How can I evaluate the integral of x/lnx if all methods seem to fail?
  • Thread starter Xyius
  • Tags
    Integral
In summary: It is possible that the exponential integral function itself is not "elementary".In summary, The problem discussed is evaluating the integral \int \frac{x}{ln(x)} dx, which has a solution of \frac{1}{2} \frac{x^2}{ln(x)} according to Maple. However, this is not the correct result as it does not pass the differentiation test. The actual solution involves the exponential integral function, \mbox{Ei}(2\ln(x)), which is defined as \mbox{Ei}(x) = \int_{-\infty}^x dt~\frac{e^t}{t}. While this form still involves an integral, it is a standard function recognized by many
Xyius
508
For some reason, I can not seem to evaluate this integral.
[tex]\int \frac{x}{ln(x)} dx[/tex]
When I plug it into maple it says the solution is
[tex]\frac{1}{2} \frac{x^2}{ln(x)}[/tex]
I cannot seem to get it for some reason! I have tried every integration technique in the book. :\
That is not a correct result, as you can check by differentiating. It looks like you accidentally wrote log(y) or something which mathematica treated as a constant, and so it gave you the integral of x. The real result involves the exponential integral,
[tex]\mbox{Ei}(2\ln(x))[/tex]
http://www.wolframalpha.com/input/?i=integrate+x/ln(x)
You were right, I forgot to put the parenthesis on the natural logarithm. I haven't learned what an exponential integral is yet. I am currently in Differential Equations but "Ei" doesn't look familiar. :\
The Exponential Integral funtion, [itex]\mbox{Ei}(x)[/itex], is a special function defined by
[tex]\mbox{Ei}(x) = \int_{-\infty}^x dt~\frac{e^t}{t}[/tex]
To be fair, this is just obtained by making a change of variables on your original integral; however, this is a special function that should be available in mathematica or matlab, so it is a standard-ish form you can use.
I did get that form quite a few times when I was trying to solve it. But I stopped at that point because it seemed like a dead end. So would that mean that the solution to the integral is an integral? Would this suggest that there is no actual solution to it? I guess you would use approximation techniques at that point to evaluate it. Am I correct with this assumption?
I haven't looked at it closely, but it just looks like the integration by parts using u = x and setting dv as the logarithmic integral.
Your integral is one that can't be expressed in elementary functions. However, while the exponential integral function is still defined as an integral, it is a standard function that is recognized by many computer math systems, and so this form is more useful than the original integral form. The programs will use a variety of techniques to evaluate the function for different regimes of x, but I do not the specific details.
FAQ: How can I evaluate the integral of x/lnx if all methods seem to fail?
What is the integral of x/lnx?
The integral of x/lnx is equal to x(lnlnx - 1) + C, where C is the constant of integration.
How do you solve the integral of x/lnx?
To solve the integral of x/lnx, you can use the substitution method by letting u = lnx. This will result in the integral becoming ∫u du, which is easy to solve. After solving for u, you can substitute back in lnx for u to get the final answer.
What is the domain of the integral of x/lnx?
The domain of the integral of x/lnx is (0, ∞). This means that the function is only defined and can only be integrated for positive values of x.
Is the integral of x/lnx a continuous function?
Yes, the integral of x/lnx is a continuous function. This means that the function is defined and has a value for every point on its domain, and there are no sudden jumps or breaks in the graph of the function.
Can the integral of x/lnx be used to solve real-world problems?
Yes, the integral of x/lnx can be used to solve real-world problems in various fields such as physics, economics, and engineering. It can be used to calculate the area under a curve, which can represent physical quantities such as displacement, velocity, or acceleration. It can also be used to find the average value of a function, which is useful in determining averages in various fields.
