A The name of the process underlying distributons with a hazard rate
The discussion centers on the relationship between hazard rates and probability distributions, particularly highlighting that different hazard rate functions correspond to different distributions. Participants clarify that the stochastic process underlying these distributions is known as a random point process. The exponential distribution is specifically mentioned as having a constant hazard rate, while other distributions may have variable hazard rates. The conversation also touches on the debate over the sequence of probability density functions (pdf) and cumulative distribution functions (cdf). Ultimately, the key takeaway is the identification of the random point process as the foundational concept for hazard rate distributions.
Ad VanderVen
TL;DR Summary
In the exponential distribution, the hazard rate is constant. The hazard rate does of course not always have to be constant, but can also be a function of time, which then leads to different distributions. But my question is: what is the stochastic process called that underlies this type of distributions with a constant or variable hazard rate?
You have this the wrong way round: different distributions have different hazard rates. You can easily calculate the hazard function for any distribution.
pbuk: Actually you are wrong. 'different distributions have different hazard rates' should be 'different hazard rate functions have different distributions'. Moreover, you do not answer my question: What is the name of the stochastic process which leads to hazard rate distributions?
Reference: https://www.physicsforums.com/threa...ying-distributons-with-a-hazard-rate.1045495/'
I've heard it called failure rate analysis if that helps.
Also this argument the two of you are having is over whether the pdf or the cdf comes first, which seems silly.
I now know what the process is called that underlies probability distributions with a hazard rate that is a function of time, such as the exponential distribution where the function of time is a constant. The process is called a random point process. Explanation can be found on Youtube:
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
