Hubble Constant and why is it important?
The Hubble Constant is a measure of the rate at which the universe is expanding. It is important because it helps us understand the age, size, and future of the universe.
2. How is the Hubble Constant calculated?
The Hubble Constant is calculated by measuring the distances to galaxies and the speed at which they are moving away from us. This is done using the redshift of light from these galaxies.
3. What is the significance of the natural unit in relation to the Hubble Constant?
The natural unit, or Planck unit, is a set of units used in physics that are based on fundamental physical constants. The Hubble Constant can be expressed in terms of the natural unit, making it a more precise and fundamental measurement.
4. How does the value of the Hubble Constant affect our understanding of the universe?
The value of the Hubble Constant affects our understanding of the universe by giving us insight into the rate of expansion and the age of the universe. A higher constant could indicate a younger universe, while a lower constant could suggest an older universe.
5. How does the Hubble Constant impact cosmological theories and models?
The Hubble Constant is an important factor in various cosmological theories and models, such as the Big Bang theory. It helps us understand the evolution and structure of the universe, and can also provide evidence for or against different theories and models.
  • Cosmology
  • Cosmology
