B The mathematics of transforming images in Adobe Premiere - Part 1
The discussion focuses on the mathematical parameters used in Adobe Premiere to transform images for slide shows, specifically how to adjust position when changing the anchor point. Six key parameters define the image's appearance: Position X (PX), Position Y (PY), Scale (S), Rotation (R), Anchor X (AX), and Anchor Y (AY). When changing the anchor point, a formula is needed to calculate the new position (PX2, PY2) to maintain the image's appearance on screen. The derived formulas for adjusting position based on anchor changes are PX2 = PX1 + (AX2 - AX1) • S/100 and PY2 = PY1 + (AY2 - AY1) • S/100. This mathematical approach allows for precise adjustments in Premiere, enhancing the transformation of still images.
guyburns
There will be a Part 2 about a related mathematical problem.
I use Premiere to generate updated versions of old-fashioned slide shows. Not much video is involved, mostly stills that I transform to bring them alive – pans, zooms, rotations.
The Mathematics
In Premiere, an image appears in what I'll call the Window. Six parameters define the appearance: Position X, Position Y, Scale, Rotation, Anchor X, Anchor Y.
For my shows, the Window is set to 1920 x 1080 pixels. Let's say the image is 3000 x 1500 pixels. When the image is imported, the centre of the image appears in the centre of the Window. Here's what the parameters control, and here are the values automatically set for such an image when imported:
Position X = 960 This is where the horizontal centre of the image will be placed in the Window.
Position Y = 540 Ditto for the vertical centre of the image.
Scale = 100 Scaling (centred on the Anchor points)
Rotation = 0 Rotation (centred on the Anchor Points)
Anchor X = 1500 The point of the image which appears stationary under scaling and rotation.
Anchor Y = 750 Ditto
Shorten the above to PX, PY, S, R, AX, AY.
For a 3000 x 1500 image, only the central 1920x1080 part of it will appear in the Window. It can then be moved, scaled and rotated.
Question
Given an image anchored at a particular place with these parameters (PX1, PY1, S, R, AX1, AY1), and then I change the Anchor Point to (AX2, AY2), how do I calculate PX2 and PY2 so the image appears unchanged on screen?
When I change the Anchor Point, the image will abruptly move, but I want to bring it back to where it was by adjusting PX2 and PY2. I can do it by eye, but it takes time and is never exact.
Is there a general formula for PX2 and PY2 in terms of PX1, PY1, AX1, AY1, AX2, AY2?
Assume S and R are constant.
PX2 = ?
PY2 = ?
Mathematics news on Phys.org
Without rotation or scaling, I think you want (PX2, PY2) to be in the same position relative to (AX2, AY2) as (PX1,PY1) is to (AX1,AX2). Thus PX2 - AX2 = PX1 - AX1 so that PX2 = PX2 + AX2 - AX1, and a similar epression for PY2.
With rotation or scaling a similar principle applies, so that (PX2,PY2) is in the same position relative to (AX2,AY2) as the image of (PX1,PY1) under rotation or scaling about (AX1,AY1) is to (AX1,AY1).
Hey, thanks for that. I just tried it in Premier and it works, except you made a typo. The formula should have been PX2 = PX1 + AX2 - AX1.
And following your suggestion, for scaling (S in percent) I have come up with the formulaes:
And they seem to work. Thanks a lot.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
