The integral of a harmonic function
In summary, the solution to this integral relies on the fact that the function log|z| is harmonic in the slit plane and the use of the Mean Value Property to calculate the average value of the function over a closed curve. This allows us to see that the integral is equal to log|z_0| when |z_0| < r and log|r| when |z_0| > r. Additionally, we need to consider the boundary points of the curve in order to properly apply the Mean Value Property. I hope this helps to clarify any confusion you had about the solution. Keep up the good work!
Poopsilon
294
Show that:
[tex]\frac{1}{2\pi}\int_0^{2\pi}log|re^{i\theta} - z_0|d\theta = \left\{\begin{matrix}
log|z_0| & if & |z_0| < r \\
log|r| & if & |z_0| > r
\end{matrix}\right.[/tex]
The function log|z| is harmonic in the slit plane since it is the real part of log(z) which is analytic in the slit plane. I'm pretty sure I'm supposed to use the fact that it's harmonic.
Harmonic functions have the Mean Value Property which states that the average of a harmonic function on the boundary of a ball is equal to the value of the harmonic function at the center point of this ball.
What I don't understand is that this integral is the average of log|z| along a circle of radius r centered at [itex]z_0[/itex], and thus by the Mean Value Property I feel that it should always equal [itex]log|z_0|[/itex] for [itex]log|z| \neq r[/itex]. I also feel like we should have the requirement that [itex]z_0 \neq 0[/itex] since the logarithm of zero is negative infinity. What am I missing here? Thanks.
Hello,
Thank you for sharing your thoughts on this problem. You are correct in your understanding that we can use the Mean Value Property to solve this integral. However, there are a few key points that we need to consider in order to fully understand the solution.
Firstly, you are correct that the function log|z| is harmonic in the slit plane, meaning that it satisfies Laplace's equation. This is because it is the real part of the analytic function log(z), and the real part of an analytic function is always harmonic. This is an important property that we will use in our solution.
Next, let's consider the integral itself. As you mentioned, it represents the average value of log|z| along a circle of radius r centered at z_0. This means that we are essentially taking the average of the function over a closed curve. We can use the Mean Value Property to rewrite this integral as the value of the function at the center point of the curve, which in this case is z_0. However, we need to be careful with the boundary points of the curve.
If we consider the case where |z_0| < r, then the curve is contained entirely within the circle of radius r centered at z_0. In this case, the boundary points of the curve are all inside the circle, and so the Mean Value Property tells us that the average value of the function is equal to the value at the center point, which is log|z_0|. This is what we see in the first part of the solution.
On the other hand, if we consider the case where |z_0| > r, then the curve extends beyond the circle of radius r centered at z_0. In this case, the boundary points of the curve include some points outside the circle. This means that the Mean Value Property no longer applies, and we cannot simply take the value of the function at the center point. Instead, we need to consider the average value of the function over the entire circle of radius r centered at z_0. This is where the second part of the solution comes in – we can use the Mean Value Property to show that the average value of log|z| over the entire circle is equal to log|r|. This is because the function is harmonic, and so the average value over the entire circle is equal to the value at the center point, which is log|r|. This is what we see in the second
FAQ: The integral of a harmonic function
What is the definition of the integral of a harmonic function?
The integral of a harmonic function f(x,y) is the sum of the values of the function over a specified region in the x-y plane. Mathematically, it is denoted as ∬f(x,y) dx dy, where the double integral represents the sum over the region and dx dy represents the area element.
How is the integral of a harmonic function related to its derivative?
According to the fundamental theorem of calculus, the integral of a function is the inverse operation of its derivative. Therefore, the integral of a harmonic function is related to its derivative as the derivative of the integral is equal to the original function.
What is the significance of the integral of a harmonic function in physics?
The integral of a harmonic function is used in physics to calculate physical quantities such as electric potential, gravitational potential, and fluid flow. It is an essential tool in understanding the behavior of physical systems.
Can the integral of a harmonic function be negative?
No, the integral of a harmonic function cannot be negative. This is because a harmonic function is defined as one that satisfies Laplace's equation, which states that the sum of the second-order partial derivatives of the function is equal to zero. Therefore, the integral of a harmonic function over a closed region will always be zero or positive.
Are there any applications of the integral of a harmonic function in real life?
Yes, the integral of a harmonic function has numerous applications in real life, such as in designing electronic circuits, analyzing fluid flow in pipes, and modeling the behavior of physical systems. It is also used in solving boundary-value problems and in the field of image processing.
