The lifespan of a neutron star
In summary: Every collection of matter will evaporate, assuming the universe continues to expand at an exponential rate. The expansion leads to a background temperature of about 1/(16 billion years) in natural units, or 10-28 K - order of magnitude estimate. At this temperature, it is extremely unlikely that thermal fluctuations kick out an electron or an atom of a neutron star - but it will happen, and over ridiculously large timescales (something like 101040 years) neutron stars will evaporate.If protons are unstable, then neutron stars will evaporate much faster due to hadron decays.
dendros
39
How durable are the neutron stars, ie how long can they last? Will they "evaporate" like black holes or something else will happen with them after a very long period of time (eons)? Or are they immortal?
I'm asking because I have found nothing clear about the lifespan of a neutron star.
Astronomy news on Phys.org
Here's more info than you'd ever want to know informally about a neutron star:
https://www.astro.umd.edu/~miller/nstar.html
and from this NASA website an estimate 10 billion years for some oldest known pulsars:
http://imagine.gsfc.nasa.gov/ask_astro/neutron_star.html
The Question
Could you tell me how long a neutron star 'lives'? Different sources are all conflicting.
The Answer
If you're asking how long a neutron star can actually be detected as a pulsar, the answer is that in the most recent catalog of pulsars (pulsars are rotating neutron stars), the oldest ones are more than 10,000,000,000 years old (although the large majority of pulsars is between 100,000 and 300,000,000 years old.
Now we can only date the neutron stars for which we measure a period and a period derivative, which means that there may be a large population of older "silent" neutron stars
I hope this answers your question.
Ilana Harrus for
the "Ask an Astrophysicist" team.
Question ID: 000406a
I don't think there's any known physical process that would make the neutron star last for less time than an infinite time. Of course, a lot can happen in infinite time.
Nothing can last forever, not even the Universe, so I doubt that a neutron star could have an infinite lifespan. A physical process that could make a neutron star to last for less than an infinite time could be the quantum tunneling.
Are there are some theoretical estimates for the lifespan of a neutron star?
Likes AgentCachat
No known physics could come up with a reasonable timespan that we could have any confidence in.
The most ancient known star is a type K dwarf star called SMSS J031300.36- 670839.3, with a confirmed age of 13.6 billion years - re:http://arxiv.org/abs/1402.1517. As neutron stars go they are extremely faint and difficult to detect - and even harder to to assign a reliable age. Pulsars can be detected much further out, but, pulsars spin down and lose the ability to 'pulse' [hence become undetectable] in relatively short order. The slowest known pulsar in J2144-3933 with an amazingly long period of 8.5 seconds. It is estimated to be about 34 million years old. In theory a neutron star should outlive any other type of star. So the oldest neutron star is probably at least as old as the oldest known star, or nearly the age of the universe.
I think neutron stars are as close to immortal heavenly bodies as one might hope to find. They won't evaporate, as far as I know. They could accumulate enough mass to collapse into a black hole. They could collide with a white dwarf, neutron star, or black hole. These are rare events. Outside of that, they would go on forever.
Neutron stars, white dwarfs, planets are all stable. They all only cool with time and on the scales of ~100 billion years all activity such as thermal light emissions, geology, quakes on them stops. A relatively small residual magnetic field may remain.
They may be not infinitely stable if nucleons are unstable ("proton decay", also affects neutrons despite its name).
I'm pretty sure they have about a 10 billion year lifetime. They might collapse and form a black hole, the star would have to have at least 25 solar masses in order for it to successfully form a black hole.
This is not their lifetime, it is a lower bound on the maximal lifetime.
Extrapolating physics theories vastly beyond the regimes in which they have ever been verified is one technique for learning about our physics theories, but has a poor track record as a means of learning about what actually happens.
Likes einswine
This would violate conservation of energy: the mass of neutron star is 20% less than mass of all its neutrons (and other lesser constitutients) when they all are pulled away and are "free particles".
Temperature fluctuations are just statistical behavior of large collection of randomly moving particles. In some cases statistical approximation is not exact enough.
Here, at very low temps, when combined kinetic energy of all particles in the body is less than what you need to kick out even one neutron from neutron star to infinity, neutrons no longer can escape.
You have the energy - it is coming from the cosmological expansion. There is no global conservation of energy in general relativity anyway.
Something else might happen before, but unless that destroys the neutron star (which does not change the conclusion), a lot of time and exponential expansion (=assumptions I made) are sufficient.
2 solar mass NS contains about 3*10^57 neutrons. To escape from NS, single neutron needs ~200 MeV of kinetic energy. When temperature of NS falls below ~ 10^-44 K, total kinetic energy of all neutrons in the NS is not enough to give 200 MeV to a single one. If NS can get that cold, then it will be absolutely stable against thermal evaporation.
It won't get that cold with current cosmology.
Also, you still have the environment which also has fluctuations.
The surface has normal atoms, so you would start by removing those. Would give an interesting object.
The number 101040 years came up. My money says that the time it takes up to come up with a new expectation about what will happen to the universe in the next 101040 years is a whole lot less than 101040 years. But we can still talk about what our current theories say.
ALL our statements are always "within the current theories". And speculations beyond current theories are against the forum laws anyway.
The issue is whether or not we have any good reason to expect our current theories to be right. Usually, we are working within some observational framework that can give us confidence. I don't think that's the case when numbers like 101040 years come up. It's the same issue with the general gedankenexperiment concept-- we confuse what empirical science is if we think gedankexperiments are experiments. They are only ways to talk about a theory, nothing more. Our shooting percentage drops rapidly the farther we leave behind the realm of experiments we have actually performed.
Yes - neutrons undergo beta-decay near the surface; the weak interaction reverses the decay only at very high pressures of the interior. So neutron star have coronas with degenerate electron matter and outside that still lower density with ionized matter. A weak stellar wind would be offset by infalling atoms from nearby space.
A remnant magnetic field would diffuse outwards, because the back-and-forward weak interactions cause diffusion of the otherwise 'frozen-in' field. Very low activity levels, but the neutron star is not absolutely 'dead' to the universe.
The problem with a neutron star having a wind (after it has spun down) is that it is energetically disfavored. Degenerate matter that loses mass must expand, so the gravitational potential energy must increase (it must go to smaller magnitude, but it is negative). So energy must be added to both the lost matter in the wind, and also everything that stays behind, and this will soon become impossible. Making matters worse is that both beta decays, and the inverse weak interaction, both result in the emission of neutrinos (the Urca process), so escape of those neutrinos would produce yet another energy loss channel. With all these energy losses going on, there will come a point where the wind too must die. Ultimately, neutron stars (and black white dwarfs) must be about the deadest objects we can imagine.
Likes newjerseyrunner
Related to The lifespan of a neutron star
1. What is a neutron star?
A neutron star is a type of celestial object that is created when a massive star runs out of fuel and collapses in on itself. It is extremely dense, with a mass greater than that of the sun packed into a sphere the size of a city.
2. How long do neutron stars live?
The lifespan of a neutron star varies depending on its initial mass. On average, it is estimated that a neutron star can survive for about 10 million to 100 trillion years.
3. What happens to a neutron star as it ages?
As a neutron star ages, it gradually cools down and its magnetic field weakens. Over time, it will also spin slower and slower until it reaches a stable state known as a "magnetar." Eventually, it may also merge with another neutron star or black hole, leading to its ultimate demise.
4. How do scientists study the lifespan of neutron stars?
Scientists study the lifespan of neutron stars by observing their emissions of X-rays, gamma rays, and radio waves. They also use computer simulations to model the evolution of neutron stars and make predictions about their lifespan.
5. Could a neutron star ever die?
While neutron stars have incredibly long lifespans, they are not immortal. Eventually, they will either merge with another celestial object or cool down to become a black dwarf. However, this process takes trillions of years, so in human terms, neutron stars can be considered essentially eternal.
  • Astronomy and Astrophysics
