The Laplace of unfamiliar function
In summary, the conversation is about solving the integral \int_{0}^{\infty} \, e^{-at} \sin(bt) \frac{\ln t}{t}\, dt using Laplace identities. The value returned by Mathematica is deemed insane and the steps to solve it are discussed in the thread. The final solution involves evaluating the Harmonic sum and integrating it to get the result -\left( \frac{ \log(a^2+b^2) }{2} +\gamma \right) \arctan \left( \frac{b}{a} \right).
alyafey22
MHB
1,561
I found the following integral \(\displaystyle \int_{0}^{\infty} \, e^{-at} \sin(bt) \frac{\ln t}{t}\, dt \)
This thread will be dedicated to solve the integral , any ideas will always be welcomed (Cool).
Serious steps will be made in the next threads . It seems to involve Laplace identities the value returned by Mathematica is insane (Sweating).
We can start by the following integral
\(\displaystyle
\begin{align*}
I(s) = \int_{0}^{\infty} t^{s-1} \, e^{-at} \, \sin(bt) dt
&= \int_{0}^{\infty}t^{s-1} \, e^{-at}\sum_{n\geq 0} \frac{(-1)^n (bt)^{2n+1}}{\Gamma(2n+2)} \\
&= \sum_{n\geq 0} \frac{(-1)^n (b)^{2n+1}}{\Gamma(2n+2)} \int_{0}^{\infty}t^{s+2n} \, e^{-at} dt \\
&= \frac{1}{a^s} \sum_{n\geq 0} \frac{(-1)^n (b)^{2n+1} \Gamma (s+2n+1)}{\Gamma(2n+2) a^{2n+1}}
\end {align*} \)\(\displaystyle
\begin{align*}
I'(0) = \int_{0}^{\infty} \, e^{-at} \sin(bt) \frac{\ln t}{t}\, dt
&= \sum_{n\geq 0} \frac{(-1)^n \psi_0(2n+1)}{2n+1} \left( \frac{b}{a} \right)^{2n+1} -\log(a) \sum_{n\geq 0} \frac{(-1)^n }{2n+1} \left( \frac{b}{a} \right)^{2n+1}\\
&= \sum_{n\geq 0} \frac{(-1)^n H_{2n}-\gamma}{2n+1} \left( \frac{b}{a} \right)^{2n+1} -\log(a) \arctan \left( \frac{b}{a} \right) \\
&= \sum_{n\geq 0} \frac{(-1)^n H_{2n}}{2n+1} \left( \frac{b}{a} \right)^{2n+1}-(\gamma +\log(a))\arctan \left( \frac{b}{a} \right)
\end{align*}
It remains to solve the following
\(\displaystyle \sum_{n\geq 0} \frac{(-1)^n H_{2n} }{2n+1} \, x^{2n+1}\)
I will try to evaluate the Harmonic sum in the next post ,,,
After lots of thinking here is a solution to the harmonic sum
\(\displaystyle
\begin{align*}
\sum_{k\geq 0}(-1)^k H_{2k} x^{2k}&= \sum_{k\geq 0}(-1)^k x^{2k} \int^1_0 \frac{1-t^{2k}}{1-t} \, dt\\
&= \int^1_0 \frac{1}{1-t} \sum_{k\geq 0}(-1)^k x^{2k} \left(1-t^{2k}\right) \, dt\\
&= \int^1_0 \frac{1}{1-t} \sum_{k\geq 0}(-1)^k \left(x^{2k}-(xt)^{2k}\right) \, dt\\
&= \int^1_0 \frac{1}{1-t}\left(\frac{1}{1+x^2}-\frac{1}{1+t^2x^2}\right) \, dt\\
&=\frac{1}{1+x^2} \int^1_0 \frac{1+t^2x^2-1-x^2}{(1-t)(1+t^2x^2)} \, dt\\
&=\frac{-x^2}{1+x^2} \int^1_0 \frac{(1-t^2)}{(1-t)(1+t^2x^2)} \, dt\\
&=\frac{-x^2}{1+x^2} \int^1_0 \frac{1+t}{(1+t^2x^2)} \, dt\\
&=\frac{-x^2}{1+x^2} \left( \int^1_0 \frac{1}{1+t^2x^2}+\frac{t}{1+t^2x^2} \, dt \right) \\
&= \frac{-1}{2(1+x^2)} \left(2x \arctan (x) + \log(1+x^2) \right) \\
\end{align*}
Using this we conclude by integrating
\(\displaystyle \sum_{k\geq 0}\frac{(-1)^k H_{2k}}{2k+1} x^{2k}=-\frac{1}{2} \log(1+x^2) \arctan(x) \)
Hence the following
\(\displaystyle \sum_{k\geq 0}\frac{(-1)^k H_{2k}}{2k+1} \left(\frac{b}{a} \right)^{2k+1}=-\frac{1}{2} \log \left( \frac{a^2+b^2}{a^2} \right) \arctan \left(\frac{b}{a} \right) \)
\(\displaystyle
\begin{align*}
\int_{0}^{\infty} \, e^{-at} \sin(bt) \frac{\ln t}{t}\, dt &= -\left( \frac{1}{2} \log \left( \frac{a^2+b^2}{a^2} \right) + \gamma +\log(a) \right) \arctan \left( \frac{b}{a} \right)\\
&=- \left( \frac{ \log(a^2+b^2) }{2} +\gamma \right) \arctan \left( \frac{b}{a} \right)\\
\end{align*}
Which is the result we are seeking for ... (Happy)
FAQ: The Laplace of unfamiliar function
What is the Laplace of an unfamiliar function?
The Laplace of an unfamiliar function is a mathematical operation that transforms a function from the time domain to the frequency domain. It is commonly used in engineering and physics to analyze dynamic systems and solve differential equations.
How is the Laplace of an unfamiliar function calculated?
The Laplace of an unfamiliar function is calculated using the Laplace transform, which involves integrating the function multiplied by an exponential function. The result is a complex number in the frequency domain that represents the function's behavior over time.
What are the applications of the Laplace of an unfamiliar function?
The Laplace of an unfamiliar function has many applications in engineering and physics, such as solving differential equations, analyzing electrical circuits, and modeling dynamic systems. It is also used in signal processing and control theory.
How does the Laplace of an unfamiliar function differ from the Fourier transform?
The Laplace transform and Fourier transform are similar, but the Laplace transform is more general as it can be applied to a wider range of functions, including those with exponential growth or decay. The Fourier transform is a special case of the Laplace transform for functions with no exponential growth or decay.
Are there any limitations to using the Laplace of an unfamiliar function?
One limitation of the Laplace transform is that it only works for functions that are causal, meaning that the output of the function depends only on the current and past inputs. It also assumes that the function approaches zero as time approaches infinity. Additionally, the Laplace transform can be difficult to calculate for functions with complex behavior.
