The other day our lecturer was going through field axioms, rules of
In summary, the conversation was about the concept of infinity and how it relates to division. The lecturer mentioned that x/∞=0, which sparked a discussion on the limitations of this expression and its implications. It was clarified that this statement is only true in the sense of limits and that infinity should not be treated as a real number in arithmetic operations. The use of extended real numbers was also mentioned and it was emphasized that it takes time to build intuition about this number system. The conversation ended with a clarification on how the value of a fraction approaches zero as the denominator approaches infinity, in the context of limits.
11thHeaven
48
The other day our lecturer was going through field axioms, rules of numbers, I guess what you'd call very elementary number theory. In particular, he was explaining what you can and can't do with ∞, and he mentioned that x/∞=0.
I guess I'd just like some clarification on this. Should this not imply that 0∞=x? Why can we divide by infinity but not by zero? Is this just "how it is"?
One interpretation that makes sense to me is that infinity doesn't "go" into any number, no matter how large: is this what the expression really means?
Help appreciated :)
Mathematics news on Phys.org
Have you studied limits? x/∞≠0 in actuality. It only approaches zero. Assume that infinity is 999999999999999999999 and x =1.
Notice how it's an insignificant number in almost any context. It will never strictly equal zero though.
You can say that the number asymptotically approaches zero.
Normal rules of algebra don't apply for infinity or zero.
Your lecturer should not have stated that x/∞ = 0. ∞ is not a number, so no arithmetic operations on it are defined. ∞ is valid as specifying a limit. So it is correct to say that the limit of x/n →0 as n →∞.
Bad lecturer!
Yes, bad lecturer! He should have made it very clear that +∞ is not a real number, so not all arithmetic operations and rules make sense.
However, +∞ is an extended real number. The extended real numbers are just the real numbers with +∞ and -∞. As extended real numbers, we often do define x/∞=0. This is just a definition, we could have defined it as 2 or 3 if we wanted to. The definition as 0 is chosen because it conforms to our intuition. But again: this is not division as you know it between real numbers since ∞ is not a real number.
Also, from x/∞=0 does not follows that ∞.0=x (whatever x is). Indeed, in order to establish this, we would apply the rule a/b=c implies a=bc. But this rule is only true for real numbers, and not necessarily for extended real numbers.
This is only true in the sense of limits. While it is not true to say that
[itex]\frac{x}{\infty} = 0[/itex],
it is correct to say:
[itex]\lim_{n \to \infty} \frac{x}{n} = 0 [/itex].
When working with the extended reals it is common to define all operations on infinity.
[tex] \frac x \infty = 0 [/tex] is the common definition.
The lecturer may have said accurate things, and the listener may have overlooked the import of some context. :-p
Real analysis is better understood by using the extended real numbers. Geometry, number theory, and complex analysis benefit greatly from projective arithmetic.
I assert that it's better to (properly) learn a number system that involves infinite numbers than it is to use ad hoc means to avoid them.
Pay close attention to the "what you can and can't do" part. Among the things you can't do is convert an equation
a/b=c​
into an equation
a=bc​
You've spent a long time working exclusively in a very specific number system: you've probably gotten quite used to how, e.g., the real numbers work. In that setting, there's no harm in mentally equating the expression
a/b​
with the notion of
the unique solution to a=bx​
so long as b is known to be nonzero.
(actually, that's not true: I believe there is harm in being unable to form a concept of division in its own right)
But now you're learning about a new setting, and so you're going to have to pay careful attention to what is appropriate for the new setting. Among the things inappropriate for the new setting is replacing the notion of "division" with the notion of "solving a multiplicative equation".
You've just learned this new number system. It will take some time to build intuition about it. Pay careful attention to what you can and cannot do with these new numbers. Pay attention to (and experiment with and do exercises about) the practical applications of these numbers, and soon enough you will develop intuition about them. When you're used to the applications, the reason why the number system is the way it is will become obvious, and you will eventually wonder why you ever thought otherwise!
Maybe i can help you by giving a crude example,
consider the following ->
1/1 = 1
1/10 = 0.1
1/100 = 0.01
1/1000 = 0.001
1/10000000000 = 0.0000000001
and so on...
so, if the denominator exceeds any known quantity (which we lovingly refer to as our dear Mr. ∞), we see that the value moves closer and closer to zero... thus, the definition of limit :)
1/1 = 1
1/10 = 0.1
1/100 = 0.01
1/1000 = 0.001
and so on...
Your statement is confused -- you are mixing up sequences with limits of sequences.The "moving value" is not a property of any fraction: a sequence of fractions could be viewed this way, though, if you think of the index as being "time".
The extended real number fraction 1/(+∞) is simply an extended real number: it does not "move". This fraction does not appear anywhere in what you have written.
Instead, the denominators are converging to +∞, and since division is continuous there, the left hand sides are converging to 1/(+∞) .
Related to The other day our lecturer was going through field axioms, rules of
1. What are field axioms?
Field axioms are a set of mathematical rules that define the properties of a field, which is a mathematical structure that includes two operations (usually addition and multiplication) and follows specific properties.
2. What is the importance of studying field axioms?
Studying field axioms is important because they provide a foundation for understanding and solving complex mathematical problems. Field axioms also have many applications in various fields such as physics, economics, and computer science.
3. Can you give an example of a field axiom?
One example of a field axiom is the commutative property of addition, which states that the order in which you add two numbers does not affect the result. For example, 3 + 4 is equal to 4 + 3.
4. Are there different types of field axioms?
Yes, there are different types of field axioms depending on the type of field being studied. Some common types include real numbers, rational numbers, complex numbers, and finite fields.
5. How are field axioms different from other mathematical axioms?
Field axioms are specific to fields, while other mathematical axioms may apply to different mathematical structures. Additionally, field axioms are used to define the properties of a field, while other axioms may be used to prove theorems or solve equations.
  • General Math
