The Line of Intersection of Two Planes
In summary, the line of intersection between the planes 6x-3y+z=5 and -x+y+5z=5 can be represented by the parametric equations x = 20/3 + t, y = 35/3 + t, z = t, where t is a real number.
Bassa
46
Find a set of parametric equations for the line of intersection of the planes.
6x-3y+z=5 and -x+y+5z=5[/B]
The cross product formula
The formula for the parametric equations of a line in three dimensional space:
x=x1+at, y=y1+bt, z=z1+ct
Knowing the fact that the coefficients in front of the variables in the equation of a plane are the components for the normal vector of the plane
[/B]
I found the cross product between the normal of the two plane. The resulting vector is going to function as the direction vector for the intersection line.
a= the normal vector of the first plane
b=the normal vector of the second plane
axb=-16i-31j+3k
finding a point on the intersection line:
We could do this by forming a system of equations. We get rid of on of the variables by saying that at some point the value of z in both planes will be the same and at some point it will be zero. This will give us the system of equations:
6x-3y=5
-x+y=5
Would solve for one of the variable by using the method of elimination. We could multiply the second equation by 6. This will give us:
6x-3y=5
-6x+6y=30
We could solve for y:
y=35/3
we could substitute the value of y into the second equation and that will give us a value for x:
-x+(35/3)=5
x=20/3
Now, we have the point ((20/3), (35/3), 0)
From this point it is really easy to plug the numbers into the parametric equations of a line. I referred to the solution of this problem. We both had the same values for the direction vector, but the point on the line was different. This makes the parametric equations of the intersection line have different values for x1, y1, z1. I was wondering if there is a unique answer to this problem? My thought is that there isn't, because we could choose any point on the line and use it to write the parametric equations of the intersection line. Am at right on this?
You are correct that any point plus a direction vector defines a unique line. The point itself is in no way unique, and may only be an indicator of which technique was used to find it.
If you are looking for additional or alternative methods, it may be worth trying to understand how the textbook solution was derived.
I can see no reason to worry about the normal vectors, etc. Essentially, a point on the line of intersection, because it lies on both planes, must satisfy both equation. So finding a point on the line of intersection of the two lines is just solving the two equations 6x-3y+z=5 and -x+y+5z=5.
Since that is two equations in three unknowns, you can solve two of the unknowns in terms of the third, then use that third as a parameter.
Related to The Line of Intersection of Two Planes
What is the line of intersection of two planes?
The line of intersection of two planes is the line that lies at the point where the two planes intersect each other. This line is formed by the points that are common to both planes.
How is the line of intersection of two planes calculated?
The line of intersection of two planes can be calculated by finding the point of intersection between the two planes using their equations. This point can then be used to find the direction vector of the line, which can be expressed as a parametric equation.
What is the significance of the line of intersection of two planes?
The line of intersection of two planes is significant in geometry and graphics as it represents the boundary or intersection between two distinct planes. It can also be used to solve systems of linear equations in mathematics and in physics to determine the path of two intersecting planes.
Can the line of intersection of two planes be parallel?
Yes, the line of intersection of two planes can be parallel if the two planes are parallel themselves. In this case, the line of intersection will be an empty set, as the planes do not intersect and therefore do not share any common points.
What does the slope of the line of intersection of two planes represent?
The slope of the line of intersection of two planes represents the direction and steepness of the line in relation to the coordinate axes. It can also be used to determine the angle between the two planes at the point of intersection.
