The negation of "A and B" does not include "not A and not B"
  • Thread starter docnet
In summary: C'7. 'A and B and C'Yes, that is correct. And to clarify, in the context of logic, 'or' is often used inclusively, meaning that 'A or B' is true if either A or B or both are true. So in your list, 'A and B' and 'A and C' would both be included in the statement 'A or B or C'.
docnet
486
What is the negation of "A and B"?
There are no equations.
This website says that the negation of "A and B" is "not A or not B"
It seems there are four possible combinations:
##1. ## A and B
##2. ## A and not B
##3. ## B and not A
##4. ## not A and not B
The correct negation is "not A or not B", which only includes ##2## and ##3##. It seems like the negation should also include ##4##, since ##4## is not ##1.##. What gives?
The condition "not A or not B" includes all elements in the set of "not A and not B", and possibly more.
Likes docnet
It does. In general, "P or Q" means P or Q or both. There is a logical operation called exclusive or, XOR, which excludes the case of both.
Likes docnet
PS in terms of sets: "Not A or Not B" means ##A^c \cup B^c##, which is everything not in ##A \cap B##. I.e.$$(A \cap B)^c = A^c \cup B^c$$Which is another way to say that the negation of "A and B" is "not A or not B".
Likes docnet
Hopefully your question has been answered by now, but this is a very basic principal in boolean algebra (De Morgan's law), which extends into deeper branches of math, as has been mentioned. It might be helpful to write out simple truth tables for each expression to see that they are equivalent, but more understanding can be gained by studying the proof of the theorem.
For ##A^c \cup B^c##, which is everything not in ##A \cap B##, it seems more appropriate to say "Not A and/or Not B" instead of "Not A or Not B"
In everyday English that is common usage to avoid ambiguity. But not in mathematics, logic or computer programming, where ambiguity is avoided by definition of "or". And, as I said, logic and programming have an XOR (exclusive OR).
Another example is "there exists ##x## such that ...". In common English you might say "there exists one or more ...". But, not in mathematics, where the convention is that "there exists" is any number and "there exists a unique ##x##" is used when you need to limit it to only one possible element.
There's no right and wrong, but these are the conventions of mathematical language.
Likes hutchphd and docnet
This is just a matter of understanding what the union, ##\cup##, means.
And, to be clear, the negation of AND is NAND ##-## XOR means 'either A is true or B is true, but not both', while NAND means 'it is not the case that both A and B are true', and allows, but does not require, that one or the other of them is true.
Question: Does that definition of OR change when you have, for example, three items A, B and C?
So, does 'A or B or C' make possible these seven choices?
1. 'A'
2. 'B'
3. 'C'
4. 'A and B'
5. 'B and C'
6. 'A and C'
7. 'not A, not B, not C'
1. 'A'
2. 'B'
3. 'C'
4. 'A and B'
5. 'B and C'
6. 'A and C'
7. should be 'A and B and C'.
The definition of 'or' (conjunction) does not change; however, it's a binary relation, and adding a 3rd term means there are 2 binary relations, which can risk ambiguity when the 2 binary relations are not the same, as in e.g. 'A or B and C' ##-## we could distinguish the 2 meanings with a comma, as in 'A, or B and C' or 'A or B, and C'; however, it's generally more clear to use parentheses, as in 'A or (B and C)' or '(A or B) and C'.
1. 'A'
2. 'B'
3. 'C'
4. 'A and B'
5. 'B and C'
6. 'A and C'
Yes, except 7 should be 'A and B and C'. Mathematically "or" works like a union of sets and is not exclusive.
If we're talking boolean algebra, I would recommend learning about disjunctive / conjunctive normal form. Either would be a minimal representation of a boolean expression of multiple variables.
Edit: should have been in reply to docnet
  • Wow
Likes PeroK
I think that learning fundamentals of binary logic does not require, and should precede, learning about canonical normal forms ##-## this might be a useful reference: https://en.wikipedia.org/wiki/Truth_table
Likes Mark44, FactChecker and PeroK
El
I guess my meaning was that one can distill a logical equation (via truth tables) in a fairly straightforward way, and going through that process is a pretty useful way to better understand the math.
The original question can be rephrased as, why is 'not A or not B' the negation of 'A and B', and in particular, why is 'neither A nor B' allowed by that negation.
A quick answer to that is that the negation of 'both' is simply 'not both', which doesn't prohibit 'neither'.
Likes PeroK
I was just trying to point out, in light of the three variable example, one could drive a disjunctive normal form simply by looking at the fact that (typically) first row of the truth table has the only false value, for the specific case. One could also derive a conjunctive normal form the hard way, using the seven "truths" in the other rows of the truth table and reducing, which ultimately is just (a or b or c), so... But one can see that both forms are ultimately the De Morgan's equivalent of each other.
The question was what is the negation of 'A and B'. The given answer was 'not A or not B'. That answer is correct.
We can observe that both 'not (A and B)' and 'not A or not B' are negations of 'A and B' ##-## the negation of a conjunction is equivalent to the disjunction of negations of the constituents of the conjunction (DeMorgan's) ##-## and that the second of the two expressions has the negation distributed over the constituents, while the first does not (the second is in DNF and the first isn't).
The construction of a truth table methodically distributes the negation over the constituents.
1. 'A'
2. 'B'
3. 'C'
4. 'A and B'
5. 'B and C'
6. 'A and C'
A truth table for a Boolean expression A will contain two rows, one for each possible value of A. A truth table for two Boolean expressions A and B will contain four (##2^2##) rows. With three Boolean expressions A, B, and C, there will be eight (##2^3##) rows.
As already noted, what you have in #7 is incorrect for A or B or C. Here is an expanded version of your list, together with the value of A or B or C.
1. 'A' true, B false, C false
2. 'B' true, A false, C false
3. 'C' true, A false, B false
4. 'A and B' both true, C false
5. 'B and C' both true, A false
6. 'A and C' both true, B false
7. A, B, C all true
8. A, B, C all false -- This is the only combination for which A or B or C is false.
Normal form seems like a topic that would be presented in a course on database design, which is not usually part of a precalculus course.
Same comment as above.
Likes sysprog, fishturtle1 and PeroK
I think that @valenumr was making reference not to database design normalization, but to the logic concepts of canonical forms, e.g. disjunctive normal form.
Maybe this way of looking at things is helpful: A&B is only true when A, B are both simultaneously true. Its negation is then true when it is not the case that both are true. This includes the situation/case where neither is true.
7. A, B, C all true
@docnet, I think that this part of @Mark44's answer to your follow-up question is worth another look, in that it completes the truth table.
FAQ: The negation of "A and B" does not include "not A and not B"
What does the statement "The negation of "A and B" does not include "not A and not B"" mean?
The statement means that if "A and B" is false, then "not A and not B" cannot be true. In other words, the negation of "A and B" does not include the possibility of both A and B being false.
What is the difference between "A and B" and "not A and not B"?
The difference between "A and B" and "not A and not B" is that "A and B" requires both A and B to be true, while "not A and not B" requires both A and B to be false. In other words, "A and B" is only true when both A and B are true, while "not A and not B" is only true when both A and B are false.
Can "A and B" and "not A and not B" both be true at the same time?
No, "A and B" and "not A and not B" cannot both be true at the same time. This is because "A and B" requires both A and B to be true, while "not A and not B" requires both A and B to be false. Therefore, they are mutually exclusive.
Can "A and B" and "not A and not B" both be false at the same time?
Yes, "A and B" and "not A and not B" can both be false at the same time. This is because "A and B" is only true when both A and B are true, while "not A and not B" is only true when both A and B are false. Therefore, they can both be false if either A or B (or both) are false.
What is the truth value of the statement "The negation of "A and B" does not include "not A and not B""?
The truth value of the statement "The negation of "A and B" does not include "not A and not B"" is always true. This is because the statement is a logical equivalence, meaning that it is always true regardless of the truth values of A and B.
