The Lorentz factor gamma and proper time
Trysse
59
TL;DR Summary
Proper time along a light-like curve isn’t undefined; it’s zero. The infinities arise only from
for , not from the geometry itself. Using avoids these issues.
I’ve been following this recent discussion on the speed of light and its implications in special relativity, and it got me thinking about proper time along light-like curves and the use of the Lorentz factor, .
One point that stood out to me is the claim that proper time along a light-like curve is undefined because becomes infinite when . While this is technically correct for , the apparent “undefined” nature of proper time comes from ’s structure, not from any fundamental issue with proper time itself.
Proper time is often expressed as
it can also be written as
If we focus directly on rather than , the situation becomes much simpler. For light-like motion (), , and so the proper time is exactly zero. This result aligns perfectly with the idea that no proper time elapses along a light-like curve, such as the path of an electromagnetic signal in Minkowski spacetime.
The infinities associated with as are thus artifacts of its structure, not a reflection of the spacetime geometry itself. By focusing on , we avoid these complications entirely and gain a clearer understanding of proper time along light-like paths.
Proper time along the world line of light is irrelevant as it is not an affine parameter of that world line. Precisely because it is a null curve. There is not much more to it than that and talking about it as an actual proper time does not offer new insights.
You can however introduce an affine parameter to the null geodesic. It does not have the interpretation of a time measured by a clock, but it does increase monotonically along the null path and as a result also with the increase of coordinate time of any inertial frame.
Events along the null path are distinct and it becomes disingenuous and misleading to talk about it as “time not passing for a photon”.
Likes Dale
Trysse said:
TL;DR Summary: Proper time along a light-like curve isn’t undefined; it’s zero.
Okay, let's accept that. How does that change the physics? You want to study the motion of a light ray and you have a parameter that is zero at every point on the light's trajectory. That's no use. So, you have to look for a different way to parameterise the light's trajectory.
Typo: , not .
The problem is that proper time is a measure of arc length (or interval) along a timelike curve. That's what actually makes it useful - that you can use it to label different events along a curve without reference to anything off the curve. That doesn't work for a null curve because the interval is zero and you cannot label points that way - you need to do something else. That is, the interval along the curve is indeed zero, but proper time isn't just the interval - it's the concept of regularly spaced tick marks along the curve, which isn't possible this way with null curves.
A more practical way to look at it is to note that if we have a timelike curve and I specify an event on it and any finite proper time later, you know which event I'm referring to. Not so with a null curve.
And the most physical way to look at it is to ask you to think about how you plan to build a clock that moves at light speed. It simply isn't possible to lay out a device that changes in any way, moves at an average speed of , and doesn't have any part of it exceed . So there's no physical meaning to "time" along the curve because you can't (even in principle) make a device to measure it.
Likes robphy, Dale, javisot20 and 1 other person
Any device returning a constant will work. That speaks to the entire point of being unphysical though …
  • Haha
Likes Ibix and PeroK
If it doesn't change the physics, then what is the point of arguing against it? Since the limit also approaches zero, why not just accept it is zero? Even if it's just for the sake of continuity and has no practical application.
A.T. said:
If it doesn't change the physics, then it what is the point of arguing against it? Since the limit also approaches zero, why not just accept it is zero? Even if it's just for the sake of continuity and has no practical application.
I agree it's a matter of taste. The issue is that in the other thread, the OP went ahead and divided by for a photon and got an infinite speed. This, as I read that thread, was something that needed an explanation. We can say that division by zero is not defined. And then we are back to my mathematical analogy!
Ibix said:
Typo: Δτ=Δt/γ, not Δt⋅γ.
Corrected in the OP.
Likes Ibix
Because a photon / beam of light has no rest frame so how can it even be meaningful to talk about a time associated with it?
Trysse said:
TL;DR Summary: Proper time along a light-like curve isn’t undefined; it’s zero. The infinities arise only from
the apparent “undefined” nature of proper time comes from γ’s structure, not from any fundamental issue with proper time itself
No, the fact that proper time is undefined on a null worldline comes from the definition of proper time:
“For timelike paths we define the proper time (eq 1.97) which will be positive”
See Sean Carroll’s Lecture Notes on General Relativity https://preposterousuniverse.com/wp-content/uploads/grnotes-one.pdf equations 1.95 - 1.97 and the associated text.
The proper time is undefined on a null worldline because we want it to be undefined and we have deliberately constructed our definition in such a way as to make it undefined there.
The reason that we have chosen to define it this way is that this definition will make other proofs simpler. This choice is not forced on us by the “nature” of anything, but is chosen for its usefulness.
Likes PeterDonis
As long as we stop there it’s harmless, but when this question comes up it’s always because someone hasn’t stopped there: they conclude “time stops” and end up in a sea of confusion because now the photon cannot move, try to do calculations in the rest frame of the photon, or some other silliness. Then they try to calculate a factor from it….
The statement that as means that we can make as large as we want by choosing a value of that is close enough to but still less than . Getting from there to is mathematically problematic because isn’t in the domain of ; is the coordinate velocity of an object at rest in its own inertial frame.
Thus I prefer to interpret the infinities and physically meaningless zeroes that appear at as the math telling us that we’re abusing it by trying to evaluate a function outside of its domain.
  • Love
Likes PeterDonis, robphy, javisot20 and 1 other person
Because then in every subsequent proof and use of proper time you have to do a test to see if it is zero or not before you can divide by it. That is inconvenient.
Also, it is not clear that continuity would be desirable here. There are several senses in which a null path and a timelike path are fundamentally different and placing the restriction forces you to confront that possibility. In the cases where continuity is warranted then you can use the affine parameter which is well defined for both timelike and lightlike worldlines.
Likes PeterDonis and PeroK
Let me introduce you to the Orodruin constant. It is a constant characterised by being able to take any fixed value, but with the important property of being universally constant. It also does not have any predictable consequences depending on its value.
I don’t understand why the Nobel committee has not called yet … 🤔
  • Haha
Likes PeterDonis
Consider a timelike worldline parameterized in flat Minkowski spacetime by coordinates with the metric signature chosen as . Proper time is defined by integrating the interval along the worldline, where . For a massive particle traveling with speed , we can write and thus obtain
Integrating from some initial time to a final time gives
In the special case of a massless particle, we know the path is light-like, so by definition , which forces
Hence each infinitesimal interval of proper time is zero, and the total proper time accumulated along that path is
The perceived “infinity” when using arises only if one tries to treat the light-like case as a limit of the timelike formula for velocities approaching , but this limit artifact does not reflect any genuine geometric singularity. Instead, the interval’s vanishing factor, , correctly signals that photons and other massless quanta do not experience the passage of proper time, and the geometry remains perfectly well-defined.
thomsj4 said:
Proper time is defined by integrating the interval dτ along the worldline,
Proper time is defined by integrating the interval along a timelike worldline. See the Carroll above.
So by definition the proper time is undefined for a massless particle.
The integral that you write does evaluate to 0 but that integral is not the proper time, which is undefined.
That is already captured in the definition. The problem arises when, instead of correctly saying “massless quanta do not experience the passage of proper time”, people incorrectly say “massless quanta experience the passage of 0 proper time”.
Likes Mister T, robphy and PeterDonis
Convenience is a valid reason. But for some, conceptual continuity might be more important.
I don’t think that the concepts that a different definition would make “continuous” should be made “continuous”.
We can think about spacetime always in some global (inertial) reference frame where light is the limit of subluminal trajectories. However, all subluminal trajectories have a four-velocity of magnitude . And light, dare I say, has no four-velocity. Also, subluminal particles have energy and momentum that tend to infinity as . Whereas, light has a finite energy and momentum.
Moreover, we must eventually wean ourselves off the security of a global inertial frame, and consider a coordinate-independent view of physics. In this view, the null wordline of light is in no way the limit of time-like worldlines - which are all equivalent geometrically. In other words, there is no such thing as a massive particle that is closer to light-like than another. Whatever one you choose, it has a rest frame where it is as far from light-like as possible. As geometric objects, the four-momentum of any particle is discontinuous from the four-momentum of light.
In terms of conceptual clarity, I would say it's important to see this discontinuity between time-like and light-like worldlines - the latter are invariant and map out the structure of causality throughout spacetime.
In terms of understanding the geometric, coordinate invariant theory of GR, it's important to move away from the concept of a null worldline being the limit of time-like worldlines.
Likes Dale
The following quote from Geroch’s Mathematical Physics (p81-82) seems appropriate… in particular, the comment about “irrelevant things”:
“It is intended that the discussion above make the point that all the structure of (V,g) has physical meaning, that anything one says within this structure can be interpreted as a physical statement, that any theorem about this structure is a physical prediction, etc. There are no "irrelevant things" around. We emphasize, however, that a Minkowski vector space is to be nothing more and nothing less than its mathematical definition above. One must prove things within that framework, providing physical interpretations where they are interesting or useful.”
To me, it's all a bit like insisting that the area of a degenerate triangle is not zero, but undefined. Despite the fact that the area formula gives a perfectly normal numerical result for that special case, motivated by inconvenience in some proofs where you need to divide by the area.
The issue is not that the arc length along a null worldline is undefined. It is well defined: it's zero.
The issue is interpreting that arc length as a "proper time". That interpretation is not justified for a null worldline, because it depends on the arc length being an affine parameter along the curve, and for a null worldline, arc length is not an affine parameter. To put it another way, you can't use arc length along a null curve as a clock, and being able to use arc length as a clock is the physical basis for interpreting the arc length as a "proper time".
Likes robphy, Nugatory and phinds
I don’t think it is at all similar. We are not just doing math we are doing physics. We want our mathematical quantities to map to our physical measurements.
Any of your standard mechanisms for physically measuring areas will give a valid 0 result in the case of the triangle. So calling it 0 area is reasonable.
The proper time is mapped to the measurement of a clock. A clock that measures 0 proper time is only ever measuring a single event, never a pair of null separated events. There is no “conceptual continuity” between a clock measuring 0 time and the interval between distinct events on a null worldline.
If we used the word “proper time” for any spacetime interval, we would still need another word to specifically refer to the interval on a timelike worldline, since that is a physically useful concept that can be measured with a clock. And once we have that word then we are back here again.
We use the definition as it is because it is a useful concept. Changing the word to refer to a broader concept wouldn’t change the importance of the narrower one.
Plus, the broader concept already has a word: the spacetime interval. Why does it need two?
Likes Orodruin and PeterDonis
This is mathematically untenable. A point or line is not a triangle. You are free to develop your own idiosyncratic mathematics and use a different definition of a triangle than everyone else. But, that's what it is - your own mathematics that will have its own definitions and theorems.
In Euclidean geometry the sum of the internal angles on a triangle is 180 degrees. There's no possibility in standard mathematics for a triangle to have no internal angles.
A degenerate triangle can have a sum of internal angles equal to 180° (180 + 0 + 0), but it's also just a line.
  • Skeptical
Likes PeroK
How do you know which end of the line has the 180 degree angle? A line is also a degenerate rectangle so it's internal angles should sum to 360 degrees as well. A line is neither a triangle nor a rectangle. Assuming it is one or both is where your problems begin.
This is a question of whether geometric properties are preserved in the limit of a sequence of sets of points. In general, they are not.
Likes phinds
Neither of them, the ends have the 0° angles. The vertices of the degenerate triangle are 3 distinct co-linear points. It's obviously not just a simple line, because you know the 3 vertices, not just the 2 end points.
Trysse said:
One point that stood out to me is the claim that proper time along a light-like curve is undefined because γ becomes infinite when v=c.
But that's not the reason! The relation is derived under the condition that , thus it is not surprising that it gives nonsense when .
The reason it's undefined is that it doesn't exist.
Thanks for the discussion.
I have two questions.
Is it then wrong to write:
Because this equation is defined for . What should I write instead of to make it a meaningful equation?
What is the distinction between "not experiencing time" and "experiencing ZERO time"? Does it not amount to the same?
It's not wrong, but yields a proper time only if and yields a valid spacetime interval only in two special cases: or . And then it doesn't tell you anything you don't already know from using the general formula for the spacetime interval and the definitions of spacelike, lightlike, and timelike intervals.
And even though you may find your approach simpler, this simplicity is an illusion: it assumes a particular coordinate system and only works (to the extent that it works at all, as above) in flat spacetime. You will have to unlearn it before you can take on general relativity, or even some of the more interesting (acceleration, rotation) problems of special relativity.
They are pretty much the same thing, but neither is a good interpretation of a zero spacetime interval between two different events (it's fine for the zero interval between an event and itself).
In my opinion, in this context,
  • "not experiencing time"
    suggests that the concept of [proper-]time "doesn't apply" along a lightlike segment
    and so the variable for it is left "undefined" or (maybe even "NaN") (as one might encounter and use in a computer program)
  • "experiencing ZERO time"
    suggests that the concept of [proper-]time applies along a timelike segment (possibly just a single point... suggesting the points coincide)
    and so the variable for it is assigned "0".
We would also not apply "proper time" to any spacetime path that is not a timelike curve (like a spacelike curve.. or any curve where the tangent vector is not timelike everywhere on it).
Your typical calculator will say that "-2" doesn't have a square root.
Should the calculator assign the answer as zero? Or should it leave it undefined?
  • #31
Worrying about that isn't physics.
  • #32
I don't know. It's a question of semantics, not physics.
The important distinction here is that for anything traveling at speed the passage of time is not defined. That is very different from saying that the passage of time is zero.
In the parlance of physics you have three types of intervals: timelike, lightlike, and spacelike. The passage of proper time is defined, and makes sense, only for timelike intervals. For a lightlike (as well as a spacelike) interval it is not possible to define the notion of proper time. It is therefore a sloppy use of terminology to say that no time passes for something traveling at light speed. Moreover, that sloppy use of terminology can lead to misconceptions.
