The Limit of a Trigonometric Function
In summary, the limit of a trigonometric function is a mathematical concept used to determine the behavior of a function as its input approaches a specific value. It can be calculated using various methods and is significant in calculus for determining continuity and differentiability. Special cases, such as indeterminate forms, must be considered when calculating the limit. In some cases, the limit can be infinite if the function approaches an undefined value.
Jambr
lim x-> 0 ( sin(5x) - 3x ) / ( 3x )
(a - b) / c = (a / c) - b
(1/3) lim x->0 ( sin(5x) / x ) - 3x
= (1/3) lim x->0 ( sin(5x) / x )( 5 / 5) - 3x
= (5/3) lim x->0 ( sin(5x) / 5x ) - 3x
= (5/3) * 1 - 3x
= (5/3) - 3x
= (5/3)
I use WolframAlpha to check whether or not my answers are correct. WolframAlpha and I are having a disagreement (even though I am most likely wrong) about this problem. I say 5/3, it says 2/3. Can someone please explain where I went wrong?
Sorry, I tried using LaTeX but I just got annoyed.
You can start with (a - b) / c = (a / c) - b. That's not right. (a-b)/c=(a/c)-(b/c).
Here is your error.
[tex]\frac{sin(5x)- 3x}{3x}= \frac{sin(5x)}{3x}-\frac{3x}{3x}= \frac{sin(5x)}{3x}- 1[/tex]
[tex]= \frac{5}{3}\frac{sin(5x)}{5x}- 1[/tex]
= (5/3) * 1 - 3x
= (5/3) - 3x
= (5/3)
Thank you, I had tried that already but I did it by removing the 3 from the bottom first off, which was wrong.
Another question: As we all know sin x / x = 1, is it also true at sin^2 x / x^2 = 1?
If you mean limit as x->0, sure. Both limits are 1.
FAQ: The Limit of a Trigonometric Function
What is the limit of a trigonometric function?
The limit of a trigonometric function is a mathematical concept that describes the behavior of a function as the input approaches a certain value. In simpler terms, it determines what value a function approaches as its input gets closer and closer to a specific value.
How is the limit of a trigonometric function calculated?
The limit of a trigonometric function can be calculated using various methods, such as algebraic manipulation, substitution, and the use of trigonometric identities. It is also important to consider the properties and behaviors of the specific trigonometric function in question.
What is the significance of the limit of a trigonometric function?
The limit of a trigonometric function is important in calculus, as it helps determine the continuity and differentiability of a function. It also allows for the evaluation of complex limits and the application of the intermediate value theorem.
Are there any special cases when calculating the limit of a trigonometric function?
Yes, there are a few special cases to consider when calculating the limit of a trigonometric function. These include the cases of indeterminate forms, such as 0/0 and ∞/∞, which require additional techniques such as L'Hôpital's rule.
Can the limit of a trigonometric function be infinite?
Yes, the limit of a trigonometric function can be infinite in certain cases. This occurs when the function approaches an undefined value, such as 1/0 or ∞, as its input approaches a specific value.
