The max. distance of fall of the bungee jumper?
In summary, the question is asking for the maximum distance a 70 kg volunteer will fall during a bungee jump with an elastic cable of unstretched length 20m and elastic modulus 3000 N. This question was posted in the wrong section and the poster is advised to post their work in the homework help section.
Mechanics!
  • Yes
    Votes: 1 100.0%
  • Yes
    Votes: 0 0.0%
  • Total voters
Esta
Please help me to solve this question because I don't have a clue to do that!
Q: In a bungee jump a volunteer of mass 70 kg drops from a bridge, tethered to his jump point by an elastic cable of unstretched length L = 20m and elastic modulus 3000 N. Ifnoring energy losses, and assuming he hits nothing below, find the jumper's maximum distance of fall.
Thanks!
Esta,
Homework questions should be posted in the homework help section, and you should post your work, even if it's only as much as looking up relevant equations in the book.
Moving this thread to homework help
-enigma
-Engineering Mentor
A: To solve this question, we can use the equation for potential energy: PE = mgh, where m is the mass of the jumper, g is the acceleration due to gravity (9.8 m/s^2), and h is the height of the jumper above the ground.
First, we need to find the height that the jumper will fall from. Since the unstretched length of the bungee cord is 20m, this means that the jumper will fall a maximum of 20m before the bungee cord starts to stretch.
Next, we need to find the potential energy at the top of the fall. We know that the jumper's mass is 70kg, so we can plug this into the equation: PE = (70kg)(9.8 m/s^2)(20m) = 13,720 J.
Now, we need to find the potential energy at the bottom of the fall. Since the bungee cord will stretch as the jumper falls, we need to take into account the elastic potential energy of the cord. We can use the equation for elastic potential energy: PE = (1/2)kx^2, where k is the elastic modulus (3000 N) and x is the distance the cord stretches.
To find x, we can use Hooke's Law: F = kx, where F is the force on the cord. At the bottom of the fall, the force on the cord will be equal to the weight of the jumper, so we can set the equations equal to each other: (70kg)(9.8 m/s^2) = (3000 N)x. Solving for x, we get x = 2.27 m.
Plugging this value into the equation for elastic potential energy, we get PE = (1/2)(3000 N)(2.27m)^2 = 7,690 J.
Now, we can find the maximum distance of fall by subtracting the potential energy at the bottom of the fall from the potential energy at the top of the fall: 13,720 J - 7,690 J = 6,030 J.
Therefore, the maximum distance of fall for the bungee jumper will be 6,030 J.
Related to The max. distance of fall of the bungee jumper?
What is the maximum distance a bungee jumper can fall?
The maximum distance a bungee jumper can fall depends on the length of the bungee cord and the weight of the jumper. Generally, bungee cords are designed to stretch to about three times their original length, so the maximum distance would be three times the length of the cord.
How is the maximum distance of fall calculated in bungee jumping?
The maximum distance of fall is calculated by taking into account the length of the bungee cord, the weight of the jumper, and the distance between the jumper and the ground. This calculation is important to ensure that the bungee cord is not too short, which could result in the jumper hitting the ground, or too long, which could cause the jumper to hit the ground with too much force.
What factors affect the maximum distance of fall for a bungee jumper?
The maximum distance of fall for a bungee jumper can be affected by several factors, including the length and elasticity of the bungee cord, the weight and height of the jumper, and external factors such as wind and weather conditions. These factors are carefully considered and adjusted by bungee jumping experts to ensure the safety and success of the jump.
Is there a limit to the maximum distance a bungee jumper can fall?
Yes, there is a limit to the maximum distance a bungee jumper can fall. This is determined by the length and strength of the bungee cord. Going beyond this limit could result in the cord breaking or the jumper hitting the ground with too much force, which can lead to serious injuries or even death. It is important for bungee jumping companies to adhere to safety regulations and regularly check and replace their bungee cords to prevent accidents.
Can the maximum distance of fall be adjusted for different bungee jumpers?
Yes, the maximum distance of fall can be adjusted for different bungee jumpers. Bungee jumping companies can use different lengths and strengths of bungee cords to accommodate jumpers of different weights and heights. They can also adjust the distance between the jumper and the ground to ensure a safe and enjoyable experience for each individual jumper.
