zyp
- 3
Is the integral of a strictly positive function on a set of positive measure strictly positive? Thankis a lot
quasar987 said:Yes. Suppose f:A-->R is such a function. We have that
[tex]A=\bigcup_{n\in\mathbb{N}}f^{-1}\left(\left[\frac{1}{n},+\infty\right)\right)[/tex]
and so by subadditivity of the measure
[tex]\mbox{mes}(A)\leq \sum_n\mbox{mes}\left(f^{-1}\left(\left[\frac{1}{n},+\infty\right)\right)\right)[/tex]
Since mes(A)>0, it must be that A_n:=mes(f^{-1}\left(\left[\frac{1}{n},+\infty\right)\right))>0 for some n. By definition
[tex]\int_Af=\sup_h\left{\int_Ah\right}[/tex]
where h:A-->R denotes a positive measurable stair function bounded above by f.
It follows that
[tex]\int_A f\geq \int_{A_n}\frac{1}{n}=\frac{1}{n}\mbox{mes}A_n>0[/tex]
The term "ingerals" is likely a misspelling of "integrals," which are a mathematical concept used to represent the area under a curve on a graph.
In this context, "measures" refer to different units of measurement. For example, a function may have one set of values in meters and another set of values in feet. Integrals can be used to find the area under the curve for each set of values, allowing for comparisons between the two measures.
Yes, integrals can be applied to any continuous function. However, the specific method used to calculate the integral may vary depending on the type of function.
Using two different measures in a function allows for comparisons and conversions between the two units of measurement. This can be useful in various fields, such as physics, engineering, and economics.
To calculate integrals for functions on two different measures, you would first need to convert one set of values to match the other measure. Then, you can use the standard methods for calculating integrals, such as Riemann sums or the Fundamental Theorem of Calculus.
