High School The inclined plane paradox (proved)
The discussion revolves around an experiment involving momentum and its behavior when a ball bearing bounces off different surfaces mounted on a cart. Participants express skepticism about the novelty of the findings, asserting that the principles demonstrated are well-established in Newtonian mechanics. The conversation highlights the importance of understanding elastic and inelastic collisions, with several contributors recommending foundational study in these areas. Concerns are raised about the experimental setup's practicality, particularly regarding friction and the materials used. Overall, the thread emphasizes the need for a solid grasp of basic physics concepts to interpret the results accurately.
migyonne
Hello, I invite you to watch this video.
This is a simple experiment, which has never been carried out and which proves that momentum can undergo a 'repartition'...
[URL='https://youtu.be/JoM59at8cnY?si=lNA4tjiOihXwZ3U2]The Beauty of Momentum[/URL]
What do you think of this phenomenon ?
What conclusion can we draw from this?
Thanks a lot for your answers.
You bounce a ball bearing moving horizontally (a) off a vertical surface mounted on a cart; then (b) off a 45° sloped surface mounted on a cart. In case (a) the ball bounces directly back, so the cart gains more momentum than in case (b) where the ball is deflected upwards but continues in the same direction as the cart moves.
There's nothing there that's novel, nor remotely unusual, let alone paradoxical.
Likes russ_watters, Mark44, Orodruin and 1 other person
Thank you so much!
Do you have an experience reference or a formula, please?
It is very important for my studies
migyonne said:
Thank you so much!
Well, it's basic Newtonian mechanics. How much have you studied momentum and elastic (that is, ideal) collisions?
Likes russ_watters
This should be covered in any basic mechanics class. All that is needed is the basics of inelastic collisions including a coefficient of restitution. What you want to do is to open an introductory textbook.
It's a very messy experiment, unfortunately. In an ideal case you just need conservation of energy, momentum, and angular momentum. But because your equipment is very far from ideal (the cart is made of Duplo, if I am not mistaken) you need to worry about static and dynamic friction and other such losses. Also, your system is not closed, clearly transferring momentum to the Earth. A quantitative analysis would be challenging.
The ideal case is do-able I think, but I doubt it will come anywhere near matching what you see.
I think he more needs to study elastic collisions, like the one in his example (link), but both would be a good idea.
Thread level changed I-->B.
What makes you think the collisions are elastic? Just the fact that the cart jumps off the ground means it is not.
I'm with Orodruin on this one. The friction in this demo is crazy. If you can lay your hands on a Duplo cart I invite you to spin a wheel - precision engineering they are not.
Learning elastic collisions is probably something OP needs to do first, but this is very much an inelastic problem.
As coincidence would have it, I am not unlikely to step on a Duplo cart when I make my way towards the bed shortly ... 😂
Edit: Not a Duplo cart, but a piece of a wooden puzzle … Generally I would say not rolling without resistance is a design feature of Duplo carts. It keeps parents’ backs unbroken.
  • Haha
Likes Nugatory, Ibix, phinds and 1 other person
It is, but I find the easiest path to understanding these problems is to analyze them in the absence of friction, then try to form an intuition for how friction changes that idealization.
(Of course that's just me, and I won't argue with anyone who prefers a different path)
Likes russ_watters and phinds
What sleight of hand is needed to make this work?
Hello,
Do you want to talk about the experience or the 'truncated' video link?
Copy and paste the URL, deleting the question mark and everything after it.
Likes sophiecentaur
It is missing a ’ after mentor edit. Originally it mixed up the URL and display text.
  • · Replies 17 ·
  • · Replies 102 ·
  • · Replies 40 ·
  • · Replies 31 ·
