A "The Operation Combination Problem"
The "Operation Combination Problem" focuses on finding all combinations of mathematical operations applied to integers from 1 to n to achieve a specific result R. The operations allowed are addition, subtraction, multiplication, and division, with each integer used exactly once and performed from left to right, ignoring operation precedence. The complexity of the problem increases with larger values of n and R, and it can be approached through combinatorial search techniques. This problem is particularly relevant for mathematicians and computer scientists interested in exploring solution spaces and computational efficiency. The analogy drawn between mathematical configurations and spatial topologies has been debated, with some questioning its validity.
hdsfhsdf
TL;DR Summary
Education question
In the "Operation Combination Problem," we explore the space of possible solutions, much like we explore the different possible topologies for the universe. The problem consists of finding all possible combinations of mathematical operations that, when applied to a finite set of integer numbers from 1 to n, produce a given result R.
To solve this problem, we must navigate this "solution space" using the following constraints and specifications:
  1. Use only the operations of addition, subtraction, multiplication, and division.
  2. Each integer number from 1 to n must be used exactly once.
  3. Operations must be performed from left to right, without considering operation precedence (i.e., without applying the "PEMDAS" or "BIDMAS" rule).
By exploring this "solution space," we seek to uncover the different possible "configurations" for combining the integer numbers, just as we seek to understand the different possible topologies of the universe.
For example, if n = 3 and R = 4, one possible combination within this "solution space" might be: (1 × 2) + 3 = 4. This combination represents a specific way of combining the integer numbers from 1 to 3 to achieve the result 4, just as a specific spatial curvature represents a specific way of configuring space in the universe.
SUMMARY:
The problem involves finding all possible ways to combine integer numbers from 1 to n, using only the operations of addition, subtraction, multiplication, and division, to achieve a specific result R. Each integer number must be used exactly once, and operations must be performed from left to right without considering operation precedence.
The goal is to navigate the "solution space" to uncover all possible combinations that yield the result R. The complexity of the problem depends on the chosen values of n and R and can be approached using combinatorial search techniques and solution space exploration.
Side note:
The problem may be of interest to mathematicians and computer scientists, who might propose more efficient approaches to solving it.
The relation is
(((...(a_1b_1a_2)b_2a_3)b_3a_4)....)b_{n-1}a_n=R
where
1\leq i \leq n, \{a_i\}=\{1,2,3,...,n\}
1\leq j \leq n-1, b_j \in \{+,-,*,/ \}
LHS has ##n! 4^{n-1}## patterns. R is a rational number which has equal or less than ##n! 4^{n-1}## different values. We can easily see variety and degeneracy in R by computer.
For an example I assume
-(n-1)(n-1)!\leq R \leq n!+1
Why do you think this is an appropriate analogy?
No, it represents a specific way of combining the integer numbers from 1 to 3 to achieve the result 5.
Again, the analogy is absurd.
hdsfhsdf said:
The problem may be of interest to mathematicians and computer scientists.
Why do you think that? It might be of some interest to someone for practicing programming techniques, but no more so than the dozens of similar problems on CodeWars.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
