The Multiple Sine function
In summary, the conversation discussed the multiple sine function, which is defined by an infinite product involving the "Multiple Sine function" and the "Double Sine function". The authors also have other papers on the subject and the conversation mentioned a few examples such as the Double Sine function, Triple Sine function, and Quadruple Sine function. The conversation also mentioned the deep connections between the Multiple Sine function and other special functions. The conversation then moved on to a proposition, which proved the Double Sine function can be expressed in closed form in terms of the Clausen function and satisfies a reflection formula. The proof used the Koyama-Kurokawa Formula and the addition formula for the Sine function.
DreamWeaver
303
Please excuse the usual rambling preamble (or should that be pre-ramble?), but last year, when idly searching on-line, I happened to chance upon a truly great, great paper by Shin-ya Koyama and Nobushige Kurokawa, concerning the "Multiple Sine function", \(\displaystyle \mathscr{S}_n(x)\). The (free) paper in question is found here -->>
http://www1.tmtv.ne.jp/~koyama/recentpapers/ei.pdf
The authors have a number of other on-line papers concerning the same subject matter, but I haven't read any of them; as soon as I saw that first one, I thought "this is a function I want to explore on my own", rather than reading more about it - yet. That being the case, I suspect [read as: expect] that everything I post below will be in one of the 'other' papers, but nonetheless, I thought I'd develop a few properties of the Multiple Sine Function and post them here. ----------------------------------------
Multiple Sine function - the definition:
I'd highly recommend reading the (short but sweet) PDF paper linked to above, but just in case, I'll very briefly skim over the authors' definition of the Multiple Sine function.
Let
\(\displaystyle \mathcal{P}_r(u) = (1-u)\, \text{exp} \left[ u + \frac{u^2}{2} + \cdots + \frac{u^r}{r} \right] = (1-u)\, \text{exp} \left[ \sum_{j=1}^{j=r} \frac{u^j}{j} \right]\)Then the Multiple Sine function is defined by the infinite product:\(\displaystyle \mathscr{S}_r(x) = \exp\left[ \frac{x^{r-1}}{r-1} \right]\, \prod_{n=1}^{\infty} \left[ \mathcal{P}_r\left( \frac{x}{k} \right) \, \mathcal{P}_r\left( -\frac{x}{k} \right)^{(-1)^{r-1}} \right]^{n^{r-1}}\)Lower order examples include the Double Sine function\(\displaystyle \mathscr{S}_2(x) = e^{x}\, \prod_{k=1}^{\infty} \left[ e^{2x} \left( \frac{1-x/k}{1+x/k} \right)^k \right]\)Triple Sine function
\(\displaystyle \mathscr{S}_3(x) = e^{x^2/2}\, \prod_{k=1}^{\infty} \left[ e^{x^2} \left( 1-\frac{x^2}{k^2} \right)^{k^2} \right]\)and Quadruple Sine function
\(\displaystyle \mathscr{S}_4(x) = e^{x^3/3}\, \prod_{k=1}^{\infty} \left[ e^{2k^2x+2x^3/3} \left( \frac{1-x/k}{1+x/k} \right)^{k^3} \right]\)I'll not reproduce it here, as it's elegantly done in the paper linked above, but Shin-ya Koyama and Nobushige Kurokawa demonstrate that\(\displaystyle \frac{ \mathscr{S}_r'(x) }{ \mathscr{S}_r(x) } = \pi x^{r-1}\cot \pi x\)
And, from there, deduce that
\(\displaystyle \int_0^{\pi z} x^{n-2}\log(\sin x)\, dx = \frac{(\pi z)^{n-1}}{(n-1)} \log(\sin \pi z) - \frac{\pi^{n-1}}{(n-1)}\log \mathscr{S}_n(z)\)This integral suggests deep connections between the Multiple Sine function and the Clausen function, Barnes' G-function, Loggamma function, and a good many other 'higher', special functions.
Now that the preliminaries are out of the way, I'll stop quoting others and start adding a few results of my own... brb (Bandit)Questions, comments, feedback, and other charitable donations would be very much appreciated on this thread -->>
http://mathhelpboards.com/commentary-threads-53/commentary-quot-multiple-sine-function-quot-10779.html
Many thanks!
Gethin :D
Proposition 1.0:
For \(\displaystyle 0<z<1 \in \mathbb{R}\,\), the Double Sine Function can be expressed - in closed form - in terms of the Clausen function, \(\displaystyle \text{Cl}_2(2\pi z)\): \(\displaystyle (1.1)\quad \mathscr{S}_2(z) = (2\sin \pi z)^{z}\, \text{exp} \left[ \frac{ \text{Cl}_2(2\pi z) }{2\pi} \right]\)
It also satisfies the reflection formula:\(\displaystyle (1.2)\quad \mathscr{S}_2(z)\, \mathscr{S}_2(1-z) = 2\sin \pi z\)Where\(\displaystyle \text{Cl}_{2n}(x) = \sum_{k=1}^{\infty} \frac{\sin kx}{k^{2n}}\)
\(\displaystyle \text{Cl}_{2n+1}(x) = \sum_{k=1}^{\infty} \frac{\cos kx}{k^{2n+1}}\)And, in particular\(\displaystyle \text{Cl}_2(x) = -\int_0^x \log\Bigg| 2\sin \frac{t}{2}\Bigg|\, dt\)
\(\displaystyle \text{Cl}_1(x) = \frac{d}{dx} \text{Cl}_2(x) = -\log\Bigg| 2\sin \frac{x}{2}\Bigg|\)NOTE: In the following proof, as well as all subsequent proofs, I will refer to the formula\(\displaystyle \int_0^{\pi z} x^{n-2}\log(\sin x)\, dx = \frac{(\pi z)^{n-1}}{(n-1)} \log(\sin \pi z)
- \frac{\pi^{n-1}}{(n-1)}\log \mathscr{S}_n(z)\)as the Koyama-Kurokawa Formula .[Or the KK-formula for short]Proof:Setting \(\displaystyle n=2\,\) in the KK-formula gives:\(\displaystyle \pi z\log(\sin \pi z) - \pi \log \mathscr{S}_2(z) = \int_0^{\pi z}\log(\sin x)\, dx = \)\(\displaystyle \int_0^{\pi z}\log(2\sin x)\, dx - \log 2\, \int_0^{\pi z}\, dx = \)\(\displaystyle \int_0^{\pi z}\log(2\sin x)\, dx -\pi z\, \log 2\)Upon setting \(\displaystyle x=y/2\, \)in the logsine integral, we get\(\displaystyle \int_0^{\pi z}\log(2\sin x)\, dx = \frac{1}{2}\, \int_0^{2\pi z}\log\left(2\sin x\right)\, dx = -\frac{1}{2}\text{Cl}_2(2\pi z)\)Hence\(\displaystyle \log \mathscr{S}_2(z) = z\log(2\sin \pi z) + \frac{1}{2\pi}\text{Cl}_2(2\pi z)\)Exponentiating both sides of the above yields (1.1). \(\displaystyle \Box\)To prove the reflection formula, replace \(\displaystyle z\,\) with \(\displaystyle 1-z\,\) in (1.1) to obtain:\(\displaystyle \mathscr{S}_2(1-z) = \Bigg( 2\sin (\pi-\pi z) \Bigg)^{1-z}\, \text{exp} \left[ \frac{ \text{Cl}_2(2\pi - 2\pi x) }{2\pi} \right]\)The addition formula for the Sine function makes it clear that\(\displaystyle \sin(\pi-\pi z) = \sin \pi z\)and\(\displaystyle \text{Cl}_2(2\pi-2\pi z) = -\text{Cl}_2(2\pi z)\)Hence\(\displaystyle \mathscr{S}_2(1-z) = \frac{2\sin \pi z}{(2\sin \pi z)^z}\, \frac{1}{ \text{exp} \left[ \frac{ \text{Cl}_2(2\pi z) }{2\pi} \right] } = \frac{2\sin \pi z}{ \mathscr{S}_2(z) }\)and\(\displaystyle \mathscr{S}_2(z)\, \mathscr{S}_2(1-z) = 2\sin \pi z\)as was to be shown. \(\displaystyle \Box\)
More to follow shortly... (Heidy)
Proposition 2.0:
This is stated without a full proof, since it assumes the following classic result of Euler:
\(\displaystyle \sin \pi x = \pi x\, \prod_{k=1}^{\infty}\left(1-\frac{x^2}{k^2} \right)
Since
\(\displaystyle \quad \mathscr{S}_2(z) = (2\sin \pi z)^{z}\, \text{exp} \left[ \frac{ \text{Cl}_2(2\pi z) }{2\pi} \right]\)The Double Sine function has the alternative infinite product representation:\(\displaystyle \quad \mathscr{S}_2(z) = (2\pi z)^z\, \text{exp} \left[ \frac{ \text{Cl}_2(2\pi z) }{2\pi} \right] \, \prod_{k=1}^{\infty}\left(1-\frac{z^2}{k^2} \right)^z\)
More on this thread soon... (Heidy)
Using (1.1):\(\displaystyle (1.1)\quad \mathscr{S}_2(z) = (2\sin \pi z)^{z}\, \text{exp} \left[ \frac{ \text{Cl}_2(2\pi z) }{2\pi} \right]\)The special values \(\displaystyle \text{Cl}_2(\pi/2) = G\) [Catalan's constant] and \(\displaystyle \text{Cl}_2(\pi) = 0\), and the extensive list of values for the Sine function found here, on the Wolfram Functions Site:
Sine: Specific values (subsection 03/02)Formula (1.1) yields the following particular values for the Double Sine function:\(\displaystyle \mathscr{S}_2\left( \frac{1}{12} \right) = \left( \frac{\sqrt{3}-1}{\sqrt{2}} \right)^{1/12}\, \exp \left[ \frac{ \text{Cl}_2(\pi/6)}{2\pi} \right]\)
\(\displaystyle \mathscr{S}_2\left( \frac{1}{10} \right) = \left( \frac{\sqrt{5}-1}{2} \right)^{1/10}\, \exp \left[ \frac{ \text{Cl}_2(\pi/5)}{2\pi} \right]\)
\(\displaystyle \mathscr{S}_2\left( \frac{1}{8} \right) = \left( 2 - \sqrt{2} \right)^{1/16}\, \exp\left[ \frac{ \text{Cl}_2(\pi/4)}{2\pi} \right]\)
\(\displaystyle \mathscr{S}_2\left( \frac{1}{6} \right) = \exp \left[ \frac{ \text{Cl}_2(\pi/3)}{2\pi} \right]\)
\(\displaystyle \mathscr{S}_2\left( \frac{1}{5} \right) = \left( \frac{5-\sqrt{5}}{2} \right)^{1/10}\, \exp \left[ \frac{ \text{Cl}_2(2\pi/5)}{2\pi} \right]\)
\(\displaystyle \mathscr{S}_2\left( \frac{1}{4} \right) = 2^{1/8}\, e^{G/2\pi}\)
\(\displaystyle \mathscr{S}_2\left( \frac{1}{3} \right) = 3^{1/6}\, \exp \left[ \frac{ \text{Cl}_2(2\pi/3)}{2\pi} \right]\)
\(\displaystyle \mathscr{S}_2\left( \frac{1}{2} \right) = \sqrt{2} \)Applying the reflection formula - (1.2) - to the above gives the further values:
\(\displaystyle \mathscr{S}_2\left( \frac{11}{12} \right) = \left( \frac{\sqrt{3}-1}{\sqrt{2}} \right)^{11/12}\, \exp \left[ -\frac{ \text{Cl}_2(\pi/6)}{2\pi} \right]\)\(\displaystyle \mathscr{S}_2\left( \frac{9}{10} \right) = \left( \frac{\sqrt{5}-1}{2} \right)^{9/10}\, \exp \left[ -\frac{ \text{Cl}_2(\pi/5)}{2\pi} \right]\)\(\displaystyle \mathscr{S}_2\left( \frac{7}{8} \right) = \left( 2 - \sqrt{2} \right)^{7/16}\, \exp\left[ -\frac{ \text{Cl}_2(\pi/4)}{2\pi} \right] \)
\(\displaystyle \mathscr{S}_2\left( \frac{5}{6} \right) = \exp \left[ -\frac{ \text{Cl}_2(\pi/3)}{2\pi} \right]\)
\(\displaystyle \mathscr{S}_2\left( \frac{4}{5} \right) = \left( \frac{5-\sqrt{5}}{2} \right)^{2/5}\, \exp \left[ -\frac{ \text{Cl}_2(2\pi/5)}{2\pi} \right]\)
\(\displaystyle \mathscr{S}_2\left( \frac{3}{4} \right) = 2^{3/8}\, e^{-G/2\pi}\)
\(\displaystyle \mathscr{S}_2\left( \frac{2}{3} \right) = 3^{1/3}\, \exp \left[ -\frac{ \text{Cl}_2(2\pi/3)}{2\pi} \right]\)
Next, from the Koyama-Kurokawa Formula \(\displaystyle \int_0^{\pi z} x^{n-2}\log(\sin x)\, dx = \frac{(\pi z)^{n-1}}{(n-1)} \log(\sin \pi z)
- \frac{\pi^{n-1}}{(n-1)}\log \mathscr{S}_n(z)\)The Triple Sine function satisfies the relation: \(\displaystyle \int_0^{\pi z} x\log(\sin x)\, dx = \frac{(\pi z)^{2}}{2} \log(\sin \pi z)
- \frac{\pi^{2}}{2}\log \mathscr{S}_3(z)\)-----------------
Proposition 3.0:
The Triple Sine function has the following closed form:\(\displaystyle \mathscr{S}_3(z) = (2\sin \pi z)^{z^2}\, \exp \Bigg[ \frac{1}{2\pi^2}\Bigg( 2\pi z\, \text{Cl}_2(2\pi z) + \text{Cl}_3(2\pi z) - \zeta(3) \Bigg) \Bigg]\)
Proof: \(\displaystyle \int_0^{\pi z} x\log(\sin x)\, dx = -\frac{(\pi z)^2}{2} \log 2 + \int_0^{\pi z} x\log(2\sin x)\, dx \)Let \(\displaystyle x \to y/2\, \Rightarrow \, dx = dy/2\, \Rightarrow\)\(\displaystyle -\frac{(\pi z)^2}{2} \log 2 + \frac{1}{4}\, \int_0^{2 \pi z} y\log\left( 2\sin \frac{y}{2} \right) \, dy = \)\(\displaystyle -\frac{(\pi z)^2}{2} \log 2 + \frac{1}{4} \left[ -y\text{Cl}_2(y)\Bigg|_0^{2\pi z} + \int_0^{2 \pi z} \text{Cl}_2(y)\, dy \right] = \)\(\displaystyle -\frac{(\pi z)^2}{2} \log 2 - \frac{\pi z}{2}\text{Cl}_2(2\pi z) + \frac{1}{4}\, \int_0^{2 \pi z} \text{Cl}_2(x)\, dx = \)\(\displaystyle -\frac{(\pi z)^2}{2} \log 2 - \frac{\pi z}{2}\text{Cl}_2(2\pi z) + \frac{1}{4}\, \sum_{k=1}^{\infty} \frac{1}{k^2}\, \int_0^{2 \pi z} \sin kx\, dx = \)\(\displaystyle -\frac{(\pi z)^2}{2} \log 2 - \frac{\pi z}{2}\text{Cl}_2(2\pi z) + \frac{1}{4}\, \sum_{k=1}^{\infty} \frac{1}{k^2}\, \left[ -\frac{1}{k} \cos kx \right]_0^{2\pi z} = \)\(\displaystyle -\frac{(\pi z)^2}{2} \log 2 - \frac{\pi z}{2}\text{Cl}_2(2\pi z) - \frac{1}{4}\, \text{Cl}_3(2\pi z) +\frac{1}{4}\, \sum_{k=1}^{\infty}\frac{1}{k^3} = \)\(\displaystyle -\frac{(\pi z)^2}{2} \log 2 - \frac{\pi z}{2}\text{Cl}_2(2\pi z) - \frac{1}{4}\, \text{Cl}_3(2\pi z) +\frac{\zeta(3)}{4} = \)\(\displaystyle \frac{(\pi z)^{2}}{2} \log(\sin \pi z)
- \frac{\pi^{2}}{2}\log \mathscr{S}_3(z)\)Hence\(\displaystyle \log \mathscr{S}_3(z) = \)\(\displaystyle z^2\log(2\sin \pi z)+ \frac{z\, \text{Cl}_2(2\pi z) }{\pi} +\frac{ \text{Cl}_3(2\pi z) }{2\pi^2} - \frac{\zeta(3)}{2\pi^2}\)And\(\displaystyle \mathscr{S}_3(z) = (2\sin \pi z)^{z^2}\, \exp \Bigg[ \frac{1}{2\pi^2}\Bigg( 2\pi z\, \text{Cl}_2(2\pi z) + \text{Cl}_3(2\pi z) - \zeta(3) \Bigg) \Bigg]\)This proves (3.0).
FAQ: The Multiple Sine function
What is the Multiple Sine function?
The Multiple Sine function is a mathematical function that takes in an input value and returns the sum of multiple sine functions of that input value.
How is the Multiple Sine function different from the regular Sine function?
The Multiple Sine function differs from the regular Sine function in that it allows for multiple sine functions to be added together, while the regular Sine function only calculates the sine of a single value.
What are the key properties of the Multiple Sine function?
The key properties of the Multiple Sine function include its periodicity, where it repeats itself after a certain interval, and its amplitude, which determines the height of the function's peaks and valleys.
What are some real-world applications of the Multiple Sine function?
The Multiple Sine function is commonly used in physics and engineering to model wave-like phenomena, such as sound and light waves. It is also used in signal processing and digital communications.
How can the Multiple Sine function be graphed and analyzed?
The Multiple Sine function can be graphed using a graphing calculator or software, and its key properties, such as amplitude and period, can be determined by analyzing the graph. Additionally, the function can be manipulated and transformed using mathematical operations.
13K
16K
24K
16K
