The need for electrolytes between cathode and anode in battery
In summary, batteries need electrolytes in order to maintain a constant voltage through a chemical process, unlike capacitors which discharge their accumulated charge. The separation of the anode and cathode in a battery allows for the flow of current both inside and outside of the battery, preventing a build up of charge on the electrodes. This is necessary for the battery to continue functioning and producing an electro-motive force.
Sleepycoaster
My question is simple: Why do batteries need electrolytes? Wouldn't the battery need the charge to flow only through the circuit in the device being powered? The point of the anode and cathode's separation is to preserve the potential difference, so why allow charge to flow through an electrolyte?
A battery is different than a capacitor. A capacitor is what you're thinking of, it will simply discharge the charge it has accumulated. A battery, on the other hand, maintains a voltage through a chemical process. It produces an electro-motive force through the reaction of the anode and cathode with the electrolyte. When a batter drains, it's voltage stays roughly constant (because the chemical reactions are driving the voltage), while when a capacitor drains its voltage drops as it loses charge.
Likes 1 person
Typical alkaline AA battery has a capacity around 2Ah. Calculate how much charge it could push through the outside circuit in its lifetime. Assuming circuit is not closed, this charge has to build up somewhere. Let's assume charge builds up at the ends of the battery - they are separated by 50 mm. Try to calculate force that would attract both ends. This is a trivial application of Coulomb's law.
Now, compare that force with force required to lift Eiffel tower. Or better yet, to the gravitational attraction between Earth and the Moon.
Likes 1 person
That's the meaning of "circuit", the current also flows inside the battery. A battery is not different in this respect from other sources of current, like, e.g., a dynamo. As Borek already pointed out, the reason is to avoid built up of (more than very small amount of) charge on the electrodes which would immediately stop the current.
Likes 1 person
Electrolytes play a crucial role in the function of batteries. They are responsible for allowing the flow of ions between the cathode and anode, which is essential for the battery to produce electricity.
Firstly, the anode and cathode are made of different materials, such as metals or metal oxides, and they have different chemical properties. When the battery is charged, chemical reactions occur at the anode and cathode, causing the release of electrons. These electrons flow through the external circuit, powering the device.
However, for the chemical reactions to continue, a balance of positively charged ions (cations) and negatively charged ions (anions) must be maintained within the battery. This is where the electrolyte comes in. It contains these ions and allows them to move between the anode and cathode, completing the circuit and enabling the battery to continue producing electricity.
Additionally, the electrolyte also helps to regulate the flow of ions, preventing the buildup of excess charge and ensuring the battery can operate safely and efficiently. Without electrolytes, the battery would quickly lose its ability to produce electricity, and its lifespan would be significantly reduced.
In summary, electrolytes are essential for the function of batteries as they facilitate the movement of ions, maintain the balance of charge, and regulate the flow of electricity.
Related to The need for electrolytes between cathode and anode in battery
1. What are electrolytes and why are they necessary in a battery?
Electrolytes are electrically conductive solutions or materials that are necessary in a battery to allow the flow of ions between the cathode and anode. They play a crucial role in the chemical reactions that generate electrical energy in a battery.
2. How do electrolytes help in the functioning of a battery?
Electrolytes help in the functioning of a battery by allowing ions to move between the cathode and anode. This movement of ions creates an electrical current that can be used to power devices.
3. What happens if there are no electrolytes between the cathode and anode in a battery?
If there are no electrolytes between the cathode and anode in a battery, there will be no flow of ions, and therefore no electrical current will be generated. This means that the battery will not be able to provide power to devices.
4. Can any type of electrolyte be used in a battery?
No, not all types of electrolytes can be used in a battery. The electrolyte must be able to conduct electricity and be stable enough to withstand the chemical reactions that occur during the battery's operation. Typically, electrolytes used in batteries are in the form of liquid or gel solutions.
5. How do manufacturers choose the right electrolyte for a battery?
Manufacturers choose the right electrolyte for a battery based on factors such as its conductivity, stability, and compatibility with the materials used in the battery. They also consider the specific needs and requirements of the battery, such as its voltage and energy density, to determine the most suitable electrolyte for optimal battery performance.
  • General Math
  • Electrical Engineering
  • Electromagnetism
