The period of a composite wave
In summary, the sum of multiple functions with different periods will have a period that is the same as the longest of the periods of the individual functions.
  • #36
sophiecentaur said:
I seem to remember that , from Archimedes, it can be shown that between any two rational numbers there will always be an irrational number which lies in between them. So with your Maths hat on, you have to be right. This implies that signals of any two frequencies, generated totally independently, would have an indeterminately long repeat period.
Frequencies, generated from the same frequency reference, will have rational values (on that reference scale), though.
Hi @sophiecentaur
So, for my situation would you say that the individual signals whose sum makes up the final signal are generated independently? They have randomly different phases and frequencies, but they are generated by the same underlying function which means that the individual points of the final sum are not independent.
From the measurements that I made, I was never able to detect a period from large core fibers (hosting a few hundred modes). So I think that either means the ratio is "irrational", or the least common multiple is too large. For example, here is an experimental measurement (a single mode on the left, and many modes on the right):
242974
Paul Colby said:
Thanks, this should have been the sentence to start the thread. The degree to which one may abstract your question depends on what you actually mean by "signal" "wave form" even function is too vague in this case IMO.
So, at the heart of your simulation is a truly linear system, time harmonic or band limited EM waves in a fiber. Your signal is a time averaged normalized intensity (absolute square) of the interferometer output as a function of interferometer length. The scan frequency is not relevant, it's just a means of reading out the data.
We (well, I actually) can only guess as to what this simulation contains in the way of assumptions or details. Just in general terms the guide or fiber wavenumber will depend on the mode in a complex way depending on nearly everything. There is no reason to expect the ratio of these mode wave numbers to be integer or rational values.
Hi @Paul Colby
Thanks a lot for the explanation. I have another question. If one of the underlying curves is given by ##T(\omega)##, would it be mathematically correct to express the final (superposition/average) signal by the integral ##TOT=\int_{\omega_{a}}^{\omega_{b}}T\left(\omega\right)d\omega##? This is for some frequency band ##\omega_{a}-\omega_{b}##.
  • #37
I would say no because ##T(\omega)## is the ratio of field amplitudes. The output field of the device at ##\omega## is ##E_{\text{out}}(\omega)=T(\omega)E_{\text{in}}(\omega)##. The output intensity is the absolute square of ##E_{\text{out}}##. Only the fields are linear. Try writing out the full expression for just two ##\omega##. Justify to yourself that all cross terms your proposed integral just drops. Hint, they won't.
  • #38
But ##T## is the squared modulus of the ratio of output to input, i.e.,
$$T=\left|\frac{E_{out}}{E_{in}}\right|^{2}.$$
When the final signal is the combination of several different ##T## curves, can't you express it using the integral notation? (I think I've seen that in some other areas)
  • #39
Not where I come from. I can see why you're having issues. Defining ##T## as the absolute square is like using ##R^2## for resistance in circuit analysis, it would make no sense.
  • #40
But that's a very common definition of ##T## used in optics textbooks (e.g. §9 of "Optics" by Hecht) or many journal articles such as this one.
  • #41
It's a consequence of the 'confusion' between Power and Field strength. R(esistance) is not a ratio of squares but T (in that paper) is defined as a ratio of squares. Even in PF contributions, it is often necessary to define out terms, to avoid needless arguments.
I must say, using a squared ratio (positive sign) makes it hard to produce a meaningful SUM in calculations when phasors are involved. There must be a good reason why they get away with T always being positive.
Likes Paul Colby and roam
  • #42
There is nothing magic in choosing symbols. The paper chooses them poorly IMO but carefully defines their meaning. Equation six refers to T as the "intensity transmission factor". If you treat it like an amplitude transmission factor, you will often get wrong or misleading answers. If the light you are dealing with is monochromatic or incoherent this might be fine. Does your simulation assume various modes are mutually coherent? If a phase relation is assumed between two modes, then the output of the ring is not the sum of intensities. Using T will yield a meaningless number. It all depends on the physics being simulated which remains a mystery to me even now.
[added] If the problem you are working is generalizing the paper to more than a single fiber mode then each fiber mode would (could) be driven by a single common coherent laser mode. In this case I would not expect the output intensity to be the sum of the mode intensities.
Likes roam and sophiecentaur
  • #43
Hi @Paul Colby
Yes, that is precisely what I am trying to do. In that paper they are only considering rings made of standard telecommunications SMF. I am simulating a situation where there is more than one mode present. The output intensity that you receive with a photodiode on an oscilloscope is the combined effect due to the intensity of individual modes.
The modes are driven by the same laser source, but they each travel at a different speed depending on their group refractive index.
What I had done in my simulation was to add the individual ##T## values (i.e., for ##M## modes I had ##T_{\text{Total}}=\left|\frac{E_{2}}{E_{1}}\right|_1^{2}+...+\left|\frac{E_{2}}{E_{1}}\right|_{M}^{2}##).
If I understood correctly, the right approach would be to compute all the individual ##\frac{E_{2}}{E_{1}}## curves, add them all together, and then take the absolute square of the sum to find intensity?
So we could write:
$$T=\left|\left(\frac{E_{2}}{E_{1}}\right)_{1}+...+\left(\frac{E_{2}}{E_{1}}\right)_{M}\right|^{2}$$
Is that correct?
  • #44
roam said:
Is that correct?
No. Amplitude ratios are no more linear than intensity ratios. If I understand the very brief glimpse of the paper the ring is coupled to a fiber line via a coupler. With multimode fiber, one will get varying phase and amplitudes in each mode. Each complex fiber mode (amplitude with phase) will get multiplied by its own coefficient and the result summed. Your expression assumes all these amplitudes are equal in magnitude and phase. This assumption isn't even close to true for a real coupler IMO.
Likes roam
  • #45
I might just comment on common practice in optics. For telescopes imaging incoherent light the intensity transfer function or MTF is indeed a sum of intensities. this happens because a telescope is linear in intensity. Basically
##\langle E(\omega_1)E(\omega_2)\rangle = I(\omega)\delta(\omega_1-\omega_2)##
In this case the ##\langle\rangle## are time averaging of the fields. Adding two fields at different frequencies the cross terms vanish in very short order making the resulting intensity the sum.
As with everything it's vital to understand the underlying principles and not just apply the "usual tricks". Optics is rife with these IMO.
  • #46
Hi @Paul Colby
I am slightly confused. I want to make sure I understood you correctly. Could you please write the expression for the sum that you think is valid?
My simulation already accounts for the modes acquiring different phases. I could also assign each mode with a different amplitude.
The plot in my post #36 is an actual measurement, which is what I am trying to simulate with the sum. I'm only trying to get a basic first-order picture. A more rigorous approach would have to account for phenomena such as modal coupling, etc.
  • #47
There is no plot in #36? Only #1 shows any plots. None appear to be a measurements?
The problem I have with writing out an expression even in principle is it's too complex a linear system to do off the cuff. From what you've asked so far I have little confidence you understand basic network theory. Explaining this here is much to ask but I would suggest introductory books on RF and microwave design. Sections on S and T matrix treatments of waveguides would be applicable.
The coupler in the paper is a 4-port device for single mode fiber becomes a 4N-port device where for common multimode fiber N is greater than 100. Of the ##10^4## S-matrix parameters only a handful are likely known even partially. I would also expect these to not be well controlled for a multimode coupler.
Good luck.
  • #48
Here is the picture of sample measurements from my post #36.
Okay. But I think you may be assuming that the spatial modes are coherent. They oscillate at different frequencies since they each experience a different group index. That means the cross term averages to zero, and you can add individual intensities.
  • #49
Can I get this straight? It seems to me that the device you are talking about is not a source but a complicated filter with roughly but not perfectly harmonically related nulls / modes. I don't understand where the concept of coherent modes comes in.
  • #50
Sorry, I thought you wanted to generalize the formalism in the paper you linked to on ring resonators for multiple transmission line modes. Ring resonators are passive linear devices which don’t alter the input frequency in any way whatsoever.
A simpler example is single versus multi mode fiber. If fed with a monochromatic source neither modifies the frequency of the light, ever.
  • #51
That expresses my problem exactly. Afaics, the other modes will just change the phase of the resultant throughput (or possibly, for a broadband input, produce extra peaks or notches.) As an RF man, I am often confused by the way Optical guys look at things. After all, it's exactly the same stuff!
Likes Paul Colby
  • Other Physics Topics
  • Science Fiction and Fantasy Media
  • Quantum Interpretations and Foundations
