The logic of the self inductance formula
In summary, self inductance is a property of circuit components that measures their ability to generate an induced voltage in response to a change in current. The formula for self inductance is L = NΦ/I, where L is measured in henries and is affected by the number of turns, magnetic flux, and current. It is related to magnetic fields through Faraday's law of induction and can cause delays and distortions in circuits. The self inductance of a circuit can be increased by adding more turns, increasing the area, using a material with higher permeability, or by using a ferromagnetic core.
nabliat
33
[tex]M_{12}=\frac{N_2\phi _{12}}{I_1}[/tex]
i need to remmeber it
but i can't see the logic of
the formula
the formula
I thought the formula looked something like: [tex]\frac{\mu_{0}N^2 A}{l}[/tex]. A is the cross section & magnetic field inside the solenoid is [tex]B=\mu_0 NI/l[/tex], flux through one loop is [tex]BA=\mu_0 N IA/l[/tex] and [tex]\Phi= \mu_0 N^2 I A/l[/tex] is the total flux. The inductance is just total flux divided by current.
FAQ: The logic of the self inductance formula
1. What is self inductance?
Self inductance is a property of a circuit component that describes its ability to generate an induced voltage in response to a change in current flowing through it. It is measured in units of henries (H).
2. What is the formula for self inductance?
The formula for self inductance is L = NΦ/I, where L is the self inductance in henries, N is the number of turns in the coil, Φ is the magnetic flux through the coil, and I is the current flowing through the coil.
3. How is self inductance related to magnetic fields?
Self inductance is related to magnetic fields because the changing magnetic field produced by a current flowing through a coil causes an induced voltage according to Faraday's law of induction. This induced voltage is directly proportional to the self inductance of the coil.
4. What is the significance of self inductance in circuits?
Self inductance is significant in circuits because it can cause delays and distortions in the flow of current, which can affect the performance of the circuit. It is also important in the design of electronic devices and can be used to create components such as inductors and transformers.
5. How can the self inductance of a circuit be increased?
The self inductance of a circuit can be increased by adding more turns to the coil, increasing the area of the coil, or by using a material with a higher permeability. Additionally, placing a ferromagnetic core inside the coil can also increase the self inductance of the circuit.
