The mass of a photon in motion
In summary, the mass of a photon is zero and the formula for kinetic energy, E = (1/2) mv^2, does not apply in the relativistic world. Instead, the total energy of the particle can be calculated using the formula E = mc^2γ and the kinetic energy can be calculated using the formula K = mc^2γ - mc^2 = mc^2(γ-1), where γ is the Lorentz factor. However, for speeds much smaller than the speed of light, the formula for kinetic energy can be approximated as K ≈ (1/2)mv^2.
Krushnaraj Pandya
73
Find the mass of photon in motion.
E=hf
p=hf/c
I just started studying modern physics and am aware of the above two equations. However equating E to 1/2mv^2 gives a different (wrong) answer while equating p to mv gives the correct expression when we consider v=c; is it wrong to write E=1/2 mv^2 or p=mv for a photon (something to do with relativity perhaps)?
I'd appreciate some insights, thank you
Could it be you accidentally discovered that ##E=mc^2 ## :wink: ? Or did someone provide you with the correct answer and spoiled it for you ?
By the way, there will be theoreticians who object against abusing the term 'mass' in this manner. (I'm not a theoretician :rolleyes:)
By the way, there will be theoreticians who object against abusing the teerm 'mass' in this manner. (I'm not a theoretician :rolleyes:)
Ohh! Right! I did not see it at all till you mentioned it,(I thought I wouldn't encounter this equation at all in high school). but a little fact-gathering provoked by your answer led me to the relativistic equation of E and what it implies (Although my knowledge of relativistic equations is severely limited, I know of one equation- that of dependence of mass on velocity) but it was quite illuminating.
I guess the person who wrote my textbook wasn't a theoretician either
Thank you very much for your help, entering into studying a new form of physics is wonderful :D
As a second thought, I'd still like to know till where KE=1/2 mv^2 is valid though
The photon is massless. That is all there is to it.
This has nothing to do with being a theoretician or not.
Likes Krushnaraj Pandya and BvU
That depends on your experimental precision. The next term in the series expansion is proportional to mv^4/c^2. Whenever your experimental precision is sufficient to resolve that you need to take relativistic corrections into account.
What does the quantity hf/c^2 represent?
Nowadays we no longer speak of mass depending on velocity. That was done in the first half of the 20th century, but not anymore (at least, not by most actual physicists---but maybe still by some authors of science books for the "layman"). For particles with positive mass, we just have non-classical formulas for momentum and energy, so ##E = (1/2) m v^2## no longer applies in the relativistic world. Instead, we have ##E = m c^2 \gamma ## for the total energy of the particle, and ##K = m c^2 \gamma - m c^2 = m c^2 (\gamma - 1)## for the kinetic energy. Here,
$$\gamma = \frac{1}{\sqrt{1 - (v/c)^2}}.$$ Note that for speeds small compared to ##c## we have
$$ \gamma - 1 = \frac{v^2}{2 c^2 } + \frac{3 v^4}{8 c^4} + \frac{5 v^6}{16 c^6} + \cdots \approx \frac{v^2}{2c^2}. $$
Thus, the kinetic energy is ##K \approx (1/2) m v^2## for ##|v| \ll c.##
For photons the mass is zero, and the formula ##E = m c^2 \gamma## does not hold, essentially because ##m = 0## and ##\gamma = \infty##, so the formula makes no sense at all.
Likes BvU and Krushnaraj Pandya
That clears up a lot of things, thank you very much :D
What do you think the author of my textbook had in mind when he posed this problem of finding the 'mass' of a photon?
perhaps he meant to imply the rest mass of a photon is zero, instead of saying its mass is zero?
That makes very little sense also, because a photon is never at rest, so the "rest mass" in non-existent. It also violates Special Relativity because it implies that there exists a reference frame where the photon is at rest.
Can you type out the author, title, and publisher of your book?
Zz.
Zz.
My textbook is not one with a standard aim of providing theory, it is one especially designed for an entrance called JEE Advanced. They'll often put something like this in (probably so that the reader questions it and gathers some knowledge about it?)
Its just the way competition in India is. The book is made by a private all-India coaching institute called Aakash (Interestingly, these are much deeper and better then the standard textbooks taught to us in school). It might be a deliberate question, or it may have been blissful ignorance of relativity since it is supposed to be for a high-school student perhaps
Either someone thinks that there is such a thing as "relativistic mass" for a photon, or this is a trick question in trying to get you to realize that the mass of a photon is zero.
Remember that the full relativistic equation is
E2 = (pc)2 + (mc2)2
For light, m = 0, so all you are left with is
E = pc
We have several videos and articles already written about this in this forum. One cannot use E = mc2 to argue that this is the "relativistic mass" of a photon, because then the equation above will carry more energy than there is.
I don't know if you can ask an instructor to clarify this, but someone may need to determine what is being tested here.
Zz.
E2 = (pc)2 + (mc2)2
E = pc
Zz.
The exact question is "Find the mass of photon in motion"
The exact answer is hf/c^2
It could be that my textbook is plain wrong
Like I said, this is someone's idea of a "relativistic mass", which is still incorrect.
A lot of people also think that since it has a "momentum", then it must have this mass, since, "p=mv". This is not valid because the definition of "momentum" in this case does not need to include a mass, because I can also write momentum as "p=hk". We use this for light and also for "crystal momentum" in solid state physics.
You should still ask an instructor if you are able to. This is something that they should not perpetuate, even with an unofficial, make-shift text that people like you are learning from. Tell your instructor that even Albert Einstein stopped using the term "relativistic mass" eventually when he realized how misleading and inappropriate that name is.
Zz.
Likes BvU and Orodruin
What year is your textbook from?
I find that this usage is prevalent in a lot of older texts and also (unfortunately) in texts by people who have learned from those, never had to work further with the material, and then teach it as they were taught without any realisation about how the term is actually used in modern physics language (by "modern" I here mean actual modern physics, not the typical "modern physics" courses that you will get at some universities, which is about 100 years old physics).
Also, send your instructor here to discuss the issue with us if (s)he persists.
Zz.
Ah! Right, its finally very clear in my head.
I don't have an instructor- I learn these things myself from books. Whenever in doubt regarding the accuracy of a sentence, I post here- and in that way I have the best instructors one could ask for :)
(while still being able to learn at my own pace, enjoying every equation in the book instead of along with a classroom teacher.)
Another thing is, this was just a trivial question at the back of the book- hardly related to the main chapter's material (just for extra knowledge I presume) and most students probably overlooked it since they didn't want to get mixed up with relativity too early but I couldn't help it.
It is certainly old enough I suppose, but the editions are revised every 6 months. I don't think they will change it in any case, and I have no way of telling the author either. And yes, we are basically studying 100 years old 'modern' physics...that's just life in high school in India
Our syllabus is quite vast. No instructor is bothered about teaching the extra things given in a book, I just look over things that are doubtful or seem wrong in my book and ask the qualified people of PF to kindly solve my doubts :D
Ok,so this is what my book explicitly says- "Although a photon has no rest mass, it possesses the inertial mass m=hf/c^2, since light is deflected by gravitational field, so it is naturally assured that photons have same gravitational behavior as other particles..."
I would throw away that book.
Likes davenn and Krushnaraj Pandya
Hahaha, alright. I'll buy a newer, more accurate book then. Thank you very much :D
Related to The mass of a photon in motion
1. What is the mass of a photon in motion?
According to the theory of relativity, a photon has no rest mass because it travels at the speed of light. However, it does have a relativistic mass which is dependent on its energy and frequency.
2. How is the mass of a photon related to its energy?
The mass of a photon is directly proportional to its energy, as stated by Einstein's famous equation E=mc². This means that as the energy of a photon increases, its mass also increases.
3. Can the mass of a photon change?
According to the theory of relativity, the mass of a photon can change if its energy changes. However, the speed of light remains constant and therefore, the mass increase or decrease is not noticeable in everyday situations.
4. How does the mass of a photon affect its behavior?
The mass of a photon affects its behavior in a number of ways. For example, it determines how it interacts with other particles and how it is affected by gravity. A higher mass photon will have a stronger gravitational pull compared to a lower mass photon.
5. Is the mass of a photon measurable?
Due to the extremely small mass of a photon, it is not possible to measure its mass directly. However, scientists can indirectly measure its mass through experiments and calculations using the known relationship between mass and energy.
