The maximum intensity for light transmitted through a thin film
In summary, the problem involves finding the visible wavelength reflected and refracted with the maximum intensity in a situation where light hits a thin film of kerosene spread on water at a specific angle. The solution involves using the fact that when light travels through a medium with a different refractive index, it undergoes a phase shift. The condition for constructive interference is used to determine the maximum intensity for both reflection and refraction, leading to the conclusion that the visible wavelength reflected into air is 552 nm and the refracted into water is 442 nm. This is based on the concept of constructive interference and not the energy conservation principle.
FranzDiCoccio
342
41
A thin (460 nm) film of kerosene (n=1,20) is spread out on water (n = 1,30).
Light hits the (horizontal) surface of the film coming (almost) perpendicularly from above.
A diver underwater, below the film.
a) Find out the visible wavelength reflected into air that has the maximum intensity.
b) Find out the visible wavelength refracted into water that has the maximum intensity.
  • when light travels a path of length [itex]\ell[/itex] through a medium whose refractive index is n, it undergoes a phase shift. The emerging light has the same (opposite) phase as the incident light if the path length [itex]\ell[/itex] is an even (odd) multiple of [itex]\lambda/(2n)[/itex].
  • when light reflects at the interface between two different transparent media it can undergo a [itex]\lambda/(2n)[/itex] phase shift. This happens when the refractive index of the first medium is less than the second.
  • when light is refracted at the interface between two different transparent media, there is no phase shift.
a) I've been able to solve this using the above facts.
The interference occurs between two reflected rays of different order. The first is reflected by the air-kerosene interface, the second is reflected by the kerosene-water interface, and travels twice through the film. Neither undergoes a phase shift at reflection because [itex]n_{\rm air}<n_{\rm kerosene}<n_{\rm water}[/itex].
As a result, the condition for constructive interference is
[tex]2 t = m \frac{\lambda_m}{n_{\rm kerosene}}[/tex]
Upon inspection, only [itex]\lambda_2 = 552\; {\rm nm}[/itex] falls in the visible window.
b) The provided solution is motivated is equivalent to assuming that refraction is maximum when reflection is minimum. Hence
[tex]2 t = (2m +1) \frac{\lambda_m}{2 n_{\rm kerosene}}[/tex]
and basically only [itex]\lambda_2 = 442\; {\rm nm}[/itex] falls in the visible window.
Doubts
Despite I'm obtaining the proposed results, I am a little confused by question b).
The inference "maximum refracted intensity when minimum reflected intensity" seems to come from Fresnel equations, but it can't be that, right?
Here the reflected light has minimum intensity because of interference between two (or more) reflected rays, not because each ray is individually faint.
I think that the solution should be obtained with the same kind of reasoning used for the reflected right.
It seems to me that there is one "principal" and one "secondary" refracted ray. The second is due to a reflection at the kerosene-water interface and another reflection at the kerosene-air interface.
Only the first brings about a [itex]\lambda/(2n)[/itex] phase shift. In order to have constructive interference the path of the second ray inside the film should compensate this phase shift. Therefore
[tex]2 t = (2m +1) \frac{\lambda_m}{2n_{\rm kerosene}}[/tex]
Is this correct?
It's just conservation of energy. If the energy doesn't come back, it must go forward. At the first interface, that means it's in the refracted beam. So the maximum energy refracted into the kerosene would be when reflection is at a minimum. But that's not the whole story. As you say, reflection and refraction occur at the kerosene-water interface as well. You need to consider the energy that makes it through both interfaces.
But since you're considering the effect of both interfaces to figure out when the energy coming back from BOTH reflections is a minimum, then any other energy must be going into the water (ignoring any absorbed within the kerosene itself).
RPinPA said:
It's just conservation of energy. If the energy doesn't come back, it must go forward. At the first interface, that means it's in the refracted beam. So the maximum energy refracted into the kerosene would be when reflection is at a minimum..
I do not think it's that.
I am afraid that somehow I dragged you in my doubt. Apologies. But by replying to your comment I think I cleared my doubt.
I think my confusion arises from two different meaning of "maximum": the first has to do with Fresnel equations and conservation of energy, the second has to do with constructive interference.
What you (and the textbook solution) seem to suggest is that it is a matter of energy: whatever light is not reflected is refracted (assuming no absorption).
But Fresnel equations depend on the angle, that here is fixed (and very small). So the ratio of transmitted/incident light is fixed, for a "single ray". Transmitted light is what it is.
Here "maximum" and "minimum" refer to constructive and destructive interference, so it cannot be a matter of a "single ray".
Even if the reflected intensity is maximum, the thickness of the film could be such that the reflected light cannot be seen due to destructive interference.
In the end, the textbook is not interested in assessing the amount of transmitted light, but only the wavelength attaining the maximum intensity (considering interference effects).
I think the textbook solution is correct, and probably works in any situation (any combination of refractive indices involved). But it's not a matter of energy, as it suggests (IMO).
Related to The maximum intensity for light transmitted through a thin film
What is the maximum intensity for light transmitted through a thin film?
The maximum intensity for light transmitted through a thin film is the highest level of brightness that can be achieved when light passes through a thin layer of material. This maximum intensity is determined by various factors such as the thickness and refractive index of the film, as well as the angle of incidence of the light.
How is the maximum intensity for light transmitted through a thin film calculated?
The maximum intensity for light transmitted through a thin film is typically calculated using the Fresnel equations, which take into account the properties of the film, the incident light, and the angle of incidence. These equations can be solved using mathematical methods or through computer simulations.
What is the relationship between the maximum intensity and the thickness of the thin film?
The relationship between the maximum intensity and the thickness of the thin film is complex and depends on various factors. In general, as the thickness of the film increases, the maximum intensity also increases. However, this relationship is not linear and can vary depending on the properties of the film and the incident light.
Can the maximum intensity for light transmitted through a thin film be controlled?
Yes, the maximum intensity for light transmitted through a thin film can be controlled by adjusting the properties of the film, such as its thickness, refractive index, and angle of incidence. This allows for fine-tuning of the level of brightness that is transmitted through the film.
What practical applications rely on understanding the maximum intensity for light transmitted through a thin film?
The understanding of the maximum intensity for light transmitted through a thin film is crucial in various fields, such as optics, materials science, and engineering. It is especially important in the development of thin film technologies, such as anti-reflective coatings, optical filters, and solar cells. Additionally, this knowledge is also used in industries such as electronics, where thin films are used in the production of displays and other electronic components.
