The mesure of distances using the redshift
  • Thread starter houhou.trad
  • Tags
    Redshift
In summary, the conversation discusses using the redshift law to determine the recessional velocity of a galaxy. The problem arises in knowing the source wavelength, but it is suggested that the distinctive patterns of spectral lines from different elements can help determine this. It is also noted that it is difficult to mistake the light of a particular abundant element due to consistent shifts in the wavelengths.
houhou.trad
Hi all,
in order to determine the recessional velocity of same galaxy we use the redshift law:
[(observed wavelength) -(source wavelength) ]/source wavelength=v/c
The problem I have found here:confused: is how we can know the source wavelength.
thinks.
Space news on Phys.org
Different elements have distinctive lines in their spectra. These lines have known wavelengths you can measure in the lab. Hot hydrogen gas and plasma have distinctive patterns of spectral lines that you can recognize, and see how much it has been shifted towards longer wavelengths.
Other elements also play a role.
Thus, want you say that we know the source wavelength of these galaxies because we know already the elements that constituting them?
It is hard NOT to know, most of the universe is made of hydrogen and helium and elements have distinctive PATTERNs of lines, like 3 close together with the longer one twice as far from the middle, and relative brightnesses of the lines within a pattern
It is like a face or fingerprint, you just see "oh! those are the hydrogen lines, but just shifted over!" or Oh I see the bright yellow sodium line but it is shifted over into the red. And the shifts are all consistent, by the same ratio.
So it is hard to mistake the light of a particular abundant element, at least with nearby galaxies where we get a good sample of the light.
Hello,
Thank you for your question. I can provide some clarification on the use of redshift in measuring distances.
Firstly, the redshift law you mentioned is known as the Doppler effect, which is a result of the expansion of the universe. This means that as a galaxy moves away from us, the light it emits is stretched, causing a shift towards the red end of the spectrum. The amount of this shift is directly related to the recessional velocity of the galaxy.
To determine the source wavelength, scientists use a technique called spectroscopy. This involves breaking down the light from the galaxy into its component wavelengths, which can then be compared to known sources. By identifying specific spectral lines, we can determine the original source wavelength and calculate the redshift.
It is important to note that the redshift method is most accurate for objects that are very far away, such as galaxies in the distant universe. For closer objects, other methods such as parallax or standard candles are used to measure distances.
I hope this helps to clarify any confusion. Let me know if you have any further questions. Thank you.
FAQ: The mesure of distances using the redshift
How is redshift used to measure distances in space?
Redshift is a phenomenon in which light from distant objects in space appears to have a longer wavelength, or "shifted" towards the red end of the spectrum. This shift is caused by the expansion of the universe and can be measured using a spectroscope. By comparing the observed redshift of an object to its known intrinsic redshift, scientists can calculate the distance to the object.
What is the difference between redshift and blueshift?
Redshift and blueshift are both caused by the Doppler effect, but in opposite directions. Redshift occurs when an object is moving away from an observer, causing the light to appear shifted towards the red end of the spectrum. Blueshift, on the other hand, occurs when an object is moving towards an observer, causing the light to appear shifted towards the blue end of the spectrum.
How accurate is redshift as a method for measuring distances?
Redshift is a widely used and reliable method for measuring distances in space. However, its accuracy can be affected by various factors, such as the expansion rate of the universe, the gravitational influence of nearby objects, and the intrinsic properties of the object being observed. Scientists continue to refine and improve the techniques used to measure redshift and its associated uncertainties.
Can redshift be used to measure distances to objects outside of our own galaxy?
Yes, redshift can be used to measure distances to objects outside of our own galaxy, including other galaxies, quasars, and other distant objects. In fact, redshift is the most commonly used method for measuring distances to these types of objects, as they are too far away for other methods, such as parallax, to be effective.
How does the concept of redshift relate to the expansion of the universe?
The concept of redshift is closely related to the expansion of the universe. As the universe expands, the space between objects also expands, causing the light emitted from those objects to appear shifted towards the red end of the spectrum. This redshift is a key piece of evidence for the theory of the expanding universe and the Big Bang theory.
