The mean of the Probability Density Function
In summary, the mean of a function is an average of y-values, while the mean of the PDF is a weighed average of x-values. The integral $$\int_{ - \infty }^\infty {xf(x)\,dx} $$ represents the expected value of the random variable X for which f is the density function.
p75213
96
The mean of a function is as follows:
$${1 \over {a - b}}\int_b^a {f(x)\,dx} $$
So why is the mean of the PDF as follows:
I thought it would have been this way:
$$\lim \,b \to - \infty \,{1 \over { - b}}\int_b^0 {f(x)\,dx\,} + \,\,\lim \,a \to \infty {1 \over a}\int_0^a {f(x)\,dx = 0 + 0 = 0} $$
Hi p75213! :smile:
The difference is that the mean of the function is an average of y-values.
The mean of the PDF is a weighed average of x-values.
The integral $$\int_{ - \infty }^\infty {xf(x)\,dx} $$ is not the "mean of the pdf"; it is the mean of the random variable X for which f is the density function. Sometimes you will see authors use rather sloppy language and say something like "let μ be the mean of the pdf", but when they say that they do not mean it literally: they mean that μ is the mean corresponding to the pdf.
RGV
Thanks guys. I've done some more reading and investigation. Rather than the mean I prefer to think of it as "expected value".
FAQ: The mean of the Probability Density Function
What is the definition of the mean of a Probability Density Function (PDF)?
The mean of a PDF represents the average value of a continuous random variable. It is calculated by integrating the product of the variable and its corresponding probability density function over its entire range.
How is the mean of a PDF different from the mean of a discrete probability distribution?
The mean of a PDF is calculated by integrating over a continuous range, whereas the mean of a discrete probability distribution is calculated by summing over a finite set of values. Additionally, the mean of a PDF can take on non-integer values, while the mean of a discrete distribution is always an integer.
What does a higher mean value of a PDF indicate?
A higher mean value of a PDF indicates that the majority of the data points are clustered around that value, with fewer data points spread out towards the tails of the distribution.
Can the mean of a PDF be negative?
Yes, the mean of a PDF can be negative if the distribution is skewed towards the negative end of the range. This means that the majority of the data points are lower than the mean value.
How is the mean of a PDF used in statistical analysis?
The mean of a PDF is used as a measure of central tendency in statistical analysis. It is often compared to other measures such as the median and mode to gain a better understanding of the distribution of the data. It is also used in calculating other statistical measures such as variance and standard deviation.
