The last static equilibrium problem.
In a product liability lawsuit regarding a portable infant seat, the manufacturer argues the child was too heavy, while the parents claim the seat was defective. Testing indicates the seat can withstand a force of 96.2 N at point A and 229 N at point B, with the child weighing 98 N. Calculations show that the forces at points A and B do not exceed these limits, suggesting the seat should have been safe. However, since the child fell, it indicates a defect in the seat's design or construction. Therefore, the judge should rule in favor of the parents, confirming the manufacturer's liability.
akan
You have been called on to testify in a product liability lawsuit. An infant sitting in a portable seat that is supported by the edge of a table fell to the floor (see the figure). The manufacturer claims the child was too heavy for the seat, and the parents claim the seat was defective. Testing showed that the seat can withstand the weight of a child when the force at A does not exceed 96.2 N and the force at B does not exceed 229 N. The child has a mass of 10 kg. In whose favor should the judge rule?
http://img370.imageshack.us/img370/5152/rw1264ji6.jpg
http://g.imageshack.us/img370/rw1264ji6.jpg/1/
How do I solve this?
Hi akan! :smile:
Show us what you've tried, and where you're stuck, and then we'll know how to help. :smile:
(x) Sum(F_x) = 0 (no forces)
(y) Sum(F_y) = F_a - F_b - F_child = 0
F_child = mg = 10*9.8 = 98
pivot at B:
(2) Sum(T_z) = F_a * (.22) - F_child (.16) = 0
pivot at C (child):
(3) Sum(T_z) = F_a * (.38) - F_b (.16) = 0
(2) .22 F_a = .16 F_child
(2) F_a = (.16 / .22) F_child = (.16 / .22) (98) = 71.27
(3) (.16 / .22) F_child (.38) = F_b (.16)
(3) F_b = (.38 / .22) F_child = (.38 / .22) (98) = 169.272727
Neither of these exceeds the allowed values, so why is the correct answer "in favor of parents"?
judge rules ok!
Hi akan! :smile:
I haven't checked your calculations …
but assuming they're correct, that means that the child would have been safe if the seat was well-made.
Since the child wasn't safe, that proves the seat was defective, and so the judge should rule "in favor of parents". :smile:
The calculations show that the force did not exceed the specifications. Yeah, I guess that means that it's the manufacturer's fault and the seat was flawed. Thanks.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
