How Does the Hypersine Function Relate to the Expansion of the Universe?
  • Thread starter marcus
  • Tags
    Model
In summary, the hyperbolic sine is a function that splits the difference between the rising exponential function e^x and the exponential function run backwards, e^-x. It has a nice symmetry that the ordinary exponential function ex does not have. It has natural time scale which is opposite to the ordinary time scale. Distances, areas, and volumes grow according to powers of hypersine over time, and the scale factor a(t) tells us how big a distance is at some given time, compared with its present size. After a moment's inspection you can probably see the place around time 0.44 in our universe's history when distance growth stopped decelerating and gradually began to accelerate.
  • #71
Jorrie said:
To find the optimal point, I would recommend that you calculate three values of of H(t) for a range of 'a' values: (i) the full Friedmann equation, (ii) Friedmann without radiation and (iii) Friedmann without Lambda.
Hi Jorrie:
Thank you very much for your excellent suggestion. I will be working on that for a few days.
Regards,
Buzz
Space news on Phys.org
  • #72
Hi marcus and Jorrie:
I completed the evaluation of H(a) using the Friedmann equation for the three cases Jorrie suggested:
i. H including terms for ΩΛ, Ωm, and Ωr
ii. H including terms just for ΩΛ and Ωm
iii Hmr including terms just for Ωr and Ωm
For my calculations:
H0 = 2.19727088648023E-15
ΩΛ = 0.691906258479859
Ωm = 0.308
Ωr = 0.0000937415201411259​
I calculated the value of a I expected to be the error crossover between ii and iii.
a = (Ωr / ΩΛ)1/4 = 0.107887513320811​
I then chose six other values of a by multiplying a by 0.9997, 0.9998, 0.9999, 1.0001, 1.0002, and 1.0003.
The following table shows the results.
Having completed this exercize, I then integrated the Friedmann equation for case iii, and I ran into a problem.
Since for a approaching zero, I expected t ∝ a2, I was quite surprised when the integral did not behave that way. I am hoping someone can help me find what's wrong in my integration.
(1) H = (da/dt)/a = H0m a-3 + Ωr) a-4)1/2
(2) dt = da (1 / H0) a / (Ωm a + Ωr)1/2
(3) t(a) = (1 / H0) ∫ a da / (Ωm a + Ωr)1/2
Here, not trusting my integration skills, I used my 1957 edition of the CRC Standard Mathematical Tables, Integral #111 on pg 283. The following I copied from the CRC changing only the variable letters and notation:
(4) ∫ a da / (p + q a) = (-2 (2 p - q a) / (3 q2)) (p + q a)1/2
Since we want the value of the integral to be zero for a = zero, the constant
4 p3/2 / 3 q2
must be added to the integral.
Substituting Ωr for p and Ωm for q produces
(5) t(a) = (1 / H0) (-2 (2 Ωr - Ωm a) / (3 Ωm2)) (Ωr + Ωm a)1/2 + 4 Ωr3/2 / 3 Ωm2
From this one can see that
t(a) ∝ a​
Where did I go wrong?
Regards,
Buzz
  • #73
Well, I had another early morning insight, and this time it turned out to be OK. I expanded the integral in a power series, and the coefficient of the linear term canceled out to zero.
My next task is to see if the integral will give a "correct" value for t corresponding to the value of a at recombination.
Regards,
Buzz
  • #74
Hi Buzz, you are doing interesting work, more than I actually suggested (which was just to compare H(t) for the different scenarios).
I'm not confident that you can use the power series to integrate for t all the way to a~0, t~0, because at best it must be an approximation. Around recombination, both matter and radiation have played a significant role and AFAIK, no analytical solution exists for the integral at that epoch. It would however be interesting to see what result you get.
Jorrie
  • #75
Hi Jorrie:
Thanks for your post.
I only wanted to see the constant, linear, and quadratic terms of the power series to conform t varies as a2 near a = 0. I have little confidence at my age that I can still do math without making a mistake, and the integral looked like t varied linearly with a for small a. I will use the integral to calculate values of t(a) for a < 0.1078875.
Regards,
Buzz
  • #76
Hi Marcus, Jorrie made me aware of the "Hypersine model", which seems very valuable to give a better understanding of how the variables play together and evolve in time.
I have a question regarding the plot in #4, where you show a, H and the reciprocal of H, which should be the Hubble length, right? It seems that a grows faster than 1/H up to roughly 0.1 time. Shouldn't 1/H grow faster than a the whole period of deceleration and then inverted? I'm a bit confused, could you please explain?
  • #77
Hi Tim, a(t) is a dimensionless number (pure, unitless)
whereas R = c/H is expressed in that plot in light zeit units---one lzeit is 17.3 billion light years.
So comparing them and their slopes is a bit "apples and oranges".
I'm puzzled by your post. I don't see why 1/H should "grow faster than a the whole period of deceleration and then inverted?"
  • #78
Now I'm puzzled too.:smile:.
I think we do agree that during decelerated expansion the Hubble sphere grows faster than the universe. Shouldn't this be reflected by comparing the slopes of the Hubble length and the scale factor accordingly? Yes, the scale factor is dimensionless, but if it doubles, the universe doubles while the Hubble length increases by a factor > 2. That's my reasoning, but perhaps I'm mistaken.
  • #79
I think the phase that you are thinking of has to do with our past light/future cone, shown as 'D_then' in the graph below. It reaches its maximum distance where the Hubble radius (R) crosses the past light cone. This is the first time photons from the CMB started to make headway towards us (in proper distance terms). Before that time, they were moving away.
  • #80
Tim I think I understand better now. Of course the ratio of a(t) to Hubble length tells you whether a'(t) is increasing or decreasing.
By definition H = a'/a so a'(t) = a(t)H(t) = a(t)/R(t) forgetting about factors of the speed of light and setting R = 1/H.
So if that ratio a/R is increasing then a' is increasing and if a/R is decreasing then a' is decreasing.
The trouble is with the words "F(x) grows faster than G(x)"
It is not true that the ratio F/G increasing implies the slope of F is greater than the slope of G. F/G increasing is not equivalent to F' > G'.
Example on the interval [0, 1/2) consider F(x) = x and G(x) = x2
F'(x) = 1 which is always greater than G'(x) = 2x on that interval.
However the ratio F/G = 1/x is always DECREASING.
WHEN YOU SAY "we do agree that during decelerated expansion the Hubble sphere grows faster than the universe" I have to say NO.
we do not agree because that sounds to me like the SLOPE of one curve is steeper than the other----R'(t) > a'(t) ---- and that is simply not true during decelerated expansion.
But it is true that during decelerated expansion the RATIO of a/R is decreasing. That is another way of interpreting the words "a grows slower than R".
The trouble is "a grows slower than R" is ambiguous.
  • #81
Not really, the past light-cone depends on how the universe expands, but doesn't show the expansion itself. Meanwhile marcus has answered and I will be busy with that.
  • #82
marcus said:
WHEN YOU SAY "we do agree that during decelerated expansion the Hubble sphere grows faster than the universe" I have to say NO. we do not agree because that sounds to me like the SLOPE of one curve is steeper than the other----R'(t) > a'(t) ---- and that is simply not true during decelerated expansion.
I guess you meant to write " the RATIO of da/dR is decreasing"?
Even that would not be generally true, because the change from decreasing to increasing in that ratio happens at the peak of the light cone curve, as I have shown above. This is well before the desired inflection point for a(t), around t=4 Gy.
  • #83
Marcus, thanks for answering in some detail which should make it easier to clarify things.
Yes, we compare the slopes. F'(x) > G'(x) means that F(x) grows faster than G(x) regarding said interval and conversely G(x) grows faster than F(x), if x > 0.5. Hopefully you do agree on that.
Lets compare the slopes of a and R in the plot of #4, using the wording as above:
Time Interval [0, 0.1]: a grows faster than R, -- a'(t) > R'(t)--. -> acceleration
Time Interval [0.1, 0.4]: R grows faster than a. -> deceleration. At t = 0.4 (very roughly) deceleration turns to acceleration again.
Time Interval [0.4, infinite]: a grows faster than R. -> acceleration
I'm confused, because if I understand the plot correctly(??) the universe though being matter dominated starts to expand accelerated. Why?
https://en.wikipedia.org/wiki/Hubble_volume
For example in a decelerating Friedmann universe the Hubble sphere expands faster than the Universe and its boundary overtakes light emitted by receding galaxies so that light emitted at earlier times by objects outside the Hubble sphere still may eventually arrive inside the sphere and be seen by us.[3] Conversely, in an accelerating universe, the Hubble sphere expands more slowly than the Universe, and bodies move out of the Hubble sphere.
Mentioning "decelerating Friedmann universe" could imply Lambda = 0. Does this make the difference, as above "matter dominated" means just a large ratio of matter density to Lambda density? But still, why then should the universe start to to expand decelerated at t = 0.1 after the matter has already been diluted?
Sorry, this all seems to make not much sense.
  • #84
Hi Tim, I posted this before I saw your post #83, so it doesn't respond to what you just said but to something earlier.
Tim, did my comment make sense to you. I think you are giving a non-standard interpretation to the words "hubble sphere grows faster than a".
You are not comparing slopes, which would be a usual interp.
You are talking as if you mean the RATIO, namely a/R, is decreasing.
You say for example that the scale factor DOUBLES and R MORE THAN DOUBLES. Mathematically that means a/R decreases.
But that is not equivalent to saying the slopes are in the relation a' < R' which I think is how most people would tend to hear words like R grows faster than a.
That is the verbal ambiguity I was talking about in my comment.
  • #85
This shows that you must never verbally interpret deceleration by saying "a grows slower than R"
That statement is first of all meaningless because they don't have the same units. They are incommensurable.
But more importantly, it will give people the impression that you mean something about the SLOPES (a' < R') which is simply not true.
So you screw people up if you say things like "deceleration means the universe grows slower than the Hubble radius", if they believe your words.
Look at that plot #4 for example. You can see that a(t) starts out decelerating because it is convex upward. But it is obviously not true that a'<R'
I think if you want a mathematical condition that would correspond truthfully to deceleration you could say for example that "The ratio a/R is decreasing"
That is true during deceleration because (up to factors of c) R = 1/H and so a/R = aH
and since H is a'/a what we have here is a/R = a'
So if the ratio a/R is decreasing then a' is decreasing, which is what people normally associate with deceleration.
Likes timmdeeg
  • #86
Sorry Marcus, I read you wrong; you are right about a/R that decreases during acceleration and increases during accelerating expansion. I hope I did not compound Tim's problem with this!
  • #87
Very true and it confirms, what I was thinking previously.
https://www.physicsforums.com/threa...e-ratio-hubble-length-to-scale-factor.842617/ #4
timmdeeg said:
The ratio I'm asking for is ##1/Ha##. Replacing ##H## by ##(da/dt)/a## yields ##1/(da/dt)##. Therefore ##1/Ha## should increase as long as the universe expands decelerated and decrease during accelerated expansion then.
I think, in the meantime I was misled by the wording "in a decelerating Friedmann universe the Hubble sphere expands faster than the Universe", causing me to think in terms of slopes, which however yields a wrong result, as is obvious from my post 83.
Marcus, I'm very thankful that you brought me back on the right track. Thanks for your efforts! Sorry, it took a while thought you mentioned the ambiguity of the wording "grows faster" and the like a few times.
  • STEM Educators and Teaching
