Isambard
- 10
- 3
Imagine making a hole in the ground, about a mile deep, with a large and square diameter. In the middle of the hole, there is a hollow and narrow tube with all air sucked out. Next to one of the walls, so close that it's touching, there is another hollow tube without air inside. Two identical marbles are dropped simultaneously, with one falling through the tube in the middle, and the other through the tube close to the wall.
Since one of them is close to one of the walls, it is closer to the mass surrounding them. The other tube is in the middle, and so the distance to the walls around it is the same, and the gravitational pull should even each other out.
Will one of the marbles hit the bottom before the other, even if it is a very tiny difference between them if that's the case?
