The Initial Reaction of a Voltaic Cell
In summary: I still don't understand exactly what happens initially in a simple voltaic cell with a salt bridge (Daniel cell).In summary, the initial reaction in a voltaic cell with a salt bridge involves the flow of electrons from the zinc anode to the copper cathode, resulting in the oxidation of zinc and the reduction of copper. The salt bridge helps maintain charge balance and the flow of electrons is initiated when the circuit is closed. The potential difference between the electrodes also plays a role in the initial reaction.
student34
639
I just want to start by saying that I have found many questions very similar to this one using the search bar, but I still don't understand exactly what happens initially in a simple voltaic cell with a salt bridge (Daniel cell).
For example, I am trying to figure out what initially happens in a cell with a zinc anode in zinc sulfate solution connected with an external circuit to a separate jar with a copper cathode in a copper sulfate solution. The salt bridge contains potassium chloride.
Because I am concerned about the very beginning of the flow of electrons in the voltaic cell, sources say that the salt bridge does not come into effect yet due to the lack of positive zinc ions. So the charges do not make it through the full circuit yet. Okay, that's fine.
So what is the initial reaction that starts this initial one-way flow of charges: zinc is oxidized, copper is reduced, both simultaneously or some other reason?
Chemistry news on Phys.org
student34 said:
both simultaneously
... , and, the salt bridge maintains the charge balance (zero) in both sides of the cell.
Likes student34
But I am missing the reason why the electrons flow from the zinc to the copper in the first place. Even if they oxidize and reduce simultaneously, what initially causes the copper to be reduced and at the same time that the zinc to be oxidized. I don't understand the initial driving forces.
Copper ions oxidize zinc metal; or, zinc metal reduces copper ions, either way you care to think about it. You have been introduced to free energies of chemical reactions?
Likes student34
I think I understand. Just to be sure, if I touched solid copper to solid zinc instead of connecting them with a conducting wire, would the copper oxidize some of the zinc atoms?
I don't think so.
student34 said:
I don't think so.
Just looked at previous threads, and, you're being "eased" into the concept. It's pretty much the same thing as is going on with the plating out of silver on the copper strip, or this thread https://www.physicsforums.com/threads/oxidizing-and-reducing-agents.799828/ , and hopefully, they'll get to the "bottom line" and give you a few rules and a table of redox potentials to use for this type of problem fairly soon. Copper is a less reactive metal than zinc, and that means that copper ions are more reactive toward zinc metal (corrosive, likely to oxidize zinc, whatever) than zinc ions are toward copper metal.
Likes student34
Entropy
Likes student34
DrDu said:
Entropy
To be honest, I don't see how it addresses the problem.
We remove ion on the copper side from the solution and put it on the electrode surface. Entropy goes down.
We remove an atom on the zinc side from the electrode and put it into the solution. Entropy goes up.
As a first approximation final entropy doesn't change, so it can't be a driving force.
Sorry, I didn't have the possibility to write much. As soon as you bring an electrode into the corresponding solution, some of the metal will dissolve and some get deposited. Which of the two reactions predominates depends on the relative stability of the ions vs. metal. This stability changes then when the electrodes start to charge up, which is a very fast process. As long as there is no external current, there will also be no internal current through the salt bridge, as each half cell will stay overall neutral.
Likes Borek
I think I found the answer. My textbook seems to say that the copper atoms of the anode will actually oxidize the zinc atoms of the cathode with or without the solution.
Does anyone know if this is accurate?
I am trying to imagine what it means. I have two pieces of metal, I touch them - and what? Zinc cations jump out into the air?
Definitely there will be some potential difference created by the junction, that's the thermoelectric effect at work.
I am not sure. It seems to be the only way thing that makes sense to me. I don't know what else could cause the flow of electrons?
For the record: zinc cations will NOT jump into the air.
So then what else would be the initial reaction?
If you're asking what initiates the reaction, it's when the circuit is closed and electrons are able to flow. Open circuit, no flow, no reaction. Closed circuit, electrons flow, copper is reduced and zinc is oxidized.
No idea, that's why it caught my attention.
There is a potential difference even in the open circuit, so there is _some_ initial reaction involved. Electrodes become charged the moment they are immersed in the solution, even if the circuit is otherwise open.
Check out this post.
https://www.physicsforums.com/threads/galvanic-cells-and-salt-bridges.812134/
Hey,
a little bit of hijacking here, but anyways: In Daniell cell, why SO4 ion does not get bonded with Zinc at the electrode interface? I guess it has to do something with reduction potential or is it because its a soluble salt? But in that case, would that mean that solvent bondings are keeping SO4 ion so tightly? Or would SO4 ion get initially attached and then solvated again?
Solubility is the only thing that matters here.
The SO4 2- ion is a 'spectator ion' and does not enter into the Galvanic process. Also, the zinc electrode in, say a Zn/Cu cell,. the Zno us undergoing oxidation leaving and imposes excess of negative charge on that electrode. SO4 2- is a negative ion whose oxidation potential is on the positive end of the Reduction Potential table and would function as a Furthermore, the SO4 2- as a counter ion remains in solution throughout the Galvanic process. In the Zn/Cu cell Zn and Cu will be the dominate reactions of the Voltaic Cell.
Link edited out.
Could you elaborate. Why are you saying 'solubility' is the only thing that matters here? There are several issues to consider beyond solubility when describing the Galvanic process and chemistry of Voltaic Cell. Thank you. jp
ZnSO4 doesn't precipitate because it is well soluble.
This question was also asked today somewhere else and there behavior of ZnSO4 was compared to the behavior of AgCl which covers Ag electrodes in the presence of chlorides. The only difference - or in other words, the only reason why Ag electrode becomes covered with AgCl, while Zn electrode doesn't get covered with ZnSO4 - is the solubility of the salt involved. Galvanic process is not important here and not needed to explain the problem.
Your reply suggests that Ag as an 'electrode' is in basic standard state [Ago(s)]. I can't find one citation that suggests that Ag-metal in basic standard state reacts with chloride ions (Cl-(aq)). I find plenty that relate Ag+(aq) ions react with Cl-ions to produce AgCl, which precipitates as a solid because it has a Ksp = 1.8 x 10-10. It's common understanding that unless Ago(s) is oxidized to Ag-ions in the presence of Cl-(aq), AgCl will not form. Also, the positive reduction potential of [Cl2(g)/2Cl-(aq)] ( = 1.36 volts ) is greater than [Ag+(aq)/Ago(s)] ( = 0.80 volts ) which indicates that Cl2(aq) would have to be present to induce oxidation of the silver. From your reply, I get the impression that you are talking about Ag-metal in the presence of chloride ions reacting to form the ionic compound AgCl without considering the oxidation-reduction process. Silver Chloride may be forming when Ag(s) and Cl-(aq) are interfaced, but what is driving the oxidation of Ag(s)? I'm finding it difficult to find citations that support your statement that Galvanic Process in not important when oxidation-reduction reactions are required to generate the AgCl precipitate. Redox reactions are a basic tenant of Galvanic Processes.
James, you have a tendency to overcomplicate things. My bet is that the OP has no idea what you are talking about. To reiterate in the context of the original question:
It doesn't happen because the solubility of ZnSO4 is high enough.
Question doesn't ask about what and why gets oxidized.
Borek, Being a new guy, I'm not totally fluent with this site. I want to ask, is there a private communication channel on this forum? I have a request for your review only and not for the public viewing. Thank you, jp
I don't think so.
For the second case whatever happens there is between Cu and Zn, at the same oxidation level, a bIt different from what we are considering - Cu2+ and Zn.
Your first question is really what drives any chemical reaction, or any ionic one with simple electron transfer at least. That is part of general chemistry. Some atoms hold on to electrons or give them away more than others. All tied with the explanations of the systematics of the periodic table. The elements are all different so one will tend to donate electrons to another, the big question is which to which. You can study that even without electrochemistry. Zn will donate electrons to Cu2+ giving Cu and Zn2+. You can easily find many you-tube etc. videos showing this happen and red copper precipitating out of blue copper sulfate solutions in which there some plates of zinc. (I only don't quote anyone because those I saw were sufficient but not very good.)
The driving force you ask after is already there in thse reactions. Electrochemistry just has the nice addition that through diffusion of ions in the liqiid and the miracle of metallic conditivity you can couple one chemical reaction at one point to another at another, and also in the process extract useful work, like light up a lightbulb.
Likes student34
Thank-you, I understand this now.
Related to The Initial Reaction of a Voltaic Cell
1. What is a voltaic cell?
A voltaic cell is an electrochemical cell that converts chemical energy into electrical energy. It consists of two half-cells, each containing an electrode and an electrolyte, connected by a salt bridge. This allows for the transfer of electrons and ions, generating an electrical current.
2. What is the initial reaction of a voltaic cell?
The initial reaction of a voltaic cell is the oxidation of the anode and the reduction of the cathode. This results in the transfer of electrons from the anode to the cathode, generating an electric current. The reaction at the anode is spontaneous, and the reaction at the cathode is non-spontaneous.
3. What factors affect the initial reaction of a voltaic cell?
The initial reaction of a voltaic cell is affected by several factors, including the types of electrodes and electrolytes used, the concentration of the electrolyte solution, and the temperature of the cell. These factors can influence the rate of the initial reaction and the amount of electrical energy produced.
4. How is the initial reaction of a voltaic cell measured?
The initial reaction of a voltaic cell is measured by the voltage or potential difference between the two half-cells. This voltage can be measured using a voltmeter. The higher the voltage, the greater the initial reaction and the more electrical energy is produced.
5. What is the purpose of the initial reaction in a voltaic cell?
The purpose of the initial reaction in a voltaic cell is to generate an electric current. This current can be used to power electronic devices or to carry out other chemical reactions. The initial reaction sets the stage for the continuous production of electrical energy in the voltaic cell.
